antix-mx derivative
antix-mx derivative
regards!
https://yadi.sk/d/2-NuHJ7-pl_DHQ
euclid5.iso
xfce
pulseaudio
mobile wifi
bluetooth
vlc
470 mb
all apps from the best linux os
-mx-linux!
euclid5.iso
xfce
pulseaudio
mobile wifi
bluetooth
vlc
470 mb
-mx-linux!
Re: antix-mx derivative
Can't download to have a look.
- Eadwine Rose
- Administrator
Hrmm weird.. works for me.
Just a sec, maybe I can help you out.
Works here.
- Eadwine Rose
- Administrator
Going to send you a pm soon Anti
PM sent with different download link.
DebianDog, in case anyone is wondering.
You might want to wear sunglasses.
debiandog "Jessie" from the DogLinux project might have been considered "similar to" antiX (not a "derivative of" though)
https://debiandog.github.io/doglinux/ -=- https://github.com/DebianDog/doglinux
and I had tracked it, listed it within the without-systemd.org wiki http://without-systemd.org/wiki/index.p ... ut_systemd
but dropped the listing as of their "debiandog Stretch" release, which clearly is "derivative of" debian (including systemd init)
ps: the DogLinux isos should (already) be available from archive.org
(md5sum or not, i would not encourage posting to // downloading from some non-descript MEGAupload -alike filesharing site)
I'm not gonna look. I'll mention that if that's the case (the desktop seen in the iso garish), then it must be a further, 3rd-party, remake of debiandog.You might want to wear sunglasses.
Across versions, the originals, as issued, were nicely themed and the preinstalled wallpapers had a calm/relaxing tone.
it is made with this script with mx-linux
packages!
Edit eadwine, added code tags, they are to the right of the " button
packages!
#!/bin/bash
# fredx181 2017-07-31, 'MakeLive' for Stretch (Debian 9), creates a minimal live system
# with aufs support and porteus-boot style included
# 2017-08-05, fixed support for Jessie host (previously worked only from Stretch)
# and removed install of linux-headers and aufs-dkms (build time gets shorter)
# instead copy aufs.ko for kernel 4.9 to /lib/modules/<kernel_version>/kernel/fs/aufs
# and execute "depmod <kernel_version>" and create new initrd.img-<kernel_version> in /boot
# dancytron suggestion, separate field for Desktop related packages
# 2017-08-14 GUI version using yad, but should be run from terminal
# 2017-08-17 GUI and CLI version into one, added different options:
# -help (or no option, will show help) -gui -cli, or e.g. -cli <config_file> (use config file), -conf (create standard config file)
# jd7654 and AndresC2 suggestion, keep the apt cache, jd7654, separate field for (graphical) applications (such as leafpad firefox)
# 2017-08-19 show helptext when made a typo on first parameter and create build_setup.conf (ready to use as config file)
# 2017-08-21 detect if login-manager is installed (and make that default)
# and make obvious in build_setup.conf which architecture the build has been made for
# 2017-08-26 GUI only, choice of DE's at start, when run without config file
# Bug fixed for LZ4 support
# 2017-09-02, added full 'Dog' build option
# 2017-09-08, added 'Kiosk' option (GUI)
# 2017-09-09, added choice of Desktop environments also for when used -cli
# 2017-09-12, added ChromeDog and ObDog to choice of Desktop environments
# 2017-09-17, more safe unmounting 'mount binds' and some minor changes
# 2017-09-24, small fix, remove 'stretch/apt/archives/lock' when script is interrupted
# 2017-09-30, try again if passwords not match
# 2017-10-10, should work on any puppy without tricks (if debootstrap installed) and on xenialdog32
# 2017-11-03, ask at start of build process, to run Xterm at later point
# (to run any command in the chroot, e.g. synaptic to install some more packages)
# 2017-11-17, added choice to install pae or no-pae kernel, in case of 32bit build
# 2017-11-23, changed installed kernel to 4.9.0-4 (previously was 4.9.0-3)
# 2018-01-12, changed installed kernel to 4.9.0-5 (previously was 4.9.0-4)
# 2018-01-13, added xserver-xorg-video-intel to standard config (otherwise X wouldn't start on some machines)
# 2018-02-24, changed installed kernel to 4.9.0-6 (previously was 4.9.0-5)
# And dropped no-pae support
# 2018-08-15, changed installed kernel to 4.9.0-7 (previously was 4.9.0-6)
# set to yes if you want to keep the locale files in /usr/share/locale
export KEEP_LOCALES="no"
export LD_LIBRARY_PATH=
standard () {
# Set the standard, (modify as desired, or run with a custom config file)
# Be careful with removing from this section (mostly essential)
BASE_INSTALL="wget net-tools ifupdown wireless-tools sysvinit-core xserver-xorg-core xserver-xorg psmisc fuse x11-utils x11-xserver-utils dbus-x11 busybox sudo mawk xinit xterm pciutils usbutils file rsync dosfstools volumeicon-alsa alsa-utils pm-utils xdotool wmctrl desktop-file-utils mime-support cryptsetup-bin squashfs-tools fakeroot xserver-xorg-input-evdev pv xserver-xorg-input-synaptics ntfs-3g nano xserver-xorg-video-intel"
# Base Dog Packages, recommended to keep: yad gtkdialog obshutdown pup-volume-monitor peasywifi
BASE_DOG_APPS_INSTALL="yad gtkdialog obshutdown pup-volume-monitor peasywifi chpupsocket edit-sfs-pcmanfm filemnt-pcmanfm remaster-scripts quick-remaster apt2sfs sfsload fixdepinstall greybird-theme-dd-stretch makedebpackage flashplayerchoice peasyclock"
# Applications
BASE_APPS_INSTALL="leafpad gparted parted synaptic viewnior firefox-esr=45.9.0esr-1 pfind conky"
# Desktop environment related
DESK_APPS_INSTALL="openbox obconf pcmanfm lxpanel lxrandr lxinput lxappearance"
FIRMWARE="firmware-linux-free" # see below for choices
EXTRA_DOG_APPS_INSTALL=""
# Remove automatically installed packages: during installing, some are installed that you might not need, e.g.
# xserver-xorg-video-vmware, REM_AUTO_INST=TRUE will uninstall it.
REM_AUTO_INST="TRUE"
# To force 32 bit build on a 64 bit OS, set to TRUE
FORCE32="FALSE"
##### Below a selection of firmware packages available (mostly for wireless) #####
##### atmel-firmware firmware-realtek bluez-firmware firmware-atheros firmware-linux-free firmware-linux-nonfree firmware-netxen firmware-ti-connectivity firmware-b43legacy-installer firmware-iwlwifi firmware-ipw2x00 firmware-libertas firmware-intelwimax firmware-brcm80211 firmware-b43-installer firmware-qlogic firmware-bnx2 firmware-misc-nonfree firmware-bnx2x firmware-zd1211
##### Some extra dog applications: debdoginstallscripts dogradio youtube-get2 youtube-viewer peasyfwmon gifondesktop upgrade-kernel conkyclock redshiftgui mpv peasymount peasyscale peasyxorburn peasyglue
create_conf () { # option -conf
##### Generate standard config file stretchlive.conf #####
echo '# Configuration for mklive-stretch, modify as desired
# NOTE: Leave every commented (#) line commented as it is
# See at the bottom commented out for info
### Start configuration
# yad gtkdialog obshutdown pup-volume-monitor peasywifi
# Force 32 bit on 64 bit OS (set to FALSE for 64-bit build on 64-bit OS)
FORCE32="FALSE"
### End configuration
# A selection of firmware packages available (mostly for wireless):
# debdoginstallscripts dogradio youtube-get2 youtube-viewer peasyfwmon gifondesktop upgrade-kernel conkyclock redshiftgui mpv peasymount peasyscale peasyxorburn peasyglue
# Choice of Desktop:
# Default is openbox with pcmanmfm providing the desktop, lxpanel, etc..
# To change, replace what is in the DESK_APPS_INSTALL field with for example:
# mate-core (for MATE), xfce4 (for XFCE), lxde (for LXDE)
# No guarantee that all work as expected, might require some fixing
# During installing all the packages, some are installed that you might not need, e.g.
# (possibly (large) library libllvm3.9 will then be autoremoved, depending on your other package choices)
# To force 32 bit build on a 64 bit OS set FORCE32=TRUE
# Locales: To keep locale files, set to KEEP_LOCALES=yes on top of the script' > stretchlive.conf
# Not running from terminal ?
tty -s;
if [ $? -ne 0 ]; then
msg=" Please run this script from terminal"
xmessage "`echo -e $msg`"
exit 0
fi
if [ "`whoami`" != "root" ]; then
echo "This script should be run as root"
echo "Please run again, e.g. 'sudo ./mklive-stretch -gui', exiting now..."
sleep 3
exit
fi
echo -e "\e[0;36mChecking network connection...\033[0m"
busybox ping -c1 google.com > /dev/null
echo -e "\e[0;33mThere is no network connection. Cannot continue, exiting...\033[0m"
sleep 3
exit
else
echo -e "\e[0;32mOK\033[0m"
sleep 1
fi
# Information button
function info () {
echo -e "\n *** A selection of firmware packages available (mostly for wireless) *** \n atmel-firmware firmware-realtek bluez-firmware firmware-atheros firmware-linux-free firmware-linux-nonfree firmware-netxen firmware-ti-connectivity firmware-b43legacy-installer firmware-iwlwifi firmware-ipw2x00 firmware-libertas firmware-intelwimax firmware-brcm80211 firmware-b43-installer firmware-qlogic firmware-bnx2 firmware-misc-nonfree firmware-bnx2x firmware-zd1211 \n\n *** Some extra dog applications *** \n debdoginstallscripts dogradio youtube-get2 youtube-viewer peasyfwmon gifondesktop upgrade-kernel conkyclock redshiftgui mpv peasymount peasyscale peasyxorburn peasyglue \n\n *** Choice of Desktop *** \n Default is openbox with pcmanmfm providing the desktop, lxpanel, etc..\n To change, replace what's in the 'Desktop Apps' field with for example: \nmate-core (for MATE), xfce4 (for XFCE), lxde (for LXDE)\n No guarantee that all work as expected, might require some fixing \n\n *** Remove automatically installed packages (checkbox) *** \n During installing all the packages, some are installed that you might not need, e.g.\nxserver-xorg-video-vmware, having the box checked will uninstall it.\n(possibly (large) library libllvm3.9 will then be autoremoved, depending on your other package choices)\n\n *** Locales ***\nTo keep locale files, set to 'KEEP_LOCALES=yes' on top of the script " | yad --margins 7 --window-icon "icons/audio-x-generic.png" --title="Information about Firmware and More" --fontname="MonoSpace Bold 12" --back=#ffffff --height=660 --width=775 --text-info --wrap --button="gtk-close:0"
export -f info
function de_info () {
echo -e "\n *** Extra modules *** \n https://debiandog.github.io/MakeLive/modules/ \n\n *** Config files *** \n https://debiandog.github.io/MakeLive/configs/ \n\n *** Screenshots *** \n https://debiandog.github.io/MakeLive/screenshots/ \n\n *** Thunar without root warning debs (32 bit only) *** \n https://debiandog.github.io/MakeLive/thunar/ \n\n *** Firmware .squashfs module *** \n https://debiandog.github.io/MakeLive/modules/99-firmware-stretch-live.squashfs\n\n *** Info Kiosk *** \n https://debiandog.github.io/MakeLive/configs/Info-Kiosk.txt" | yad --margins 7 --window-icon "icons/audio-x-generic.png" --title="Information" --show-uri --fontname="MonoSpace Bold 12" --back=#ffffff --height=460 --width=775 --text-info --wrap --button="gtk-close:0"
export -f de_info
de_config () {
if [ -z `which yad` ]; then
msg=" You don't have yad installed.\nIt's a dependency of this program.\n Please install it.\n Or run with option: -cli"
echo $msg
exit 0
fi
wget --no-check-certificate -P /tmp/ -r -e robots=off -N -q -nd -l1 -A "*png" https://debiandog.github.io/MakeLive/icons/ 2> /dev/null
LFONT=" *** <span size='large' > <b>Choose Desktop Environment</b> </span> *** "
CHOICE=$(yad --borders=6 --window-icon="gtk-ok" --center --height 650 --width="810" --list --title="Choose Desktop Environment" \
--text=" $LFONT \n Select one of the options and click Ok \n Next you can modify the packages install list, but: \n <b>Note:</b> Recommended to not remove packages, only add packages, specially for the 'Desktop' field \n Click 'Skip' for no preconfigured DE, the standard packages list (openbox) will appear then. " --separator="" \
--column ":IMG" --column Name --column Description \
/tmp/openbox.png "Openbox" " Openbox with pcmanfm (providing the desktop) and lxpanel (standard)" \
/tmp/xfce4.png "Xfce4" " Xfce4 with Whisker Menu" \
/tmp/jwm.png "Jwm" " Jwm preconfigured" \
/tmp/mate.png "Mate" " Mate basic" \
/tmp/lxde.png "LxDD" " LxDog with LXDE environment (32 bit only) by Peebee, many additions and configurations" \
/tmp/fvwm-crystal.png "Fvwm-crystal" " FVWM-Crystal, eye-candy but also powerful desktop environment" \
/tmp/dog.png "DDog" " Full DebianDog Openbox_Xfce-Jwm version" \
/tmp/kiosk.png "Kiosk" " Kiosk version, restricted to browsing the internet only" \
/tmp/obdog.png "ObDog" " Full Dog, openbox with pcmanfm, lxpanel - or Jwm, with firefox" \
/tmp/chrome.png "ChromeDog" " Full Dog, openbox with pcmanfm, lxpanel - or Jwm, with google-chrome (64bit only)" \
--print-column 2 --buttons-layout=spread --button="gtk-info:bash -c de_info" --button="Skip:2" --button="gtk-quit:1" --button="gtk-ok:0")
ret=$?
case $ret in
0)
[ -z "$CHOICE" ] && yad --title="Nothing Selected" --center --text " Please select one of the options " --button="gtk-close:0" && exec $0 -gui
export DE_CONFIG="$CHOICE"
[ "$DE_CONFIG" = "Openbox" ] && wget -P /tmp/ --no-check-certificate https://debiandog.github.io/MakeLive/configs/openbox_lx.conf && config=/tmp/openbox_lx.conf
[ "$DE_CONFIG" = "Xfce4" ] && wget -P /tmp/ --no-check-certificate https://debiandog.github.io/MakeLive/configs/xfce4.conf && config=/tmp/xfce4.conf
[ "$DE_CONFIG" = "Jwm" ] && wget -P /tmp/ --no-check-certificate https://debiandog.github.io/MakeLive/configs/jwm.conf && config=/tmp/jwm.conf
[ "$DE_CONFIG" = "Mate" ] && wget -P /tmp/ --no-check-certificate https://debiandog.github.io/MakeLive/configs/mate.conf && config=/tmp/mate.conf
[ "$DE_CONFIG" = "LxDD" ] && wget -P /tmp/ --no-check-certificate https://debiandog.github.io/MakeLive/configs/lxdd.conf && config=/tmp/lxdd.conf
[ "$DE_CONFIG" = "Fvwm-crystal" ] && wget -P /tmp/ --no-check-certificate https://debiandog.github.io/MakeLive/configs/fvwm-crystal.conf && config=/tmp/fvwm-crystal.conf
[ "$DE_CONFIG" = "DDog" ] && wget -P /tmp/ --no-check-certificate https://debiandog.github.io/MakeLive/configs/ddog.conf && config=/tmp/ddog.conf
[ "$DE_CONFIG" = "Kiosk" ] && wget -P /tmp/ --no-check-certificate https://debiandog.github.io/MakeLive/configs/kiosk.conf && config=/tmp/kiosk.conf
[ "$DE_CONFIG" = "ObDog" ] && wget -P /tmp/ --no-check-certificate https://debiandog.github.io/MakeLive/configs/obdog.conf && config=/tmp/obdog.conf
[ "$DE_CONFIG" = "ChromeDog" ] && wget -P /tmp/ --no-check-certificate https://debiandog.github.io/MakeLive/configs/chromedog.conf && config=/tmp/chromedog.conf
1|252)
exit
2)
echo "Skipping DE configuration"
esac
export -f de_config
de_config_cli () {
echo -e "\e[0;36mChoose Desktop Environment\033[0m"
echo
echo -e "\e[0;36mPlease select one of the options \nNext you can modify the packages install list\033[0m"
echo "1) Openbox, Openbox with pcmanfm (providing the desktop) and lxpanel (standard)"
echo "2) Xfce4, Xfce4 with Whisker Menu"
echo "3) Jwm, Jwm preconfigured"
echo "4) Mate, Mate basic"
echo "5) LxDD, LxDog with LXDE environment (32 bit only) by Peebee, many additions and configurations"
echo "6) Fvwm-crystal, FVWM-Crystal, eye-candy but also powerful desktop environment"
echo "7) DDog, Full DebianDog Openbox_Xfce-Jwm version"
echo "8) Kiosk, Kiosk version, restricted to browsing the internet only"
echo "9) ObDog, Full Dog, openbox with pcmanfm, lxpanel - or Jwm, with firefox"
echo "10) ChromeDog, Full Dog, openbox with pcmanfm, lxpanel - or Jwm, with google-chrome (64bit only)"
echo
echo "0) Skip this step, use default, as defined on top of script (Openbox)"
echo
echo "Type the number and press Enter."
echo
read n
case $n in
1)
DE_CONFIG="Openbox" ;;
2)
DE_CONFIG="Xfce4" ;;
3)
DE_CONFIG="Jwm" ;;
4)
DE_CONFIG="Mate" ;;
5)
DE_CONFIG="LxDD" ;;
6)
DE_CONFIG="Fvwm-crystal" ;;
7)
DE_CONFIG="DDog" ;;
8)
DE_CONFIG="Kiosk" ;;
9)
DE_CONFIG="ObDog" ;;
10)
DE_CONFIG="ChromeDog" ;;
0)
echo "Skipping DE configuration" ;;
esac
export -f de_config_cli
yad_gui () {
if [ "$(uname -m)" = "i686" ]; then
SETUP=`yad --borders=4 --height=680 --width=790 --center --title="MakeLive Stretch" --text="<b> \tCreate a Debian 9 (Stretch) minimal live system similar to 'DebianDog' </b>\n With aufs support and porteus-boot style included\n It's required to have at least 3 GB free space, and to run this script on a Linux filesystem, e.g. ext4 \n Add or remove packages as desired, although be careful with removing too much " \
--window-icon="preferences-system" --form --columns=1 \
--field="Base Install (most are essential, recommended not to remove packages from this list): :TXT" "$BASE_INSTALL" \
--field="Base Dog Packages Install: (recommended to keep: yad gtkdialog obshutdown pup-volume-monitor peasywifi):TXT" "$BASE_DOG_APPS_INSTALL" \
--field="Applications Install::TXT" "$BASE_APPS_INSTALL" \
--field="Desktop :: " "$DESK_APPS_INSTALL" \
--field="Firmware:: " "$FIRMWARE" \
--field="Extra Dog Packages:: " "$EXTRA_DOG_APPS_INSTALL" \
--field="Remove some automatically installed packages (these may take much space, see Information):CHK" "$REM_AUTO_INST" \
--button="gtk-info:bash -c info" --button="gtk-quit:1" --button="gtk-ok:0"`
ret=$?
[ $ret -ne 0 ] && exit
export BASE_INSTALL="`echo $SETUP | cut -d "|" -f 1`"
export BASE_DOG_APPS_INSTALL="`echo $SETUP | cut -d "|" -f 2`"
export BASE_APPS_INSTALL="`echo $SETUP | cut -d "|" -f 3`"
export DESK_APPS_INSTALL="`echo $SETUP | cut -d "|" -f 4`"
export FIRMWARE="`echo $SETUP | cut -d "|" -f 5`"
export EXTRA_DOG_APPS_INSTALL="`echo $SETUP | cut -d "|" -f 6`"
export REM_AUTO_INST="`echo $SETUP | cut -d "|" -f 7`"
export FORCE32="TRUE"
elif [ "$(uname -m)" = "x86_64" ]; then
[ "$FORCE32" = "TRUE" ] && CONF32="Build configuration loaded <b>possibly suitable only for i686</b> (32 bit) uncheck bottom checkbox for a 64-bit build \n"
SETUP=`yad --borders=4 --height=680 --width=790 --center --title="MakeLive Stretch" --text="<b> \tCreate a Debian 9 (Stretch) minimal live system similar to 'DebianDog' </b>\n With aufs support and porteus-boot style included\n $CONF32 It's required to have at least 3 GB free space, and to run this script on a Linux filesystem, e.g. ext4 \n Add or remove packages as desired, although be careful with removing too much " \
--field="Force a 32 bit build (unchecked will build according to host system being 32 or 64 bit):CHK" "$FORCE32" \
ret=$?
export FORCE32="`echo $SETUP | cut -d "|" -f 8`"
fi
# This makes sure when the script is interrupted, that all mount 'binds' will unmount
exitfn () {
trap SIGINT # Resore signal handling for SIGINT
echo -e "\e[0;36mUnmounting mount binds in chroot\033[0m"
#umount -l chroot/tmp
umount -l $LAUNCHDIR/stretch/chroot/proc 2> /dev/null
umount -l $LAUNCHDIR/stretch/chroot/sys 2> /dev/null
umount -l $LAUNCHDIR/stretch/chroot/dev/pts 2> /dev/null
umount -l $LAUNCHDIR/stretch/chroot/dev 2> /dev/null
[ ! -d $LAUNCHDIR/stretch/apt ] && mv -f $LAUNCHDIR/stretch/chroot/var/cache/apt $LAUNCHDIR/stretch/
rm -f $LAUNCHDIR/stretch/apt/archives/lock 2> /dev/null
sleep 2
if mountpoint -q $LAUNCHDIR/stretch/chroot/dev; then # just in case check dev
echo -e "\e[0;31mSomething went wrong, directory chroot cannot be removed\033[0m"
echo -e "\e[0;31mMake sure it's not in use by some process and try again, exiting...\033[0m"
sleep 2
exit
else
rm -rf $LAUNCHDIR/stretch/chroot
fi
exit
export -f exitfn
trap "exitfn" 1 2 3 15 # Set up SIGINT trap to call function 'exitfn'
# OK or FAILED
ok_or_failed () {
[ $? -eq 0 ] && echo -e "\e[0;32mOK\033[0m" || echo -e "\e[0;31mFAILED\033[0m"
export -f ok_or_failed
cr_build_info () {
# Create setup info list build_setup.txt
echo "Live system built on $(uname -m) for $ARCH on $(date)" > build_setup.txt
echo -e "Preinstalled on top of debootstrap build:\nlive-boot wget menu dialog apt-utils dbus ca-certificates apt-transport-https xserver-xorg-legacy\n" >> build_setup.txt
echo -e "Base Install:\n$BASE_INSTALL\n" >> build_setup.txt
echo -e "Base Dog Packages Install:\n$BASE_DOG_APPS_INSTALL\n" >> build_setup.txt
echo -e "Applications Install:\n$BASE_APPS_INSTALL\n" >> build_setup.txt
echo -e "Desktop Environment Packages:\n$DESK_APPS_INSTALL\n" >> build_setup.txt
echo -e "Firmware:\n$FIRMWARE\n" >> build_setup.txt
echo -e "Extra Dog Packages:\n$EXTRA_DOG_APPS_INSTALL\n" >> build_setup.txt
echo -e "Remove xserver-xorg-video-vmware=$REM_AUTO_INST" >> build_setup.txt
# Info architecture for build config
[ "$ARCH" = "i386" ] && INFO_i386="Config generated for $ARCH, FORCE32 is set to TRUE (this way it works also on 64 bit)"
##### Generate config from build #####
echo '# Configuration for mklive-stretch, generated for architecture: '$ARCH', modify as desired
BASE_INSTALL="'"$BASE_INSTALL"'"
BASE_DOG_APPS_INSTALL="'"$BASE_DOG_APPS_INSTALL"'"
BASE_APPS_INSTALL="'"$BASE_APPS_INSTALL"'"
DESK_APPS_INSTALL="'"$DESK_APPS_INSTALL"'"
FIRMWARE="'"$FIRMWARE"'"
EXTRA_DOG_APPS_INSTALL="'"$EXTRA_DOG_APPS_INSTALL"'"
REM_AUTO_INST="'"$REM_AUTO_INST"'"
# '$INFO_i386'
FORCE32="'"$FORCE32"'"
# Locales: To keep locale files, set to KEEP_LOCALES=yes on top of the script' > build_setup.conf
export -f cr_build_info
########################## End functions #####################################
############# Start #############
export LAUNCHDIR="$PWD"
########### Options (GUI or CLI, configuration) ###########
helptext="mklive-stretch\n
usage: $(basename $0) [OPTION] <config_file>\n
Options:\n
-gui ( run GUI, requires yad installed )\n
choice of Desktop Environments (GUI) and packages to install \n
-cli ( commandline only, no GUI )\n
choice of Desktop Environments (CLI) and packages to install \n
-gui <config_file>\n
load custom config file\n
-cli <config_file>\n
load custom config file \n
-conf ( create 'stretchlive.conf' ) \n
create a standard config file in same directory as running this script from\n
( to modify and load as custom configuration )\n
-help show this help\n
Example using custom config file: \n
mklive-stretch -cli mycustom.conf \n"
params=$@
if [ ${#params} -eq 0 ]; then # no options, no text, so print info/help...
echo -e $helptext
exit
fi
arg=$1
config=$2
case $arg in
-gui)
if [ $2 ]; then
. $config
CONFIG="yes"
yad_gui
else
de_config
if [ "$DE_CONFIG" ]; then
. $config
CONFIG="yes"
yad_gui
else
standard # when DE config skipped
yad_gui
fi
fi
-cli)
CLI="yes"
if [ $2 ]; then
. $config
CONFIG="yes"
else
de_config_cli
echo -e "\e[0;36mYou can edit now: \e[1;29m$(readlink -f $config)\e[0;29m (to add packages as desired)\033[0m"
read -sp "When done, press ENTER to continue . . . "
echo
. $config
CONFIG="yes"
else
fi
fi
-conf)
echo -e "\e[0;32mCreating $PWD/stretchlive.conf\033[0m"
create_conf
exit
-help|--help)
echo -e $helptext
exit
echo -e "\e[0;31mNot a valid parameter\033[0m"
echo -e $helptext
exit
esac
# export final variables defined through GUI or CLI (with or without custom config)
export BASE_INSTALL="$BASE_INSTALL"
export BASE_DOG_APPS_INSTALL="$BASE_DOG_APPS_INSTALL"
export BASE_APPS_INSTALL="$BASE_APPS_INSTALL"
export DESK_APPS_INSTALL="$DESK_APPS_INSTALL"
export FIRMWARE="$FIRMWARE"
export EXTRA_DOG_APPS_INSTALL="$EXTRA_DOG_APPS_INSTALL"
export REM_AUTO_INST="$REM_AUTO_INST"
export FORCE32="$FORCE32"
echo
echo -e "\e[0;32mOK, running 32-bit OS, building live system for 32-bit: $(uname -m)\033[0m"
export ARCH="i386"
echo
if [ "$FORCE32" = "TRUE" ]; then
echo -e "\e[0;32mOK, running 64-bit OS, building live system for 32-bit: i686\033[0m"
export ARCH="i386"
else
echo -e "\e[0;32mOK, running 64-bit OS, building live system for 64-bit: $(uname -m)\033[0m"
export ARCH="amd64"
fi
fi
echo -e "\e[0;33mCreate a Debian 9 (Stretch) minimal live system similar to 'DebianDog'\nWith aufs support and porteus-boot style included\n\nIt's required to have at least 3 GB free space\nand to run this script on a Linux filesystem, e.g. ext4\033[0m"
echo -e "\e[0;32mBuilding will be done in: $PWD/stretch\033[0m"
if [ "$CONFIG" = "yes" ]; then
if [ -z "$BASE_INSTALL" ]; then
echo -e "\e[0;31mThis config file cannot be used, sorry, exiting...\033[0m"
exit
else
echo -e "\e[0;36mRunning with configuration: \e[1;29m$(readlink -f $config)\e[0;29m\033[0m"
fi
else
echo -e "\e[0;36mNo custom config in use\033[0m"
echo -e "\e[0;36mUsing standard configuration defined on top of script\033[0m"
fi
echo -e "\e[0;33mBuild setup info can be found in: $PWD/stretch/build_setup.txt\033[0m"
echo -e "\e[0;32mIf you'd like a log from the output, run again e.g:\033[0m"
echo -e "\e[0;33m$0 -gui 2>&1 | tee mklive-stretch.log\033[0m"
echo -e "\e[0;36mFirst setting up debootstrap, this will take a few minutes\nAfter that you will be asked to set the password for 'root'\033[0m"
echo
# read -sp "Press ENTER to continue . . . "
echo -e "\e[0;33mAt the end of the install process you may want to run one or more commands\n (in the chroot) \n If so, Xterm will run and you can type e.g. synaptic, to install more packages\n Or e.g. rox or thunar (filemanager), if installed)\033[0m"
read -p "Do you want to run Xterm just before exiting chroot ? (Enter=no) (y/N)?" choice
case "$choice" in
y|Y)
echo -e "\e[0;36mOK, will run xterm later, at the end of install process\033[0m"
export RUNXTERM=yes
n|N|"")
echo -e "\e[0;36mOK, will not run xterm at the end of install process\033[0m"
esac
echo
sleep 3
exit
else
sleep 1
fi
if [ -d "stretch" ]; then
echo -e "\e[0;33m Working directory 'stretch' already exists \n To be able to continue, contents need to be removed first\n All files inside will be deleted, except the apt cache in chroot\033[0m"
read -p "Are you sure to delete contents of directory stretch ? (Enter=yes) (Y/n)?" choice
case "$choice" in
y|Y|"")
echo -e "\e[0;36mUnmount mount binds and remove stretch/chroot...\033[0m"
umount -l stretch/chroot/proc 2> /dev/null
umount -l stretch/chroot/sys 2> /dev/null
umount -l stretch/chroot/dev/pts 2> /dev/null
umount -l stretch/chroot/dev 2> /dev/null
mv stretch/chroot/var/cache/apt stretch/ 2> /dev/null
if mountpoint -q stretch/chroot/dev; then # just in case check dev
echo -e "\e[0;31mSomething went wrong, directory stretch/chroot cannot be removed\033[0m"
sleep 2
exit
else
rm -rf stretch/chroot
fi
mkdir -p stretch/chroot/var/cache 2> /dev/null
mv stretch/apt stretch/chroot/var/cache/ 2> /dev/null
find stretch -mindepth 1 ! -wholename 'stretch/chroot/*' -delete 2> /dev/null
echo -e "\e[0;32mOK, continue...\033[0m"
n|N)
echo "Exiting..."
sleep 3
exit 0
echo -e "\e[0;31mNot a valid choice, exiting....\033[0m"
sleep 3
exit 0
esac
fi
if [ $(command -v apt-get 2>/dev/null) ];then
echo -e "\e[0;36mUpdate the package lists...\033[0m"
apt-get update
echo -e "\e[0;36mInstall some required packages, e.g. debootstrap, squashfs-tools, etc...\033[0m"
apt-get install debootstrap wget xorriso isolinux xz-utils squashfs-tools cpio -y
ok_or_failed
fi
########## Set up debootstrap ##########
echo -e "\e[0;36mSetting up debootstrap in stretch/chroot\033[0m"
echo -e "\e[0;36mThis may take a while...\033[0m"
mkdir -p stretch/chroot && cd stretch &&
debootstrap --arch=$ARCH --variant=minbase --include=apt-transport-https,ca-certificates stretch chroot http://ftp.us.debian.org/debian/
# create build_info.txt and build_setup.conf
cr_build_info
echo -e "\e[0;36mDownload required archives containing scripts, initrd-skel, etc...\033[0m"
sleep 3
wget --no-check-certificate https://raw.githubusercontent.com/DebianDog/MakeLive/gh-pages/dog-boot-stretch-20180815.tar.gz
wget --no-check-certificate https://raw.githubusercontent.com/DebianDog/MakeLive/gh-pages/initrdport-stretch.tar.gz
wget --no-check-certificate https://raw.githubusercontent.com/DebianDog/MakeLive/gh-pages/isodata-stretch.tar.gz
ok_or_failed
echo -e "\e[0;36mExtracting...\033[0m"
tar -zxf dog-boot-stretch-20180815.tar.gz
tar -zxf isodata-stretch.tar.gz
tar -zxf initrdport-stretch.tar.gz
ok_or_failed
echo -e "\e[0;36mCopy scripts, required for porteus-boot, to the chroot...\033[0m"
cp -af dog-boot-stretch-20180815/* chroot/
ok_or_failed
# mount bind some required directories from host filesystem
mount --bind /proc chroot/proc
#mount --bind /tmp chroot/tmp
mount --bind /dev chroot/dev
mount --bind /sys chroot/sys
mount -t devpts devpts chroot/dev/pts
# provide a network connection in chroot
echo -en "`cat /etc/resolv.conf`" > chroot/etc/resolv.conf
############ Start running in chroot ############
chroot_in () {
if [ -z $(which apt-get) ]; then
echo -e "\e[0;31mSorry, apt-get not found, cannot continue\033[0m"
echo -e "\e[0;36mExiting . . .\033[0m"
touch /exit_
sleep 3
exit
fi
export HOME=/root
export LC_ALL=C
# Google chrome for 64 bit only, so remove on i386
[ "$ARCH" = "i386" ] && rm -f /etc/apt/sources.list.d/google-chrome.list
# Setup install without install recommends
echo "APT::Install-Recommends "false"; APT::Install-Suggests "false";" > /etc/apt/apt.conf
sleep 1
[ "$ARCH" = "i386" ] && sed -i '1 s|^|deb https://fredx181.github.io/StretchDog/i386/Packages/ ./\n|' /etc/apt/sources.list
[ "$ARCH" = "amd64" ] && sed -i '1 s|^|deb https://fredx181.github.io/StretchDog/amd64/Packages/ ./\n|' /etc/apt/sources.list
apt-get update # required, dog repository just added
[ $? -ne 0 ] && apt-get update # try again if failed
echo -e "\e[0;36mPlease set the password for 'root'\033[0m"
echo -e "\e[0;33mAlso now you may want to add to or edit files in the chroot folder\033[0m"
passwd root
if [ $? -ne 0 ]; then # try again if passwords not match
echo -e "\e[0;36mPlease try again, type password for root\033[0m"
passwd root
fi
[ $? -ne 0 ] && echo -e "\e[0;31mWarning: password is not set\033[0m"; sleep 3
echo
# add groups fuse and wheel
addgroup fuse
addgroup wheel
echo
# create user puppy
echo -e "\e[0;36mAdd user 'puppy'...\033[0m"
adduser puppy --gecos ",,," --disabled-password 2> /dev/null
echo
echo -e "\e[0;36mPlease set the password for user 'puppy'\033[0m"
passwd puppy
echo -e "\e[0;36mPlease try again, type password for puppy\033[0m"
passwd puppy
fi
usermod -a -G sudo,cdrom,disk,audio,video,plugdev,fuse,wheel puppy
# configure keyboard first
echo -e "\e[0;36mInstall keyboard-configuration \033[0m"
apt-get install dialog keyboard-configuration --yes
# Merge all install variables into one
INSTALL="$BASE_INSTALL $BASE_APPS_INSTALL $DESK_APPS_INSTALL $BASE_DOG_APPS_INSTALL $EXTRA_DOG_APPS_INSTALL $FIRMWARE"
# check gnome-mplayer and transmission version
if [ "$(echo "$INSTALL" | grep gnome-mplayer)" ]; then
G_MPLAYER=$(echo "$INSTALL" | tr ' ' '\n' | grep "gnome-mplayer")
[ "$ARCH" = "i386" ] && INSTALL="$(echo "$INSTALL" | sed "s/$G_MPLAYER/gnome-mplayer-1.0.7/g")"
[ "$ARCH" = "amd64" ] && INSTALL="$(echo "$INSTALL" | sed "s/$G_MPLAYER/gnome-mplayer-1.0.6/g")"
fi
if [ "$(echo "$INSTALL" | grep transmission)" ]; then
T_MISSION=$(echo "$INSTALL" | tr ' ' '\n' | grep "transmission")
[ "$ARCH" = "i386" ] && INSTALL="$(echo "$INSTALL" | sed "s/$T_MISSION/transmission-2.31/g")"
[ "$ARCH" = "amd64" ] && INSTALL="$(echo "$INSTALL" | sed "s/$T_MISSION/transmission-2.60/g")"
fi
# simulate install first to check for errors, if there are, exit
echo -e "\e[0;36mChecking packages . . .\033[0m"
sleep 3
apt-get install -s -y $INSTALL
ret=$?
if [ $ret -eq 100 ]; then
echo -e "\e[0;31mSorry, there are one or more errors, see above.\033[0m"
echo -e "\e[0;31mCould be a typo in a package name.\033[0m"
touch /exit_
sleep 3
exit
else
echo -e "\e[0;32mAll packages checked OK, continue now to install some basic packages... \033[0m"
sleep 3
fi
# Install some basic packages (do not edit, essential!)
apt-get install live-boot wget menu dbus apt-utils xserver-xorg-legacy gnupg --yes
touch /exit_
exit
fi
fi
dbus-uuidgen > /var/lib/dbus/machine-id
echo "live" > /etc/hostname
echo "127.0.0.1 localhost" > /etc/hosts
echo "127.0.1.1 live" >> /etc/hosts
mkdir /live
mkdir -p /opt/bin
update-rc.d snapexit defaults
# make /bin/sh symlink to bash instead of dash:
echo -e "\e[0;36mmake /bin/sh symlink to bash instead of default dash\033[0m"
echo "dash dash/sh boolean false" | debconf-set-selections
DEBIAN_FRONTEND=noninteractive dpkg-reconfigure dash
############ Start installing packages ############
### First install the kernel
if [ "$ARCH" = "i386" ]; then
echo -e "\e[0;36mInstall linux-image-4.9.0-7-686-pae\033[0m"
sleep 3
apt-get install --yes linux-image-4.9.0-7-686-pae
touch /exit_
exit
fi
fi
elif [ "$ARCH" = "amd64" ]; then
# Add google signing key
wget -q -O - https://dl.google.com/linux/linux_signing_key.pub | apt-key add -
apt-get update # required, google repository key just added to sources.list
echo
echo -e "\e[0;36mInstall linux-image-4.9.0-7-amd64\033[0m"
sleep 3
apt-get install --yes linux-image-4.9.0-7-amd64
touch /exit_
exit
fi
fi
fi
### End installing kernel
# check kernel version just installed in chroot, output of VERNEWKERNEL will be used later
VERNEWKERNEL=$(grep " install " /var/log/dpkg.log | sort -r | cut -d " " -sf4 | grep -o "^[^:]*" | grep linux-image | head -n 1 | sed -e 's/linux-image-//')
####### Start installing packages, defined on GUI #######
echo -e "\e[0;36mInstall packages, as defined in configuration\033[0m"
sleep 3
# If one of the variables is empty, it will be skipped
### Do the real installing
apt-get install -y $INSTALL
touch /exit_
exit
fi
fi
############ End of installing packages ############
echo -e "\e[0;36mCopy aufs and squashfs (LZ4 support) module\033[0m"
sleep 3
if [ "$NOPAE" = "yes" ]; then
mv -f /lib/aufs-nopae /lib/modules/$VERNEWKERNEL/kernel/fs/aufs
rm -rf /lib/aufs64
rm -rf /lib/aufs32
mv -f /lib/squashfs-nopae/* /lib/modules/$VERNEWKERNEL/kernel/fs/squashfs/
rm -rf /lib/squashfs32
rm -rf /lib/squashfs-nopae
rm -rf /lib/squashfs64
depmod $VERNEWKERNEL
else
mv -f /lib/aufs32 /lib/modules/$VERNEWKERNEL/kernel/fs/aufs
rm -rf /lib/aufs64
rm -rf /lib/aufs-nopae
mv -f /lib/squashfs32/* /lib/modules/$VERNEWKERNEL/kernel/fs/squashfs/
fi
mv -f /lib/aufs64 /lib/modules/$VERNEWKERNEL/kernel/fs/aufs
rm -rf /lib/aufs32
mv -f /lib/squashfs64/* /lib/modules/$VERNEWKERNEL/kernel/fs/squashfs/
fi
# Pin the kernel version
echo "Adding new entry (pin) of package linux-image-$VERNEWKERNEL in preferences files..."
VERSION=$(dpkg -s linux-image-$VERNEWKERNEL | grep "Version:" | awk '{ print $2 }')
echo '
Package: linux-image-'$VERNEWKERNEL'
Pin: version '$VERSION'
Pin-Priority: 1001
' >> /etc/apt/preferences
echo '
Pin-Priority: 1001
' >> /var/lib/synaptic/preferences
echo "Fixing preferences files... (e.g. remove first empty line(s) )"
# no empty lines allowed at top of preferences files, delete them
sed -i '/./,$!d' /etc/apt/preferences
sed -i '/./,$!d' /var/lib/synaptic/preferences
# replace multiple empty lines by one
sed -i '/^$/N;/^\n$/D' /etc/apt/preferences
sed -i '/^$/N;/^\n$/D' /var/lib/synaptic/preferences
mkdir -p /etc/systemd/network 2> /dev/null # might not exist
ln -s /dev/null /etc/systemd/network/99-default.link # traditional network interface names
# create new initrd with aufs and new squashfs (lz4) included
CRYPTSETUP=Y update-initramfs -t -c -k $VERNEWKERNEL
##### Extra apt-get remove #####
# Remove xserver-xorg-video-vmware ?
# Takes a lot of space due to (large) dependency libllvm3.9 package
if [ "$REM_AUTO_INST" = "TRUE" ]; then
echo -e "\e[0;36mAs requested, remove xserver-xorg-video-vmware\033[0m"
apt-get purge -y xserver-xorg-video-vmware
fi
### Uninstall gnome-icon-theme
GNOME_ICON=$(apt-cache rdepends --installed gnome-icon-theme | grep -v "gnome-icon-theme\|Reverse Depends" | grep -v "|") # check for reverse dependencies, remove only if none
[ -z "$GNOME_ICON" ] && apt-get purge --yes gnome-icon-theme # in case installed
# if "xserver-xorg-input-evdev" is installed:
# apt-get purge --yes xserver-xorg-input-libinput # uncomment if lxinput doesn't work
apt-get --yes autoremove
mv -f /usr/local/XTerm /etc/X11/app-defaults/
if [ "$RUNXTERM" = "yes" ]; then
echo -e "\e[0;36mAs requested, running Xterm now\nDo not forget to close Xterm and all other windows, when done\033[0m"
xterm
fi
echo "Cleaning..."
rm -f var/lib/alsa/asound.state
rm -f root/.bash_history
rm -f root/.xsession-errors
rm -rf root/.cache
rm -rf root/.thumbnails
rm -f etc/blkid-cache
rm -f var/lib/dhcp/dhclient.eth0.leases
rm -f var/lib/dhcpcd/*.lease
rm -rf lib/consolefonts
rm -rf lib/keymaps
rm -fr var/lib/aptitude/*
ls var/lib/apt/lists | grep -v "lock" | grep -v "partial" | xargs -i rm var/lib/apt/lists/{} ;
rm -f var/cache/debconf/*-old
rm -f var/lib/dpkg/*-old
find /usr/share/doc -type f -exec rm -f {} 2> /dev/null \;
find usr/share/man -type f -exec rm -f {} 2> /dev/null \;
find usr/share/gtk-doc -type f -exec rm -f {} 2> /dev/null \;
find usr/share/info -type f -exec rm -f {} 2> /dev/null \;
chown -R man:root usr/share/man
rm -f vmlinuz* initrd* # remove symlinks on /
[ "$KEEP_LOCALES" = "no" ] && rm -fr usr/share/locale/*
rm -f /var/lib/dbus/machine-id
#apt-get clean
rm -rf /tmp/*
rm /etc/resolv.conf
export -f chroot_in
if [ "$(which chroot)" = "/bin/chroot" ]; then
CHROOT="/usr/sbin/chroot"
else
CHROOT="chroot"
fi
$CHROOT chroot /bin/bash -c chroot_in
# do not continue if there were errors
[ -f "chroot/exit_" ] && exitfn
############ End running in chroot #############
umount -l chroot/proc
umount -l chroot/dev/pts
umount -l chroot/sys
echo -e "\e[0;36mStart extracting and creating new 'live' initrd files...\033[0m"
sleep 3
mkdir initrdlive
mv -f chroot/boot/initrd.img-* initrdlive/initrd.img
ok_or_failed
cd initrdlive
zcat initrd.img | cpio -i -d
rm -f initrd.img
echo -e "\e[0;36mCreating initrd.img, please wait...\033[0m"
find . -print | cpio -o -H newc 2>/dev/null | xz -f --extreme --check=crc32 > ../initrd.img
ok_or_failed
cd ..
echo -e "\e[0;36mCopy kernel modules, contents of lib/modules, from extracted 'live-boot' initrd\n to extracted 'porteus-boot' initrd skeleton, initrdport/lib/modules/ ...\033[0m"
sleep 2
cp -a initrdlive/lib/modules/* initrdport/lib/modules/
ok_or_failed
echo -e "\e[0;36mCreating initrd1.xz, please wait...\033[0m"
cd initrdport
find . -print | cpio -o -H newc 2>/dev/null | xz -f --extreme --check=crc32 > ../initrd1.xz
ok_or_failed
cd ..
echo -e "\e[0;36mCopy initrd.img, initrd1.xz to isodata/live...\033[0m"
mv -f initrd.img isodata/live/
mv -f initrd1.xz isodata/live/
ok_or_failed
echo -e "\e[0;36mMove vmlinuz, from chroot/boot/, to isodata/live/vmlinuz1 ...\033[0m"
mv -f chroot/boot/vmlinuz-* isodata/live/vmlinuz1
ok_or_failed
rm -f chroot/boot/System.map*
rm -f isodata/live/01-filesystem.squashfs # just in case it exists remove first
# copy build_setup.txt to chroot/root
cp -a build_setup.txt chroot/root/
rm -f chroot/var/cache/apt/*.bin
mkdir -p apt/archives
mv -f chroot/var/cache/apt/archives/*.deb ./apt/archives/
if [ "$(cat chroot/etc/X11/default-display-manager 2> /dev/null)" ]; then
echo -e "\e[0;36mIt looks like you have a display-manager installed\033[0m"
echo -e "\e[0;36mThis probably will conflict with the default login method (through /etc/inittab)\033[0m"
cp -af chroot/etc/inittab-noauto chroot/etc/inittab
echo -e "\e[0;32mDisabled autologin through /etc/inittab, using display-manager for login\033[0m"
sleep 3
fi
# Download extra squashfs modules if DE config is set
echo -e "\e[0;36mIf configured, download extra .squashfs modules to isodata/live...\033[0m"
[ "$DE_CONFIG" = "Openbox" ] && wget --no-check-certificate -P isodata/live -r -e robots=off -nd -l1 -A "*squashfs" https://debiandog.github.io/MakeLive/modules/openbox/ 2> /dev/null
[ "$DE_CONFIG" = "Xfce4" ] && wget --no-check-certificate -P isodata/live -r -e robots=off -nd -l1 -A "*squashfs" https://debiandog.github.io/MakeLive/modules/xfce4/
[ "$DE_CONFIG" = "Jwm" ] && wget --no-check-certificate -P isodata/live -r -e robots=off -nd -l1 -A "*squashfs" https://debiandog.github.io/MakeLive/modules/jwm/ 2> /dev/null
[ "$DE_CONFIG" = "Mate" ] && wget --no-check-certificate -P isodata/live -r -e robots=off -nd -l1 -A "*squashfs" https://debiandog.github.io/MakeLive/modules/mate/
[ "$DE_CONFIG" = "LxDD" ] && wget --no-check-certificate -P isodata/live -r -e robots=off -nd -l1 -A "*squashfs" https://debiandog.github.io/MakeLive/modules/lxdd/
[ "$DE_CONFIG" = "Fvwm-crystal" ] && wget --no-check-certificate -P isodata/live -r -e robots=off -nd -l1 -A "*squashfs" https://debiandog.github.io/MakeLive/modules/fvwm-crystal/
if [ "$DE_CONFIG" = "DDog" ]; then
[ "$ARCH" = "i386" ] && wget --no-check-certificate -P isodata/live "https://debiandog.github.io/MakeLive/modules/ddog/zz_openbox_xfce-jwm_32.squashfs"
[ "$ARCH" = "amd64" ] && wget --no-check-certificate -P isodata/live "https://debiandog.github.io/MakeLive/modules/ddog/zz_openbox_xfce-jwm_64.squashfs"
fi
[ "$DE_CONFIG" = "Kiosk" ] && wget --no-check-certificate -P isodata/live -r -e robots=off -nd -l1 -A "*squashfs" https://debiandog.github.io/MakeLive/modules/kiosk/
[ "$DE_CONFIG" = "ObDog" ] && wget --no-check-certificate -P isodata/live -r -e robots=off -nd -l1 -A "*squashfs" https://debiandog.github.io/MakeLive/modules/obdog/
[ "$DE_CONFIG" = "ChromeDog" ] && wget --no-check-certificate -P isodata/live -r -e robots=off -nd -l1 -A "*squashfs" https://debiandog.github.io/MakeLive/modules/chromedog/
# Allow the user to makes changes in chroot just before creating filesystem.squashfs
echo "At this point you may want to add/edit files in chroot folder"
echo "Also you can add .squashfs modules in the isodata/live folder, to be included in the ISO"
echo
echo -e "\e[0;33mNow we will create compressed filesystem: '01-filesystem.squashfs'\nPlease enter your choice, xz compression will give smaller size than gzip,\033[0m"
echo -e "\e[0;33mbut xz takes much longer time to compress\033[0m"
read -p "Type gzip or xz : " choice
case "$choice" in
gzip)
echo -e "\e[0;36mCreating isodata/live/01-filesystem.squashfs...\033[0m"
mksquashfs chroot isodata/live/01-filesystem.squashfs
xz)
mksquashfs chroot isodata/live/01-filesystem.squashfs -comp xz -b 512k
echo -e "\e[0;31mNot a valid choice, please try again, type: gzip or xz \033[0m"
sleep 1
TRYAGAIN=yes
esac
if [ "$TRYAGAIN" = "yes" ]; then
### Second chance in case having made a typo
case "$choice" in
gzip)
xz)
mksquashfs chroot isodata/live/01-filesystem.squashfs -comp xz -b 512k -Xbcj x86
echo -e "\e[0;31mNot a valid choice, exiting now... \033[0m"
sleep 1
exit 0
esac
fi
ok_or_failed
echo
# Move back the cache to chroot
mv -f ./apt/archives/*.deb chroot/var/cache/apt/archives/ 2> /dev/null
rm -rf apt 2> /dev/null
echo -e "\e[0;36mFinally creating ISO...\033[0m"
NEWISO=$PWD/isodata
LABEL=deblive
NAME=../DebLive_Stretch-$ARCH.iso
cd "$NEWISO"
xorriso -as mkisofs -r -J -joliet-long -l -isohybrid-mbr /usr/lib/ISOLINUX/isohdpfx.bin -partition_offset 16 -V "$LABEL" -b isolinux/isolinux.bin -c isolinux/boot.cat -no-emul-boot -boot-load-size 4 -boot-info-table -o ${NAME} "$NEWISO"
ok_or_failed
cd ..
echo
echo -e "\e[0;32mFinished! If all went well, DebLive_Stretch-$ARCH.iso has been created. \nAlso the required files for a frugal install are in isodata 'live' folder \n\nHave a good day!\033[0m"
echo
# read -s -n 1 -p "Press any key to close . . ."
exit 0
