mx linux 17 first-initial impression + few basic questions, first ever boot from usb
makemxlinuxeasy
#1 Post by makemxlinuxeasy »
minor ux thing
* after chrome downloads, it doesnt auto-open
* you need to click 2 times to open it
* but this a fx problem im guessing
more minor ux thing
* after you open the chrome, i believe there were 2 sets of confirmations when typically there is 1
* but at least you can check to remember as is typical in other oses
a bigger minor ux thing
* it did not auto-close once it was done installing as other oses do
* instead i needed to close it
few questions
what is the default shortcut/hotkey to max a window? couldnt find anything via google
how or where is the setting to dragdrop the icons on the 'left bar'?
the experience at this point was w/e, and i did what i needed to do which is getting to the point of downloading chrome, and opening it, and then i noticed..
highlight bug
when using chrome for a tiny bit, i noticed a 'highlight bug' or error
1. when you highlight text
2. then when you move the mouse to the left,
3. and highlight back to the right
4. it stops highlighting at that point
i've never seen bugs like this before, or anywhere
* if i highlight slowly, it doesnt happen
* it either happens if you highlight left too far or too fast
* im guessing it's likely due to 'too fast'
1-line backstory summary -- with an immense amount of needless trouble & pain, there was only 1 person on a diff linux site that gave a helpful answer to a simple question of how to use a linux from usb
* 'just use etcher'
so on win10 i used:
* https://github.com/resin-io/etcher
* instead of https://github.com/pbatard/rufus
it was a lot simpler, just a few clicks
rufus was technical and confusing
now i know how to go about testing a few other linux distros
* kubuntu plasma
* mx linux xcfe
* elmentory os (w/e they use)
so on to the 3rd and last one tomorrow or something!
Re: mx linux 17 first-initial impression + few basic questions, first ever boot from usb
#2 Post by dolphin_oracle »
the manual has many of the answers you seek, and its translated into several major languages now.
makemxlinuxeasy wrote:minor ux thing
Its not supposed to auto-open. However, chrome can be slow to open the first time you launch during a session.
more minor ux thing
no it doesn't. you launched it twice I suspect.
what doesn't auto-close? mx-packageinstaller? why would you want it to? YOu might want to install something else for instance. synaptic doesn't open close. in fact, no package installer I know of auto-closes.
few questions
check out Settings->Window Manager->Keyboard for a list of hot keys for window management.
for each item you want to move, right-click the item and select "Move"
highlight bug
I suggest filing a bug with Google for that one.
#3 Post by Adrian »
Maybe Gdebi installation pop-up? Not sure what OP meant...
makemxlinuxeasy
#4 Post by makemxlinuxeasy »
rewriting that part:
1. open fx
2. type 'download chrome'
3. click on relevant link
4. press 'download'
5. i think there was one confirmation screen or something
6. after chrome downloads, it doesnt auto-open
7. you need to click 2 times to open it
etc.
#5 Post by richb »
That is Normal behavior. Navigate to the download folder and clicking on the deb brings up gdebi and click on install.
Eadwine Rose
#6 Post by Eadwine Rose »
Why download a deb for Chrome when it is in the MXPI?
I will refer again to The Manual as the answer for many of the questions.
makemxlinuxeasy
#7 Post by makemxlinuxeasy »
Eadwine Rose wrote:Why download a deb for Chrome
because its easier and better and simple things should be done in good ways
makemxlinuxeasy
#8 Post by makemxlinuxeasy »
richb wrote:Normal behavior
ok i dont like it, i dont like those things mentioned in the main post
makemxlinuxeasy
#9 Post by makemxlinuxeasy »
dolphin_oracle wrote:no package installer I know of auto-closes.
ok ill test how the 3rd & last linux version is after this usb thing is fixed
ill likely end up going macos win10 or chromeos long-term based on the experiences so far
dolphin_oracle wrote:"you launched it twice I suspect.
that's werid maybe it was slow to open or something so maybe clicked twice
dolphin_oracle wrote:I suggest filing a bug with Google for that one.
never did this: 'filing a bug'
nothing else has this problem, win10 doesnt, the other linux versions doesnt
i think its a mx linux prblem
notes for comparison reference:
* check out Settings->Window Manager->Keyboard for a list of hot keys for window management.
* dragdrop featue/function not available
makemxlinuxeasy
#10 Post by makemxlinuxeasy »
dolphin_oracle wrote:the manual has many of the answers you seek
this is also something i do not like
i have dont have to read a bible for anything else
for some other things in life there are helpful and good things
this is far too complex and complicated
and it has been a very bad experience overall
