This message appears after grub starting loading the system where it stucks.
How it happened. I install Debian 9.2 into another partition where it change the UUID of the swap partition.
I have two MX 16.1 installed in my laptop the one I do not use boots fine the other one which I use and it is from MX15 to MX16.1 has this message.
The problem I noticed is connected with the cryptsetup because when I remove it and put manually the UUID of the root and swap partition loads normally, if the cryptsetup is installed it doesn’t matter what I do, it is impossible to load the MX.
Now that partly I solve the problem I noticed other side effects like:
mount /mnt
mount: can't find /mnt in /etc/fstab
What can I do with this on MX?
[SOLVED] Ignoring BGRT: invalid status 0 (expected 1) Loading please wait
Re: Ignoring BGRT: invalid status 0 (expected 1) Loading please wait
Likely I had stored the UUID of the old swap partition, I change it, I restore my backup and everything is ok now.
Don’t forget user, always backup everything of your computer.
