[SOLVED]Recording skype session
mmikeinsantarosa
#1 Post by mmikeinsantarosa »
I've recorded skype sessions using simplescreenrecorder in the past but it only captures the audio on the other end. My audio doesn't get captured. Anybody got a tip what I need to do to also capture my audio.
thanks in advance
- mike
Last edited by mmikeinsantarosa on Tue Dec 25, 2018 10:56 am, edited 1 time in total.
Re: Recording skype session
#2 Post by dolphin_oracle »
if you can, use obs-studio. it can capture multiple sources of video and audio
mmikeinsantarosa
#3 Post by mmikeinsantarosa »
dolphin_oracle wrote: Tue Dec 25, 2018 10:19 am if you can, use obs-studio. it can capture multiple sources of video and audio
Thanks DO. I'll give it a try.
I'm skyping my kid in MN this AM.
turtlebay777
#4 Post by turtlebay777 »
Have a look at Vokoscreen (in the repos) if that one doesn't work.
#5 Post by Adrian »
Skype should be able to make recording now, not sure if the option is available only in Windows (I am not a big Skype user).
mmikeinsantarosa
#6 Post by mmikeinsantarosa »
Adrian wrote: Tue Dec 25, 2018 10:33 am Skype should be able to make recording now, not sure if the option is available only in Windows (I am not a big Skype user).
Recording via skype may be a windows only thing. There's supposed to be a more pick and I don't see that in our skype gui.
I can get OBS to record both audios but not the skype video. It'll capture my webcam just fine though.
Unless I can get this sorted out before 0730 PDT, I'll just record video via simple screen recorder and both audios via OBS and merge them later.
mmikeinsantarosa
#7 Post by mmikeinsantarosa »
turtlebay777 wrote: Tue Dec 25, 2018 10:30 am Have a look at Vokoscreen (in the repos) if that one doesn't work.
That works!
gracias!
Call this one SOLVED!
turtlebay777
#8 Post by turtlebay777 »
mmikeinsantarosa wrote: Tue Dec 25, 2018 10:56 am
That works!
gracias!
Merry Christmas and a Happy New Year!
mmikeinsantarosa
Re: [SOLVED]Recording skype session
#9 Post by mmikeinsantarosa »
Merry christmas to you and yours!
