something is going wrong - see my local version of the Devil's Triangle :
What i've tried (without rebooting the machine) :
- stop and restart conky
- remove and reinstall Orage's plugin (in xfce4-panel, i didn't reinstall the package itself)
- sudo /etc/init.d/ntp restart
- sudo ntpdate -u pool.ntp.org && sudo hwclock -w
4 Mar 11:58:03 ntpdate[24927]: sendto(mirror3.rafal.ca): Operation not permitted 4 Mar 11:58:03 ntpdate[24927]: sendto(37.44.185.42): Operation not permitted 4 Mar 11:58:03 ntpdate[24927]: sendto(static.140.107.46.78.clients.your-server.de): Operation not permitted 4 Mar 11:58:03 ntpdate[24927]: sendto(97-127-86-125.mpls.qwest.net): Operation not permitted 4 Mar 11:58:05 ntpdate[24927]: sendto(mirror3.rafal.ca): Operation not permitted 4 Mar 11:58:05 ntpdate[24927]: sendto(37.44.185.42): Operation not permitted 4 Mar 11:58:05 ntpdate[24927]: sendto(static.140.107.46.78.clients.your-server.de): Operation not permitted 4 Mar 11:58:05 ntpdate[24927]: sendto(97-127-86-125.mpls.qwest.net): Operation not permitted 4 Mar 11:58:07 ntpdate[24927]: sendto(mirror3.rafal.ca): Operation not permitted 4 Mar 11:58:07 ntpdate[24927]: sendto(37.44.185.42): Operation not permitted 4 Mar 11:58:07 ntpdate[24927]: sendto(static.140.107.46.78.clients.your-server.de): Operation not permitted 4 Mar 11:58:07 ntpdate[24927]: sendto(97-127-86-125.mpls.qwest.net): Operation not permitted 4 Mar 11:58:09 ntpdate[24927]: sendto(mirror3.rafal.ca): Operation not permitted 4 Mar 11:58:09 ntpdate[24927]: sendto(37.44.185.42): Operation not permitted 4 Mar 11:58:09 ntpdate[24927]: sendto(static.140.107.46.78.clients.your-server.de): Operation not permitted 4 Mar 11:58:09 ntpdate[24927]: sendto(97-127-86-125.mpls.qwest.net): Operation not permitted 4 Mar 11:58:11 ntpdate[24927]: no server suitable for synchronization found
- Using MX tool to set time didn't work either
***EDIT***
After resetting the timezone (using MX tool) Conky's output has been corrected, but not Orage's one.
***EDIT 2***
Orage timezone had to be reset manually, in the plugin's preferences.
[SOLVED] ! \o/
Still, the result of ntpdate -u pool.ntp.org being no server suitable for synchronization found is intriguing. Is my ISP blocking ntp packets ? :/
**EDIT 3***
Lol no. What a dead brain I am. I forgot to allow ntp protocol (port 123) after reinstalling my firewall (gufw) -_-"
[sudo] Mot de passe de ksz :
4 Mar 13:29:37 ntpdate[26833]: step time server 147.135.187.131 offset 6.140419 sec
