text replacement help
#1 Post by dolphin_oracle »
in a bash script I need to replace 2 words in a string with new words. I know one of the words, and the other follows. For instance
xserver_arguments -dpi 120 -nolisten tcp
needs replaced so that the 120 is something else. the -dpi is the parameter to change.
Order is not ensured, nor is the presence at all.. however, I can test for the presence of the parameter ahead of time, so I can append or replace as needed.
any help is appreciated. this will fix a bug in an antiX settings app.
TIA
d.o.
Re: text replacement help
#2 Post by Adrian »
Not a sed master by any measure, would this work?
sed -i  's/-dpi [^ ]*/-dpi 200/' filename
That should replace "-dpi xxx" with "-dpi 200"
Try different version of the string here https://regexr.com/ (use only the first part of the sed expression to see what it matches)
#3 Post by dolphin_oracle »
ah, looks promising, thanks!
*edit* yep, that does the trick
