viewtopic.php?f=94&t=50081
I believe that installing Waterfox is the best "bug fix" to address the Firefox bug! I've not been happy with Mozilla's / Firefox's add-on strategy and management (user controls and "forceware") for a long time and now you can count me as a new Waterfox fan after my first install. I simply told the Waterfox installer to import from Firefox and, low and behold, even my add-ons were up and running again on my first launch of Waterfox. A couple of preferences required re-setting (including a few quick terminal copy commands to restore my previous Firefox tabs on launch) but it took me far less time that it took me to review and reject the options to try to fix Firefox. (I'm certainly not willing to let Firefox snoop my system to obtain a test fix for something as simple as a certificate snafu--even for the brief period allegedly required to obtain the pre-release fix!) A final bug fix is presently pathetically overdo, given the bug as it was publicly reported .
I just used:
sudo apt-get update
sudo apt-get install waterfox
My add-ons, history, bookmarks and forms were ported-over automatically after telling the Waterfox installer to import from Firefox. The only thing I had to do was to get Waterfox to restore my tabs upon lauch. Make sure you enable this feature in Waterfox "preferences" first, if you used it in Firefox. Then simply terminate both Firefox and Waterfox and copy a few files (save backups first, just in case). You'll need to find your specific hidden directory paths but here's what I did (I hope no typos):
cp ~/.waterfox/2pazrqd.default/sessionstore.jsonlz4 ~/.waterfox/2pazrqd.default/sessionstore.jsonlz4.bak
cp -r ~/.waterfox/2pazrqd.default/sessionstore-backups ~/.waterfox/2pazrqd.default/sessionstore-backups.bak
cp ~/.mozilla/firefox/bztufw4l.default/sessionstore.jsonlz4 ~/.waterfox/2pazrqd.default/sessionstore.jsonlz4
rm -fr ~/.waterfox/2pazrqd.default/sessionstore-backups
cp ~/.mozilla/firefox/bztufw4l.default/ ~/.waterfox/2pazrqd.default/
I used <ctl+d> to save some bookmarks and did not experience this problem:
viewtopic.php?p=500586#p500586
Recommended!
https://www.waterfox.net/
https://www.waterfox.net/blog/waterfox- ... -download/
I think Mozilla is turning into Microsoft, with the clear belief that it knows best what is best for users!
Please post your experiences and opinions here--both good and bad.
