removal virtualbox 32 bit
I would like to know if virtuabox can be removed from 32 bit instaliations.Many distros don't support 32 anymore so I don't see the need of 32 bit virtualbox?.thanks john
Re: removal virtualbox 32 bit
Only the guest additions are presinstalled, which are still required.for.the 32 bit.guest system to work with all the vb features like folder sharing and matching the display resolution to the vb window size.
It can be safely removed at anytime.
thanks for reply .john
