[SOLVED & FASCINATING] SWAP - does it really?
Hello, Any...
Something I have wanted to know for a long, long time but never got around to asking.
Why does my SWAP file always show 0 (zero) usage? To my recollection it has never changed. Is it because modern memory is huge and "swapping" becomes unnecessary - or what?
Simple answer good. Any further depth of explanation would be good too - because it has been a real puzzle to me.
Regards,
boombaby
_
- chrispop99
- Global Moderator
Re: SWAP - does it really?
It obviously does depend on the amount of RAM you have, and also how you use your machine. If you have multiple browser tabs open, then do something intensive like rendering video, you might run into swap. I have 8GB on my everyday machine, and swap has never been used.
If you use Hibernate, you need an appropriately sized swap, but otherwise, given sufficient RAM for your use case, it is possible to run without it.
DELL XPS 15
Lots of test machines
DELL XPS 15
- Eadwine Rose
- Administrator
My swap got used when one of the two ram banks (also 8G total) didn't sit properly after opening the case. Didn't notice a thing at first.. but saw the bar go up.. HUH?? and then saw it didn't see the second one, so.. back to reopen that case and reseat both of them. Prob solved. :)
MX-23.2_x64 July 31 2023 * 6.1.0-18-amd64 ext4 Xfce 4.18.1 * 8core AMD Ryzen 7 2700
@boombaby wrote:
http://forum.mxlinux.org/viewtopic.php? ... 87#p459661
Maybe this will clarify your situation, it's in Spanish but it's easy to understand or you can use the Google translator.Why does my SWAP file always show 0 (zero) usage? To my recollection it has never changed. Is it because modern memory is huge and "swapping" becomes unnecessary - or what?
If you can see the swap item (see below) then your swap is really and ready to be used if needed.
cat /proc/swaps
Filename Type Size Used Priority
/dev/sdax partition 9215996 0 -2
#or
free
total used free shared buff/cache available
Mem: 6033128 1491116 3391056 7932 1150956 4369596
Swap: 9215996 0 9215996
Thanks to each. Fascinating!
Re: [SOLVED & FASCINATING] SWAP - does it really?
I can easily get my 16 GB machine to run out of RAM and start using swap by trying to compile a 64-bit and 32-bit version of Thunderbird or Pale Moon at the same time and letting them use all 12 available threads...so I do them one at a time.
... With your swappiness by default (60) or or already optimized ?
cat /proc/sys/vm/swappiness #60 by default
10 #optimized for desktop standard value
cat /proc/sys/vm/vfs_cache_pressure #100 par defaut
50 #optimized for desktop
