inxi -F
System: Host: HP-DV7 Kernel: 4.13.0-1-amd64 x86_64 bits: 64 Desktop: Xfce 4.12.3
Distro: MX-17.1_x64 Horizon December 10, 2017
Machine: Type: Laptop System: Hewlett-Packard product: HP Pavilion dv7 Notebook PC
v: 058B110000242B10000020100 serial: <root required>
Mobo: Hewlett-Packard model: 1443 v: 67.33 serial: <root required>
BIOS: Hewlett-Packard v: F.28 date: 04/11/2011
Battery: ID-1: BAT0 charge: 63.6 Wh condition: 81.3/81.3 Wh (100%)
CPU: Topology: Triple Core model: AMD Phenom II N850 bits: 64 type: MCP L2 cache: 1536 KiB
Speed: 800 MHz min/max: 800/2200 MHz Core speeds (MHz): 1: 800 2: 800 3: 800
Graphics: Card-1: AMD RS880M [Mobility Radeon HD 4225/4250] driver: radeon v: kernel
Card-2: AMD Park [Mobility Radeon HD 5430/5450/5470] driver: radeon v: kernel
Display: x11 server: X.Org 1.19.2 driver: ati,radeon unloaded: fbdev,modesetting,vesa
resolution: 1600x900~60Hz
OpenGL: renderer: Gallium 0.4 on AMD RS880 (DRM 2.50.0 / 4.13.0-1-amd64 LLVM 3.9.1)
v: 3.3 Mesa 13.0.6
Audio: Card-1: AMD SBx00 Azalia driver: snd_hda_intel
Card-2: AMD Cedar HDMI Audio [Radeon HD 5400/6300/7300 Series] driver: snd_hda_intel
Sound Server: ALSA v: k4.13.0-1-amd64
Network: Card-1: Broadcom Limited BCM4313 802.11bgn Wireless Network Adapter driver: wl
IF: wlan0 state: dormant mac: 3e:3f:b2:d8:ed:28
Card-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet driver: r8169
IF: eth0 state: up speed: 1000 Mbps duplex: full mac: 60:eb:69:53:d0:f9
Drives: HDD Total Size: 596.17 GiB used: 5.89 GiB (1.0%)
ID-1: /dev/sda vendor: Seagate model: ST9640320AS size: 596.17 GiB
Partition: ID-1: / size: 81.65 GiB used: 5.52 GiB (6.8%) fs: ext4 dev: /dev/sda1
ID-2: /home size: 501.64 GiB used: 383.9 MiB (0.1%) fs: ext4 dev: /dev/sda3
ID-3: swap-1 size: 2.05 GiB used: 1.5 MiB (0.1%) fs: swap dev: /dev/sda2
Sensors: System Temperatures: cpu: 60.2 C mobo: N/A gpu: radeon temp: 56 C
Info: Processes: 174 Uptime: 2h 05m Memory: 3.61 GiB used: 1.29 GiB (35.7%) Shell: bash
inxi: 3.0.10
ifconfig sees the wlan0.
Thanks
Scott
