I update my USB drives every 2 or 3 days with the latest from the repositories and generate a new snapshot which I've recently started writing with Live USB Maker.
The Live USB Maker in MX Tools worked great up until Jan 3rd. I could create a live USB from an .iso I generated with mx-snapshot.
Then, after my next update on Jan 6, a different gui was presented with a text box containing "System" and a drop down containing only "Detected". An Apply and Close button were the actions.
When I hit Apply, it only allows me to Clone. I can no longer select a .iso.
I have attached an image of the before (Jan 3) and after (Jan 6) that contains the screen shots of the two gui presentations.
Perhaps it is supposed to work this way, and I should go back to using Rufus. But I also thought perhaps something got checked in by accident or maybe was accidentally reverted to an early version.
BTW: It is my pleasure to make another donation to the MX project. I've been an enthusiast since the 2014 release, and it just keeps getting better. Thank you for all you do for us.
MX17 - Live USB Maker GUI Changes **SOLVED
Re: MX17 - Live USB Maker GUI Changes
Thanks very much for this--and to all our donators--it helps a lot.BTW: It is my pleasure to make another donation to the MX project. I've been an enthusiast since the 2014 release, and it just keeps getting better. Thank you for all you do for us.
I'll check into it. we made some changes to accommodate language translation, and I might have broke something. thanks!
try this one.
extract it into your home folder and run as
sudo ~/live-usb-maker-gui
Sorry I didn't make feedback . But I just took a look and it seemed you corrected well the issue...dolphin_oracle wrote:I'll check into it. we made some changes to accommodate language translation, and I might have broke something. thanks!
dolphin_oracle, thanks! Works perfectly. I just had do something else I included here in case someone is following this thread and needs this work around.dolphin_oracle wrote:try this one.
extract it into your home folder and run as (super user)
# Let root have access to your display
xhost +
thanks. I've sent the changes up to anti for packaging.
