login between xfce and kde
I installed kde-full using synaptic and would like to use either one
at login.
jozien64
at login.
jozien64
Re: login between xfce and kde
you can. lightdm has a session chooser in the upper right corner of the login screen.
- chrispop99
- Global Moderator
To help you in the future, it is always worth a look in the manual.
Section 6.3 has the information you needed.
DELL XPS 15
Lots of test machines
DELL XPS 15
I tried lightdm and couldnot get to switch to kde.
jozien64
jozien64
- chrispop99
- Global Moderator
At the login screen, on the top-right are three icons. The one to the left of those three, that consists of a number of horizontal lines, is where you select the desktop you want to use for that session.
You should see three entries; Default, Xfce, and KDE.
If the KDE entry is not there, perhaps you haven't installed KDE properly yet?
DELL XPS 15
DELL XPS 15
i guess it will say plasma instead of Kde.
I don't get a login screen because when I originally installed MX 17.1,
I selected automatic login.
How do you change that to get a login screen?
Thank to all who replied.
I originally used Mepis for many , started
with Mepis 3.?
jozien64
with Mepis 3.?
jozien64
- Eadwine Rose
- Administrator
Jozien! Hi :) I remember you :)
- chrispop99
- Global Moderator
MX Tools > MX User Manager > Options tab. Select user's name. Check 'Require password to login'. Click Apply.jozien64 wrote:I don't get a login screen because when I originally installed MX 17.1,
with Mepis 3.?
jozien64
DELL XPS 15
DELL XPS 15
Logout would work wouldn't it?
My Computer
MAG X570 TOMAHAWK WIFI Motherboard
Ryzen 5 3600 Six Core CPU
2x 8GB DDR4 2666 Memory Modules
NVidia GeForce RTX 3060Ti Grfx Card
M.2 x1 @500GB HDD x1 @ 2TB
