[SOLVED] Synaptic shows errors / during install of packages
Report Bugs, Issues and non- pacakage Requests
penguin
Post by penguin » Tue Jan 23, 2018 2:27 pm
Occasionally I have noticed errors in Synaptic but today, trying to install a program.
Synaptic gaves this error.
E: virtualbox-guest-utils: subprocess installed post-installation script returned error exit status 1
E: virtualbox-guest-x11: dependency problems - leaving unconfigured
E: virtualbox-qt: dependency problems - leaving unconfigured
E: virtualbox: dependency problems - leaving unconfigured
W: Download is performed unsandboxed as root as file '/root/.synaptic/tmp//tmp_sh' couldn't be accessed by user '_apt'. - pkgAcquire::Run (13: Permission denied)
In the Synaptic > Details there are error explanations :
Gtk-WARNING **: Unable to locate theme engine in module_path: "xfce", at /usr/share/perl5/Debconf/FrontEnd/Gnome.pm line 96, <> line 2.
Gtk-WARNING **: Unable to locate theme engine in module_path: "xfce", at /usr/share/perl5/Debconf/FrontEnd/Gnome.pm line 114, <> line 2.
Selecting previously unselected package gtklp.
(Reading database ... 403067 files and directories currently installed.)
Preparing to unpack .../gtklp_1.3.1-0.1+b1_i386.deb ...
Unpacking gtklp (1.3.1-0.1+b1) ...
Selecting previously unselected package mtpaint.
Preparing to unpack .../mtpaint_3.40-3_i386.deb ...
Unpacking mtpaint (3.40-3) ...
Processing triggers for mime-support (3.60) ...
Processing triggers for desktop-file-utils (0.23-1) ...
Setting up gtklp (1.3.1-0.1+b1) ...
Processing triggers for menu (2.1.47+b1) ...
Setting up mtpaint (3.40-3) ...
Setting up virtualbox-guest-utils (5.2.4-dfsg-1~mx17+1) ...
insserv: warning: script 'K20.depend.stop' missing LSB tags and overrides
insserv: warning: script 'K20.depend.boot' missing LSB tags and overrides
insserv: warning: script 'K20.depend.start' missing LSB tags and overrides
insserv: script console-setup: service console-setup already provided!
insserv: script lm-sensors: service lm-sensors already provided!
insserv: There is a loop at service rmnologin if started
insserv: Starting .depend.stop depends on rmnologin and therefore on system facility `$all' which can not be true!
insserv: Starting .depend.boot depends on rmnologin and therefore on system facility `$all' which can not be true!
insserv: Starting .depend.start depends on rmnologin and therefore on system facility `$all' which can not be true!
insserv: Max recursions depth 99 reached
insserv: loop involving service lm-sensors at depth 6
insserv: There is a loop between service rmnologin and mountnfs-bootclean if started
insserv: loop involving service mountnfs-bootclean at depth 11
insserv: loop involving service mountnfs at depth 10
insserv: There is a loop between service rmnologin and urandom if started
insserv: loop involving service urandom at depth 6
insserv: loop involving service mountall at depth 5
insserv: There is a loop between service .depend.stop and mountall if started
insserv: loop involving service networking at depth 8
insserv: loop involving service mountall-bootclean at depth 6
insserv: loop involving service checkfs at depth 7
insserv: There is a loop between service rmnologin and bootlogd if started
insserv: loop involving service bootlogd at depth 3
insserv: loop involving service mountdevsubfs at depth 2
insserv: loop involving service .depend.stop at depth 1
insserv: There is a loop between service .depend.stop and mountall-bootclean if started
insserv: There is a loop between service rmnologin and mountnfs if started
insserv: loop involving service alsa-utils at depth 17
insserv: There is a loop between service rmnologin and mountdevsubfs if started
insserv: loop involving service udev at depth 2
insserv: There is a loop between service rmnologin and mountkernfs if started
insserv: loop involving service mountkernfs at depth 1
insserv: exiting now without changing boot order!
update-rc.d: error: insserv rejected the script header
dpkg: error processing package virtualbox-guest-utils (--configure):
Processing triggers for man-db (2.7.6.1-2) ...
Processing triggers for gnome-menus (3.13.3-9) ...
dpkg: dependency problems prevent configuration of virtualbox-guest-x11:
virtualbox-guest-x11 depends on virtualbox-guest-utils (= 5.2.4-dfsg-1~mx17+1); however:
Package virtualbox-guest-utils is not configured yet.
dpkg: error processing package virtualbox-guest-x11 (--configure):
dpkg: dependency problems prevent configuration of virtualbox-qt:
virtualbox-qt depends on virtualbox-guest-x11; however:
Package virtualbox-guest-x11 is not configured yet.
dpkg: error processing package virtualbox-qt (--configure):
dpkg: dependency problems prevent configuration of virtualbox:
virtualbox depends on virtualbox-qt (= 5.2.4-dfsg-1~mx17+1); however:
Package virtualbox-qt is not configured yet.
dpkg: error processing package virtualbox (--configure):
virtualbox-qt
virtualbox
E: Sub-process /usr/bin/dpkg returned an error code (1)
A package failed to install. Trying to recover:
virtualbox-qt
virtualbox
I tried to remove virtualbox as follow:
https://askubuntu.com/questions/692982/virtualbox-failed-to-install-after-upgrade-to-15-10
Reinstalling .... but problem persist.
I use Mx Linux 32 bit.
Should I remove virtualbox? I do not use it.
Also I have noticed from the first day of MX Linux 17, the follow error:
sudo leafpad
(leafpad:22716): Gtk-WARNING **: Unable to locate theme engine in module_path: "xfce",
Seems that something is missing ..... ?
P.S. For latest problem with Leafpad. Just I checked. Something is missing with my theme.I will try to find error based on :
https://classicforum.manjaro.org/index.php?topic=22524.0
Error not happens when only when I switch to Adwaita or some other theme. With other themes problems persist.Seems that many of the themes are blacklisted.
First Problem - VirtualBox - removed . No issues any more
Second Problem - GTK+-2.0 theme engine for Xfce was missing. I installed it and no any issues any more )
Re: Synaptic error / refuses to install packages
Post by Stevo » Tue Jan 23, 2018 2:31 pm
Yes, you can remove it if you are not using it. The guest packages are only useful if you are running inside Virtual Box, too.
m_pav
Re: [SOLVED] Synaptic shows errors / during install of packages
Post by m_pav » Sat May 26, 2018 10:08 pm
I got this for the first time yesterday when updating a VBox install. The error messages are benign, a bug was filed originally in 2005 but with slightly different wording which the synaptic devs changed to read a little differently. It causes no issues and can be safely ignored. The latest version of Synaptic that seems to be affected is 0.84.2, which we have in MX17.1
Mike P
Regd Linux User #472293
(Mine)Lenovo T560, i7-6600U, 16GB, 2.0TB SSHD, MX17 64-bit
(Wifes) Asus M4A88TD-M, AMD Phenom II x4 955 CPU, nVidia GF610, 6Gb, 500GB+320GB, MX17 + KDE
(Kids) Intel NUC, J1900, 4GB, 64GB SSD, MX17
