Laptop Freezes
Laptop Freezes
Hi
Me again - I hope I am still welcome.
Today the poor laptop kept freezing. When checking the syslog in var I saw the following
Apr 10 22:08:08 x220 kernel: [ 212.739856] [drm] GPU HANG: ecode 60x00000000, reason: Kicking stuck semaphore on rcs0, action: continue
Apr 10 22:09:01 x220 CRON[5028]: (root) CMD ( [ -x /usr/lib/php/sessionclean ] && if [ ! -d /run/systemd/system ]; then /usr/lib/php/sessionclean; fi)
Apr 10 22:10:49 x220 kernel: [ 373.327864] thinkpad_acpi: EC reports that Thermal Table has changed
Apr 10 22:16:12 x220 ntpd[2482]: 195.219.205.9 local addr 192.168.0.11 -> <null>
Apr 10 22:17:01 x220 CRON[6966]: (root) CMD ( cd / && run-parts --report /etc/cron.hourly)
Apr 10 22:39:01 x220 CRON[11223]: (root) CMD ( [ -x /usr/lib/php/sessionclean ] && if [ ! -d /run/systemd/system ]; then /usr/lib/php/sessionclean; fi)
Apr 10 22:54:07 x220 wpa_supplicant[3025]: wlan0: WPA: Group rekeying completed with 40:0d:10:48:c6:67 [GTK=TKIP]
Apr 10 22:55:54 x220 assert_20180410225553_27.dmp[14492]: Uploading dump (out-of-process)#012/tmp/dumps/assert_20180410225553_27.dmp
Apr 10 22:55:55 x220 assert_20180410225553_27.dmp[14492]: Finished uploading minidump (out-of-process): success = yes
Apr 10 22:55:55 x220 assert_20180410225553_27.dmp[14492]: response: CrashID=bp-aacc82e2-fcfd-4deb-bf1a-73bf62180410
Apr 10 22:55:55 x220 assert_20180410225553_27.dmp[14492]: file ''/tmp/dumps/assert_20180410225553_27.dmp'', upload yes: ''CrashID=bp-aacc82e2-fcfd-4deb-bf1a-73bf62180410''
Apr 10 23:04:46 x220 nagios: Auto-save of retention data completed successfully.
Apr 10 23:09:01 x220 CRON[16983]: (root) CMD ( [ -x /usr/lib/php/sessionclean ] && if [ ! -d /run/systemd/system ]; then /usr/lib/php/sessionclean; fi)
My assumption was that the laptop was too hot, but i'm not sure as the log reports a GPU HANG, but then reports a thermal table change.
Primary HP Omen 15-ax009na, i5-6300HQ+NVIDIA GTX 950 Running MX17 64 bit.
Secondary Thinkpad x220 12GB ssd msata & ssd sata drive MX17 64 bit
Light child duties Thinkpad R51 MX17/Windows XP 32bit with forcepae and IDE to SATA + Kingston SSD.
Re: Laptop Freezes
This was on the x220
- rokytnji.1
- Global Moderator
Re: Laptop Freezes
My old motorcycle shop media center Emachine 3507 is also getting hinky lately with freezes lately. I have been doing hard reboots even. So my 1st step was to run gsmartctl to see if my hard drive is failing.
On mine, gsmartctl says both hard drives are healthy. So my motherboard may be hinky. So just to be sure. I am going to backup what I want to keep. Using a 1TB external hard drive. Then install AntiX on it again and take MX off of it.
If it keeps freezing. I dumpster dived acquired that Emachine. So no big investment loss. So I guess I will switch out parts and use my IBM in the shop. It looks a lot better now than in that picture. The emachine ram and harddrives fit that IBM also.
That shop computer is mainly for manuals & saved pdf's I saved from the web from forums and such. Also is my streaming radio player through a 200 watt per channel stereo sytem for music in the shop. I also made another user so guys that show up can use it while I work on their bikes. For games or web searches. My wifi antenna is a re-purposed Dish network satellite dish.
I have a couple spare towers because City Hall gives me their going to the landfill gear when they upgrade their systems. I am special that way.
I know this may not help you with your problem. Maybe gsmartctl will say your hard drive is healthy also. Usually freezes are hardware related In My Experience.
Hopefully someone else has a better answer for you.
Re: Laptop Freezes
I appreciate the feedback. I hope its not the hdd as its one of those samsung ssds... but worth a check. Thanks
Re: Laptop Freezes
Will boot into mx on my x220 and see how it works.
Re: Laptop Freezes
My X220 is running MX 17 without freezing and temp at 45C.
Edit: just thinking, does you x220 have i5 or i7 cpu? Mine is i5. I7 would run warmer.
- rokytnji.1
- Global Moderator
Re: Laptop Freezes
Have you ran sensors-detect yet in MX?
harry@biker:~
$ sensors
coretemp-isa-0000
Adapter: ISA adapter
Core 0: +49.0°C (high = +95.0°C, crit = +105.0°C)
Core 2: +47.0°C (high = +95.0°C, crit = +105.0°C)
dell_smm-virtual-0
Adapter: Virtual device
Processor Fan: 0 RPM
CPU: +49.0°C
SODIMM: +43.0°C
Other: +48.0°C
Other: +53.0°C
Re: Laptop Freezes
$ sensors
coretemp-isa-0000
Package id 0: +33.0°C (high = +86.0°C, crit = +100.0°C)
Core 0: +33.0°C (high = +86.0°C, crit = +100.0°C)
Core 1: +29.0°C (high = +86.0°C, crit = +100.0°C)
acpitz-virtual-0
temp1: +33.0°C (crit = +99.0°C)
thinkpad-isa-0000
fan1: 0 RPM
coretemp-isa-0000
acpitz-virtual-0
thinkpad-isa-0000
fan1: 0 RPM
Re: Laptop Freezes
Its an I5, sadly I couldnt find an i7 with usb 3.0 or the IPS screen...KBD wrote:My X220 is running MX 17 without freezing and temp at 45C.
This was underload. So this may just be the laptop getting hot as it works. I might have to investigate a repaste of the cpu... perhaps that would help?
- chrispop99
- Global Moderator
Re: Laptop Freezes
Judging by the temperatures you have posted, overheating is not the problem.
If you want to be able to monitor temperatures as you work, you could install the 'sensors' plug-in to the panel.
DELL XPS 15
Lots of test machines
DELL XPS 15
