Hi !
I have just installed MX-18, Swedish language, on a Dell Latitude D630 Laptop.
Generally, I'm pleased, but on the desktop is a field that show the time, CPU load, memory, etc.
It doesn't update. It only add more numbers and is a real mess.
How do I disable it ?
https://photos.app.goo.gl/JhXgAnzyxynfx46k7
/ Hans Gatu
MX-18 desktop clock/CPU/memory/etc
Re: MX-18 desktop clock/CPU/memory/etc
"Conky Toggle" in the menu will turn it off.
Though I thought that Conky display bug was fixed.
I guess its just "mitigated heavily".
on the installed system, I suggest using conky-manager to increase the time delay before the conky starts up if the problem continues.
Last edited by dolphin_oracle on Fri Dec 21, 2018 5:06 pm, edited 1 time in total.
- chrispop99
- Global Moderator
Are you sure you have the Final release, not an earlier version?
DELL XPS 15
Lots of test machines
DELL XPS 15
Could you please give us the output of this command as regular user:Highlight the line that returns then right-click to copy.
cat /etc/mx-version
- chrispop99
- Global Moderator
I've just booted a D630 that was one of the test machines for MX-18. It has Final on it, and it had no Conky corruption on three consecutive boots from installed, and two live.
It had the corruption every boot with Beta/RC1.
DELL XPS 15
DELL XPS 15
Thank you all for your help.
I now have toggled Conky off.
I already have all the info in the system tray, so no need for the Conky.
$ cat /etc/mx-version
MX-18_x64 Continuum Dec 20, 2018
Tanks, and Merry Christmas !
/ Hans Gatu
/ Hans Gatu
