Trace - online tracking protection
colin_b
#1 Post by colin_b »
After reading through the thread on spying browsers viewtopic.php?f=6&t=48426&hilit=spying+browsers I decided to quit using Chromium based browsers. Since MX comes with Firefox I decided to see if I could make it look and work as I want via theming and add-ons. FF may not offer perfect security, but it looks way more secure than browsers such as Slimjet & Opera (both of which I have regularly used).
I applied a couple of tweaks to FF as mentioned at https://spyware.neocities.org/articles/firefox.html, one of them being disabling pocket. Another less mentioned tweak I made was to "Prevent accessibility services from accessing your browser" in privacy and security. It's not something I use and can cause problems https://support.mozilla.org/en-US/kb/ac ... y-services.
One of the add-ons I had on Firefox was Canvas Defender. I was curious if there was anything available which offered more functionality, so I dug through the add-ons and I ultimately found Trace https://addons.mozilla.org/en-US/firefo ... ble-trace/.
Here's the author's description:
An extension to stop multiple advanced tracking techniques employed by websites all over the web.
Trace can protect against:
Canvas Fingerprinting (Video)
Audio Fingerprinting (Advanced)
WebGL Fingerprinting (New!)
JS Crypto Currency Mining
WebRTC Leakage
User-Agent Tracking (Advanced)
Hardware Fingerprinting
Browser plugin fingerprinting (Advanced)
Beacon Requests
Bad Top Level Domains
Hyperlink Auditing
HTTP Referrer Headers (Video)
Chrome Header Tracking
E-Tag Tracking
URL Tracking Parameters
Specific Tracking Cookies
I have been using it for a few days now and I've got to say I'm impressed with what it can do. A check on Browserleaks https://browserleaks.com/ confirmed it works as advertised. As an example, I set the "Hardware Fingerprint Protection" to indicate my PC has 4 cores and 8GB RAM, and sure enough the "JavaScript Browser Information" at Browserleaks indicated my 2 core machine has 4 cores & 8GB RAM.
I also used Trace alongside uBO-Scope https://addons.mozilla.org/en-US/firefo ... ubo-scope/ to see how well it compared to UBO in blocking unnecessary connections, and I have found it to be on par with UBO on the majority of websites. This has resulted in me disabling UBO as I now find it isn't required.
The only setting in Trace I found which caused problems is "User-Agent Randomiser" - some pages on YouTube don't load correctly. As a result I've left this setting disabled.
If you're looking for an add-on to help protect your online privacy I suggest you give Trace a try. It's a keeper for me.
Also available for Chrome https://chrome.google.com/webstore/deta ... ldkjcplfjb.
manyroads
Re: Trace - online tracking protection
#2 Post by manyroads »
Ok @colin_b... you caught me. I'll give canvas defender a go to see what happens. Have you tried the BitDefender Traffic Light?
colin_b
#3 Post by colin_b »
manyroads wrote: Sun Feb 17, 2019 10:25 pm I'll give canvas defender a go to see what happens.
The add-on you're after is Trace ;)
manyroads wrote: Sun Feb 17, 2019 10:25 pm Have you tried the BitDefender Traffic Light?
I haven't. I'm now a convert to Trace.
manyroads
#4 Post by manyroads »
Got it, Thank you!
colin_b
#5 Post by colin_b »
Hopefully you will find it as useful as I have.
As a footnote, here is more info about Trace and its functionality https://absolutedouble.co.uk/trace/.
