Standard rather than Military time
I have %R on my clock and it displays 18:56 PM, but I want it to say 6:56 PM. I looked online and there was not any obvious solution. Maybe I'm just blind.
Could someone help please?
Re: Standard rather than Military time
try
For other options check the date manpage.
%l:%M %p
That's one of the first things I change, I use
You can add a blank space before %p if you want a space, I also use horizontal panel so it doesn't run out of space...
Edit: ninja'd by kmathern
%I:%M%p
%P will give you am/pm indicators in lower case.
For me (using clock) I just append this to what is already there, having checked 12-hour format during installation I believe:
%I:%M%P
%I:%M%P
Thanks guys. did the trick. You're da best.
- Head_on_a_Stick
Is that a bug?
24-hour clocks shouldn't have AM/PM.
- chrispop99
- Global Moderator
As released, it doesn't display am/pm with locale as UK. The strftime function used is %H:%M. Incidentally, %R, which is what the OP says he had, doesn't display am/pm either.Head_on_a_Stick wrote: ↑Fri May 03, 2019 1:52 amIs that a bug?
Perhaps controversially, an argument could be made for 24h display being the default, in view of the number of global users.
DELL XPS 15
Lots of test machines
DELL XPS 15
The best thing about 24 hour time, IMHO,
is how logically it sorts.
https://www.google.com/url?q=https://en ... gD94xl_vj6
A limited number of countries, particularly English-speaking, use the 12-hour clock, or a mixture of the 24- and 12-hour time systems. In countries where the 12-hour clock is still dominant, some professions prefer to use the 24-hour clock. For example, in the practice of medicine the 24-hour clock is generally used in documentation of care as it prevents any ambiguity as to when events occurred in a patient's medical history.[3] In the United States and a handful of other countries, it is popularly referred to as military time.[1][4]
