Very specific conky question...[Closed]
Because of the prototypes (Desktops I'm building) I want my Conky "RAM used " calculation/formula to match the data provided by htop.
Does anyone have that figured out? Mother google does not readily provide me with a pointer....
- Eadwine Rose
- Administrator
Re: Very specific conky question...
${color Tan1}Ram in use ${color}${mem} / $memmax
That is my ramline.
That sounds wrong..
edit: no_buffers are on false here
top result when I websearched "conky ram vs htop":
https://github.com/brndnmtthws/conky/issues/130
discusses the effect of toggling the "no_buffers=" configuration parameter
Just tried opening a few different apps and my conky looks like it's the same as the output from htop.
${font Terminus:size=12}${color #99CC99}Memory ${hr 2} ${alignr}${font}$color
${offset 20}$mem / $memmax $alignr $memperc%
${offset 20}$membar
${offset 20}${top_mem name 1}$alignr${top_mem mem 1}%
${offset 20}${top_mem name 2}$alignr${top_mem mem 2}%
${offset 20}${top_mem name 3}$alignr${top_mem mem 3}%
${offset 20}${top_mem name 4}$alignr${top_mem mem 4}%
${font Terminus:size=12}${color #99CC99}Swap ${hr 2} ${alignr}${font}$color
${offset 20}$swap / $swapmax $alignr $swapperc%
${offset 20}$swapbar
I have the
and it does not match htop. It is off by some 30%.
I did try @skidoo's recommended solution:
But I can't make it do anything other than echo the command stream.
btw. I did come across this in my search which looks pretty interesting:
https://github.com/brndnmtthws/conky/wiki/Configs
$mem / $memmax
[[${mem} / ${memwithbuffers} / ${memmax} :: SWAP ${swap}/${swapmax}]
- Eadwine Rose
- Administrator
I see yes, the difference.
Placing the memwithbuffers bit in mem's place gives me the same result as the sole mem does, so that doesn't seem to help.
Here's a screenshot of what I see...
[attachment=0]screenshot.jpg[/attachment
htop shows 1.18GB RAM... conky 1.48GB
- Eadwine Rose
- Administrator
I've googled a bit, it seems to be a tough nut to crack.. htop shows the mem value minus other values, apparently.
I agree... I'm not certain which value is viewed as being correct. Is it htop or Conky? antiX folks seem to like htop. I think that's fine, but there must be a forumal we can devise to make conky's results match htop (or vice versa).Eadwine Rose wrote: ↑Wed Jun 05, 2019 2:17 pm I've googled a bit, it seems to be a tough nut to crack.. htop shows the mem value minus other values, apparently.
btw. how many angels can stand on the head of a pin???? :lipsrsealed:
Have now checked that conky and htop match on both my desktop & laptop so maybe you could swap out your .conkyrc with the one below just to see if its the same for you.
This conky originated at https://pastebin.com/S88Yj0b8 which I then modified (with my very limited conky knowledge) to include the time & date,two cpu core and separate /home.
conky.config = {
alignment = 'top_right',
maximum_width = 260,
border_width = 0,
font = 'Terminus:size=10',
gap_x = 20,
gap_y = 10,
own_window = true,
own_window_class = 'Conky',
own_window_type = 'override',
own_window_transparent = true,
double_buffer = yes,
background = true,
use_xft = true,
xftalpha = 0,
update_interval = 1.0,
total_run_times = 0,
double_buffer = true,
draw_shades = true,
draw_outline = true,
draw_borders = false,
draw_graph_borders = true,
no_buffers = true,
cpu_avg_samples = 2,
override_utf8_locale = true,
use_spacer = 'right'
conky.text = [[
${font Terminus:size=14}${color #99CC99}$nodename ${hr 2} ${alignr}${font}$color
${alignc}${font Terminus:size=28}${color #ffffff}${time %H:%M}${font}
${alignc}${time %A %d %B %Y}
${offset 20}Kernel:$alignr${kernel}
${offset 20}Uptime:$alignr$uptime
${font Terminus:size=12}${color #99CC99}CPU ${hr 2} ${alignr}${font}$color
${offset 20}Core 1 (${cpu cpu1}%) $alignr Core 2 (${cpu cpu2}%)
${offset 20}${cpugraph cpu1 25,100}$alignr${cpugraph cpu2 25,100}
${offset 20}${top name 1}$alignr${top cpu 1}%
${offset 20}${top name 2}$alignr${top cpu 2}%
${offset 20}${top name 3}$alignr${top cpu 3}%
${offset 20}${top name 4}$alignr${top cpu 4}%
${offset 20}$membar
${font Terminus:size=12}${color #99CC99}Storage ${hr 2} ${alignr}${font}$color
${offset 20}/ $alignc ${fs_used /} / ${fs_size /} $alignr ${fs_used_perc /}%
${offset 20}${fs_bar /}
${offset 20}/home $alignc ${fs_used /home} /home ${fs_size /home} $alignr ${fs_used_perc /home}%
${offset 20}${fs_bar /home}
${color #99CC99}${if_up wlan0}wlan0 (${addr wlan0}) ${hr 2}$color
${offset 20}${color white}$color ${downspeed wlan0}${alignr}${color 333333}$color ${upspeed wlan0}
${offset 20}${downspeedgraph wlan0 25,100} ${alignr}${upspeedgraph wlan0 25,100}$color${endif}
${color #99CC99}${if_up eth0}eth0 (${addr eth0}) ${hr 2}$color
${offset 20}${color white}$color ${downspeed eth0}${alignr}${color 333333}$color ${upspeed eth0}
${offset 20}${downspeedgraph eth0 25,100} ${alignr}${upspeedgraph eth0 25,100}$color${endif}
