For the last week or so I've been receiving this error message when I execute apt-get update.
Err:13 http://security.debian.org stretch/updates/main Translation-en
Could not open file /var/lib/apt/lists/partial/security.debian.org_dists_stretch_updates_main_i18n_Translation-en.bz2 - open (13: Permission denied) [IP: 128.101.240.215 80]
E: Failed to fetch http://security.debian.org/dists/stretc ... slation-en Could not open file /var/lib/apt/lists/partial/security.debian.org_dists_stretch_updates_main_i18n_Translation-en.bz2 - open (13: Permission denied) [IP: 128.101.240.215 80]
E: Some index files failed to download. They have been ignored, or old ones used instead.
I'm not overly concerned about missing security updates for a week or so.
Just seems odd the problem has not been corrected by now.
Tom
[Solved] Stretch Repository Errors
Re: Stretch Repository Errors
Weird. You might want try using MX Repo to have the Debian repo switched to the fastest.
I wonder if this is related somehow
Running the updater via synaptic this morning, I was asked if I wanted to replace the Debian list, which, if we take a look at it, will have some ramifications on one of our tools to select the local repo. The sliver of text in the Synaptic window has the following and for clarity, I've attached a snapshot of the display which contained the "sliver"
--- /etc/apt/sources.list.d/debian.list 2017-12-28 20:29:30.909604866 +1300
+++ /etc/apt/sources.list.d/debian.list.dpkg-new 2018-02-08 12:19:08.000000000 +1300
@@ -1,11 +1,7 @@
# Debian Stable.
-deb http://ftp.nz.debian.org/debian/ stretch main contrib non-free
+deb http://ftp.us.debian.org/debian/ stretch main contrib non-free
deb http://security.debian.org/ stretch/updates main contrib non-free
-#deb-src http://ftp.nz.debian.org/debian/ stretch main contrib non-free
-# Multimedia Stable.
-# Use to install libdvdcss2 and codecs.
-#deb http://www.deb-multimedia.org stretch main non-free
+#deb-src http://ftp.us.debian.org/debian/ stretch main contrib non-free
#stretch backports
#deb http://deb.debian.org/debian stretch-backports main
Mike P
Regd Linux User #472293
and I have chosen "replace" option here (Y).Running the updater via synaptic this morning, I was asked if I wanted to replace the Debian list...
Now I have in /etc/apt/sources.list.d
debian.list
debian.list.dpkg-old
2nd question:
Also I have mxpm-temp.list in there. Is that normal?
That looks like a corrupted file, or one with bad permissions. Open a root Thunar and delete any files found in /var/lib/apt/lists/partial/ . Those are supposed to be temporary files that are removed once the download of the package lists is complete.outlaw wrote:Err:13 http://security.debian.org stretch/updates/main Translation-en
I've seen this happen before when the root partition became full during an apt-get update so it wouldn't hurt to check your free space.
The new debian.list removes the deactivated deb-multimedia repo, which often causes conflicts (gufw removal, for example) if everything is upgraded from it if activated. Though we recommend against that, some people seem to have forgotten to deactivate it after use, or assume it has our approval if it appears in the list. We recommend saying yes, then tweaking your entries with the repo manager again if necessary.
Thank you for your reply Jerry ...your suggestion didn't solve the problem but using a server located closest to me makes sense.
Thank you for your reply Tim.
Deleting all the files from /var/lib/apt/lists/partial/ then running apt-get update generated a new error message:
E: Failed to fetch http://security.debian.org/dists/stretc ... slation-en BZ2_bzread: /var/lib/apt/lists/partial/security.debian.org_dists_stretch_updates_non-free_i18n_Translation-en.bz2 Read error (-5: DATA_ERROR_MAGIC)
This suggests to me a corrupt file but seems unlikely.
Could someone suggest a alternative / mirror for: deb http://security.debian.org/ stretch/updates main contrib non-free
Thank in advance for any advice or suggestions.
Tom
Naturally nuts no pharmaceuticals required
Tom
Looking around for an explanation, I saw several places where users who had the same Read error (-5: DATA_ERROR_MAGIC) message were able to recover by removing everything in /var/lib/apt/lists, including the partial directory. apt-get update worked properly after that. Every once in a while that error pops up if a disk is going bad but unless the new download of that file was into the exact same sectors it occupied the first time, that's fairly unlikely.
Thank you Tim your suggestion appears to have solved the problem.
Initially I only deleted the files in the partial directory.
Tom
Tom
