system upgrades changed my fonts without my approval [solved]
lonesomepoint
#1 Post by lonesomepoint »
This question may or may not have anything to do with MX, since I'm not sure why the problem occurred. I installed the accumulated system upgrades, and one of them changed my usual MX font (whatever it's called--I had little reason to check, since it never changed) to...screenshot attached. I don't like the new font. What application do I have to run to change it back? I don't know, I haven't tried playing with system fonts in living memory.
(P.S. No, I'm not in a liveCD environment, ref. the icon in the screenshot. I just have one in the drive.)
Last edited by lonesomepoint on Sat Jul 21, 2018 10:29 pm, edited 1 time in total.
MarkG
Re: system upgrades changed my fonts without my approval
#2 Post by MarkG »
You'r lucky, I have programs that nolonger work, last update audio stopped wotking, then another update and audio worked, another update (just the other day) audio gone again.
skidoo
#3 Post by skidoo »
lonesomepoint, an exact answer is provided in the MX Users Manual (Section 3.3.3)
#4 Post by asqwerth »
Have you rebooted?
#5 Post by Stevo »
The default font we use is Noto Sans at 10.5 pts.
#6 Post by timkb4cq »
The only font related update I can see in the last month was to fontconfig and it's associated packages libfontconfig1 & fontconfig-config.
This should not have made a major difference in your fonts - but you can roll back to the debian version using:
sudo apt-get install fontconfig=2.11.0-6.7+b1 libfontconfig1=2.11.0-6.7+b1 fontconfig-config=2.11.0-6.7
If that fixes your issue then you should pin those packages so they don't update.
#7 Post by fehlix »
lonesomepoint wrote: Sat Jul 21, 2018 12:04 pm What application do I have to run to change it back?
Settings-> Appearance or just start on the CLI or command prompt ( Alt+F2 )
xfce4-appearance-settings
And change back the default font to "Noto Sans" Size 10.5
lonesomepoint
#8 Post by lonesomepoint »
asqwerth wrote: Sat Jul 21, 2018 1:17 pm Have you rebooted?
Done. That erased the change. I didn't think that would work, and am embarrassed that I didn't try.
