MX-17.1 Some programs can't resize.
This bug looked like it got carried over from MX-17 to MX-17.1 where some program windows can't resize. So far I found this issue with advert-block and Libre Office.
Re: MX-17.1 Some programs can't resize.
LibreOffice is interesting. The "Front Page" of LibreOffice appears to have minimum height related to fitting all the buttons on the left into the window. It can be made taller than that but not shorter no matter what.
However each of the LibreOffice components can be made to.
Open Settings -> Appearance and change your DPI to 96. Close. Open it again and uncheck Custom DPI. Close.
Now open Libreoffice Writer. Resize the window to only a few lines of text high. Close it.
Change your custom DPI back to 120. Writer will now open at the size you had it set and is completely resizable.
I'll have to experiment to see if there's a way to accomplish this without the back & forth - I rather suspect there is.
Thanks. It's a little bit better but it's still too long. My DPI is set to 150 because of my eyes. What's strange it's only these two programs that won't resize. All the other programs have no problem.timkb4cq wrote:LibreOffice is interesting. The "Front Page" of LibreOffice appears to have minimum height related to fitting all the buttons on the left into the window. It can be made taller than that but not shorter no matter what.
I set my dpi to 150 and I can resize Writer or Calc too tiny to use:
http://mxrepo.com/misc/Peek-2018-03-14.webm
Not that window. This window. I use the Alt key and left mouse click to move it to get to what's hidden as a work around.
Sorry, that's by (the LO devs) design. We can't fix it. You can't resize it any smaller than that on Windows either.
OK, thanks.
- Eadwine Rose
- Administrator
I can make it really small..
I have more than one file in there, but this is the smallest I can get it:
But indeed not smaller vertically.
MX-23.2_x64 July 31 2023 * 6.1.0-18-amd64 ext4 Xfce 4.18.1 * 8core AMD Ryzen 7 2700
Have you checked if this window is maximized by default ? It should be the case : maximized windows can't be resized, same as the fullscreen-sized ones.Mauser wrote:OK, thanks.
To check this you could use [Alt]+[F10] to restaure/maximize it and [Alt]+[F8] to resize it.
It works here, like for Eadwine :
> Desktop : AMD 64 bits (unknowned monocore model :P looking for an AM2+ 4cores Phenom) | RAM 4Go DDR2 | MX@daily updates, sudo apt dist-upgrade
> Laptop x2 : WIP obsolescence and "old" batteries prices have killed my project
You can reduce the height vertically until the Base Database icon is touching the Help & Extensions buttons at the bottom.Eadwine Rose wrote:I can make it really small..
