Thunderbird stopped working after latest updates
grasshopper
#1 Post by grasshopper »
Did nothing but run the latest updates and now Thunderbird won't load..it shows one screen, drawn..but blank.. then hangs.
Wow. buggy software. what's the fix?
LnMau05R
Re: Thunderbird stopped working after latest updates
#2 Post by LnMau05R »
What is the output if Thunderbird started from the terminal?
grasshopper
#3 Post by grasshopper »
Sadly I have to type this in by hand...
[calBackendLoader] Using Thunderbird's builtin libical backend.... and that's 100% of it.
#4 Post by Jerry3904 »
That's weird. Couple of suggestions:
1)Log out and back in, then try again
2) Right-click the Updater icon > History, and copy/paste here what was in that update.
3) Give us the output of this command as regular user
apt policy thunderbird
#5 Post by fehlix »
grasshopper wrote: Tue Aug 21, 2018 11:14 pm ...run the latest updates and now Thunderbird won't load
Show us the output of the following commands from the terminal command line as normal user.
Do copy/paste the command into the terminal commandline
and copy/paste the text output and post here between [code] the code-tags here [/code].
System Info:
inxi -Fxzr
thunderbird installed version:
--fehlix
#6 Post by Stevo »
I don't think we've done any Thunderbird updates for at least a month. If Debian doesn't add the required cargo package to Stretch, and update rustc for 32-bit, we won't be able to build the new 60.X versions from source, either. There has been some chatter about that happening to enable firefox-esr 60 builds by September, but no progress lately.
