ive just installed mx17 on an old laptop but although i selected uk english in set up during installation once i booted into my desktop its only partly uk english. folders and apps etc are in russian or something. even the date on desktop is only part uk
any help appreciated
language problem in mx 17
win 7 pc, lubuntu 17.10 on compaq pressario, mx 17 on inspiron 1545.
samsung 700g7c mx17
registered linux user number 625675
linux is a way of life
otmapp wwwc krazies and kattle and the krew
samsung 700g7c mx17
Re: language problem in mx 17
I think we had this situation before. Sounds like you selected Ukrainian (uk) instead of United Kingdom. Is that en_GB?
ah ok im with you. do i need to do a re-install then
samsung 700g7c mx17
samsung 700g7c mx17
try from a terminal
then logout/login.
sudo update-locale LANG=en_GB.utf8
thanks guys, that works fine
samsung 700g7c mx17
samsung 700g7c mx17
