Translations required
For suggestions, procedures and requests for translations of documentation and apps to languages other than English.
Old Giza
#1 Post by Old Giza »
Translations are needed on Transifex for the resource mx-live-usb-maker. Since this has been based on antix's live-usb-maker, many of the strings are in common which should allow you to take advantage of suggestions and make your work shorter. 22 of the 66 strings are already filled in.
I have also based the desktop file entries on the antix version. If necessary please edit and add a post.
[Desktop Entry]
Name=MX Live USB Maker
Nmae[am]=MX በ ቀጥታ-usb መፍጠሪያ
Name[ca]=MX Creador de USB autònoms
Name[de]=MX Live USB Erzeugung
Name[el]=MX Δημιουργός Live-usb
Name[es]=
Name[fr]=MX Créateur de Live-usb
Name[it]=MX Crea Live USB
Name[ja]=
Name[nl]=MX Live USB Maker
Name[pt]=MX-Criar USB-executável
Name[ro]=
Name[ru]=
Name[sv]=MX Live USB Maker
Comment=Create a full-featured live-usb
Comment[am]=ሙሉlገጽታ በ ቀጥታ-usb መፍጠሪያ
Comment[ca]=Crea un USB autònom complert
Comment[de]=Erzeugung eines voll ausgestatteten Live-USB-Sticks
Comment[el]=Δημιούργησε live-usb με πλήρη χαρακτηριστικά
Comment[es]=
Comment[fr]=Créer un live-usb complet
Comment[it]=Crea una Live USB con tutte le funzionalità
Comment[ja]=
Comment[nl]=Maak een volledig voorziene live-usb
Comment[pt]=Criar sistema executável (instalação frugal), com todas as funcionalidades, em dispositivo USB (Live-usb maker)
Comment[ro]=
Comment[ru]=
Comment[sv]=Skapa en live-usb med alla möjligheter
Richard
Re: Translations required
#2 Post by Richard »
[Desktop Entry]
Name[es]=MX Construir Live-USB
Name[ja]=
Name[ro]=
Name[ru]=
Comment[es]=MX Construir Live-USB
Comment[ja]=
Comment[ro]=
Comment[ru]=
Eadwine Rose
#3 Post by Eadwine Rose »
I see something.. shouldn't
be
Name[am]=MX በ ቀጥታ-usb መፍጠሪያ
MX-23.2_x64 July 31 2023 * 6.1.0-18-amd64 ext4 Xfce 4.18.1 * 8core AMD Ryzen 7 2700
#4 Post by anticapitalista »
Eadwine Rose wrote:I see something.. shouldn't
be
For a moment, I thought 'Wow!, ER knows Amharic'. Then I looked closely.
Eadwine Rose
#5 Post by Eadwine Rose »
I'm good, I'm not THAT good heheh ;)
iezzi_michele
#6 Post by iezzi_michele »
Do I also translate the first string?
Program_Name
#7 Post by Adrian »
iezzi_michele wrote:Do I also translate the first string?
Program_Name
That's from a template, it will be replaced at compile time, it should not be on transifex, so no, don't translate it.
iezzi_michele
#8 Post by iezzi_michele »
Program_Name
OK thank you very much
Return to “Translations”
