Hello translators,
The mx-tweak app is being updated with a new window and dialog. Since this closely follows an Xfce window, we have been able to load Transifex with the new strings - and their translations. The quality of the translations may vary, so we need you to check over your language and make any necessary corrections.
So please have a look at strings 26 and 72-98 of the mx-tweak resource on Transifex. You will find translations present for most of our used languages. If yours is not there yet, please wait and check in a day or two.
If you want to see how the strings are used, you can get a good idea by calling up the existing Xfce window:
- right-click open spot on your panel
- Panel
- Panel preferences
- Items
- Window buttons
- Edit
New mx-tweak translations to check
Re: New mx-tweak translations to check
Very cool to import those, well done.
The Swedish translation was OK. Only had to make a minor adjustment to one string.
Henry
Henry
Thanks are owing to d_o for originating the idea.
The translated string in LANG=de looks good to me ;=)
Nevertheless, I'd like to have instead of title "Dialog" when editing "Window Bottons" the title "Window Buttons", which translated to "Fensterknöpfe" in de_DE.
So I would rather translate "Dialog" to just "Fensterknöpfe".
Looking into running "MX Tweak" version 18.08.1 I do see "Tasklist Settings" but missing this string to translate in transiflex.
Might be I'm not looking into the latest version?
In the Dev Team thread we agreed to change that to "Options."Looking into running "MX Tweak" version 18.08.1 I do see "Tasklist Settings" but missing this string to translate in transiflex.
Also, there is no version number on the About screen for 18.08.1.
Looks like I might have forgot to give the window a title. I'll try to get that fixed and up tonight.
title updated.
as to the version...apparently I never added that to mx-tweak at all. Will fix.
version number now fixed.
