MX-17.1: List of unmounted devices not cleared after each devices unplugged [SOLVED]
app4soft
#1 Post by app4soft »
After upgrading from MX-17 to MX-17.1 in file manager (Thunar) list of unplugged devices not cleared. So, if plug same device few times each time it create new device entry but old entry not automatically removed.
Before this upgrade, under previouse MX-17 there was no such issue.
Here is "Quick System Info" output:
System:    Host: mx1 Kernel: 4.15.0-1-amd64 x86_64 bits: 64 Desktop: Xfce 4.12.3
           Distro: MX-17.1_x64 Horizon December 15, 2017
Machine:   Device: other-vm? System: SAMSUNG product: SR58P v: 06YK serial: N/A
           Mobo: SAMSUNG model: SR58P serial: N/A BIOS: Phoenix v: 06YK date: 03/05/2008
Battery    BAT1: charge: 24.4 Wh 100.0% condition: 24.4/24.4 Wh (100%)
CPU:       Dual core Intel Pentium Dual T2330 (-MCP-) cache: 1024 KB
           clock speeds: max: 1600 MHz 1: 1596 MHz 2: 1560 MHz
Graphics:  Card: Advanced Micro Devices [AMD/ATI] RS600M [Radeon Xpress 1250]
           Display Server: x11 (X.Org 1.19.2 )
           drivers: ati,radeon (unloaded: modesetting,fbdev,vesa)
           Resolution: 1280x800@60.00hz
           OpenGL: renderer: Gallium 0.4 on ATI RS600 version: 2.1 Mesa 13.0.6
Audio:     Card Advanced Micro Devices [AMD/ATI] SBx00 Azalia (Intel HDA) driver: snd_hda_intel
           Sound: Advanced Linux Sound Architecture v: k4.15.0-1-amd64
Network:   Card-1: Qualcomm Atheros AR242x / AR542x Wireless Network Adapter (PCI-Express)
           driver: ath5k
           IF: wlan0 state: down mac: <personal-info>
           Card-2: Marvell 88E8039 PCI-E Fast Ethernet Controller driver: sky2
           IF: eth0 state: down mac: <personal-info>
Drives:    HDD Total Size: 120.0GB (93.1% used)
           ID-1: /dev/sda model: TOSHIBA_MK1246GS size: 120.0GB
Partition: ID-1: / size: 30G used: 27G (96%) fs: ext4 dev: /dev/sda1
           ID-2: swap-1 size: 1.88GB used: 0.08GB (4%) fs: swap dev: /dev/sda5
Sensors:   System Temperatures: cpu: 47.0C mobo: 47.0C
           Fan Speeds (in rpm): cpu: N/A
Info:      Processes: 178 Uptime: 2 days Memory: 439.1/1744.0MB
           Client: Shell (quick-system-in) inxi: 2.3.54
martianRocks
Re: MX-17.1: List of unmounted devices not cleared after each devices unplugged
#2 Post by martianRocks »
I'm having a similar issue too but I didn't get to the multi-list level that you have app4soft. Could be the extra apps you installed broke something? I know that when I uninstalled Conky on MX 17, stuff stopped working right and had to re-install and just disable that cockroach. The problem seems to me to be with the Notifier and who is and isn't talking to it and also looks like it could be caused by an MX Dev Team tweak but the same issue is in my Debian 9.4 VBox. I wish I had the ability to get under the hood but I'm still programming in Basic inside DOS and haven't gotten much further than that.
#3 Post by dolphin_oracle »
Are you unmounting the devices first before pulling the sticks out?
do the duplicates show in in your /etc/fstab?
is it any device, or just the one in your screenshot?
what sort of device is that?
app4soft
#4 Post by app4soft »
Q: Are you unmounting the devices first before pulling the sticks out?
A: Yes.
Q: do the duplicates show in in your /etc/fstab?
A: No. In /etc/fstab this duplicates not listed.
Q: is it any device, or just the one in your screenshot?
A: I have only one mobile device. ("File System" & "D" are two partitions of internal HDD on my PC)
Q: what sort of device is that?
A: Android 6.0 smartphone (model is ASSISTANT AS-5432)
spidermouse
#5 Post by spidermouse »
This happens when the device is in MPT mode.
https://bugs.debian.org/cgi-bin/bugrepo ... bug=883425
#6 Post by Jerry3904 »
Maybe an upgrade to 4.15 kernel using MX Package Installer would help(?).
#7 Post by timkb4cq »
The debian bug report indicates it's fixed in the gvfs package currently in experimental.
app4soft
#8 Post by app4soft »
timkb4cq wrote:The debian bug report indicates it's fixed in the gvfs package currently in experimental.
Any news or updates of gvfs package for MX-17?
#9 Post by timkb4cq »
Thanks for the prompt.
The fix has now made it into Buster. I'll see if I can backport it tomorrow.
#10 Post by timkb4cq »
I wasn't able to backport the Buster version of gvfs, but I was able to apply that patch to the Stretch version.
It's available in the Testing MX-17 repository. MXPI upgrades it just fine.
