MX Package Installer and Debian 4.9.0-7-amd64 kernel
ChrisUK
Qualified MX Guide
#1 Post by ChrisUK »
Just for information:
From memory, other kernels installed via MXPI, also setup VirtualBox drivers etc - I just installed the aforementioned kernel using MXPI, and needed to set up VirtualBox, as no access to shared folders on host. It's not a problem, as it's just a matter of typing
sudo /sbin/vboxconfig
in the terminal, but I figured newbies might be a bit wary of doing it manually.
MX 18 MX 19 - Manjaro
Re: MX Package Installer and Debian 4.9.0-7-amd64 kernel
#2 Post by dolphin_oracle »
Thanks. This hasn't been a problem for debians main kernel in the past but maybe it's safer to setup the same autorebuild for it.
#3 Post by Stevo »
Users that installed the MX or Debian VBox packages* can also run
sudo dpkg-reconfigure virtualbox-dkms
to make sure the kernel modules are built. There are some reports on the Debian forums that the Nvidia DKMS driver also wasn't rebuilt during the kernel update, leaving some users staring at the dreaded black screen.
* which is what the MX Package installer provides.
#4 Post by dolphin_oracle »
i''m updating mx-pi's lists to force rebuild of dkms packages for all kernel options
users can also run this command manually
/usr/share/mx-packageinstaller-pkglist/rebuild_dkms_packages.sh
ChrisUK
Qualified MX Guide
#5 Post by ChrisUK »
You both deciphered my gibberish ;)
I've just noticed that I described the problem, but the wrong symptom. The shared folder access was due to me updating to the latest firejail... I hadn't deleted the link to Virtualbox in /usr/local/bin/. The symptom was no access to VMs, which you've now fixed for future upgrades with the rebuild (Maybe worth adding a link to the rebuild script or the one-liner in MX Tweak? Just in case a user breaks any manual kernel installs.)
Richard
#6 Post by Richard »
Well the first command didn't work.
$ sudo dpkg-reconfigure virtualbox-dkms
Deleting module version: 5.2.10
completely from the DKMS tree.
Done.
Loading new virtualbox-5.2.10 DKMS files...
Building for 4.17.0-1-amd64
Building initial module for 4.17.0-1-amd64
Error! Bad return status for module build on kernel: 4.17.0-1-amd64 (x86_64)
Consult /var/lib/dkms/virtualbox/5.2.10/build/make.log for more information.
[ ok ] Unloading VirtualBox kernel modules....
[FAIL] Loading VirtualBox kernel modules...[....] No suitable module for running kernel found ... failed!
 failed!
invoke-rc.d: initscript virtualbox, action "restart" failed.
richard@T430:/media
Richard
#7 Post by Richard »
... and the second seems to have failed also:
$ sudo /usr/share/mx-packageinstaller-pkglist/rebuild_dkms_packages.sh
-------- Uninstall Beginning --------
Module:  broadcom-sta
Version: 6.30.223.271
Kernel:  4.15.0-1-amd64 (x86_64)
Status: Before uninstall, this module version was ACTIVE on this kernel.
wl.ko:
 - Uninstallation
   - Deleting from: /lib/modules/4.15.0-1-amd64/updates/dkms/
 - Original module
   - No original module was found for this module on this kernel.
   - Use the dkms install command to reinstall any previous module version.
depmod...
Backing up initrd.img-4.15.0-1-amd64 to /boot/initrd.img-4.15.0-1-amd64.old-dkms
Making new initrd.img-4.15.0-1-amd64
(If next boot fails, revert to initrd.img-4.15.0-1-amd64.old-dkms image)
update-initramfs......
DKMS: uninstall completed.
Kernel:  4.17.0-1-amd64 (x86_64)
wl.ko:
 - Uninstallation
   - Deleting from: /lib/modules/4.17.0-1-amd64/updates/dkms/
 - Original module
depmod...
Backing up initrd.img-4.17.0-1-amd64 to /boot/initrd.img-4.17.0-1-amd64.old-dkms
Making new initrd.img-4.17.0-1-amd64
(If next boot fails, revert to initrd.img-4.17.0-1-amd64.old-dkms image)
Deleting module version: 6.30.223.271
Done.
Loading new broadcom-sta-6.30.223.271 DKMS files...
Done.
wl:
Running module version sanity check.
 - Original module
   - No original module exists within this kernel
 - Installation
   - Installing to /lib/modules/4.17.0-1-amd64/updates/dkms/
depmod...
DKMS: install completed.
Module:  ndiswrapper
Version: 1.61
ndiswrapper.ko:
 - Uninstallation
 - Original module
depmod...
Module:  ndiswrapper
Version: 1.61
ndiswrapper.ko:
 - Uninstallation
 - Original module
depmod...
Deleting module version: 1.61
Done.
Loading new ndiswrapper-1.61 DKMS files...
Done.
ndiswrapper:
 - Original module
 - Installation
depmod...
Done.
Module:  virtualbox-guest
Version: 5.2.10
vboxguest.ko:
 - Uninstallation
 - Original module
vboxsf.ko:
 - Uninstallation
 - Original module
vboxvideo.ko:
 - Uninstallation
 - Original module
depmod...
Done.
Loading new virtualbox-guest-5.2.10 DKMS files...
Consult /var/lib/dkms/virtualbox-guest/5.2.10/build/make.log for more information.
richard@T430:/media
Richard
#8 Post by Richard »
With the same Vbox error:
Kernel driver not installed (rc=-1908)
The VirtualBox Linux kernel driver (vboxdrv) is either not loaded or there is a permission problem with /dev/vboxdrv. Please reinstall virtualbox-dkms package and load the kernel module by executing
'modprobe vboxdrv'
as root.
where: suplibOsInit what: 3 VERR_VM_DRIVER_NOT_INSTALLED (-1908) - The support driver is not installed. On linux, open returned ENOENT.
Richard
#9 Post by Richard »
So, back to the old tried and true method:
Thanks to Stevo.
Set up VBox for new kernel as follows:
;; boot the new kernel
;; activate mx test repo (MX Repo Manager is quick)
;; in a terminal, as root:
# apt-get update
# m-a prepare
# apt-get remove virtualbox-dkms
# apt-get install virtualbox-dkms
# modprobe vboxdrv
;; if no error, de-activate mx testrepo
;; execute Virtualbox
and Vbox is running with Win7.
kmathern
#10 Post by kmathern »
Richard wrote: Fri Jul 20, 2018 9:04 pm Well the first command didn't work.
Done.
Error! Bad return status for module build on kernel: 4.17.0-1-amd64 (x86_64) ...
I think you need a newer vbox version than 5.2.10 for a 4.17 series kernel.
A patch for 4.17 kernels was added in vbox version 5.2.12, and 5.2.16 is available in the MX-17 testrepo.
virtualbox (5.2.12-dfsg-3) unstable; urgency=medium
  * debian/patches/fixes_for_4.17.patch
    from opensuse: fix build with kernel 4.17 (LP: #1776671)
 -- Gianfranco Costamagna <locutusofborg@debian.org>  Thu, 14 Jun 2018 10:09:21 +0200
edit: nevermind, I see you installed the testrepo version.
