Thunar file icons
Ray66
Thunar file icons
#1 Post by Ray66 »
mxlinux 17 When opening Thunar or files then Documents files are showing data rather than icons
File names are under where icons should be and clearly readable
How do I get icons on these files ?
Re: Thunar file icons
#2 Post by Jerry3904 »
Settings > File Manager, check box "Text beside icons " ??
#3 Post by fehlix »
Thunar -> View
-> View as Icons Ctrl+1
-> View as Detailed List Ctrl+2
-> View as Compact List Ctrl+3
In "Icon View" you can place filename (text) beside Icons as @Jerry mentioned within File Manager Preferences.
Ray66
#4 Post by Ray66 »
I have tried all suggestions and only changing the text to side of icon works
I can not get an icon on the file it only shows small text where the icon should be
Looks like text from inside the file which is libre office data
#5 Post by fehlix »
Ray66 wrote: Thu Aug 16, 2018 8:59 am I have tried all suggestions and only changing the text to side of icon works
Rather show us some screen dumps, as it is would be more clear what you want to achieve.
#6 Post by dolphin_oracle »
I think you are seeing the thumbnails of the file. You can turn off thumbnails in the thunar settings.
Ray66
#7 Post by Ray66 »
Thanks to everyone who helped
Problem solved by setting thumbnail to never
Ray66
(solved)Thunar file icons
#8 Post by Ray66 »
Solved
#9 Post by asqwerth »
Please edit your very first post to insert "(SOLVED)" in the title.
