how to change language to all english
jozien64
change language
Re: change language
on the installed system
on the live, just choose a new one from the language menus.
sudo update-locale LANG=en_US.utf8
- Schuhabtret0r
Re: change language
Sorry wrong thread.
Re: change language
a newby question....where in the terminal...would one enter this command?
Regards, jonnken...since Feb 2019
Dell Latitude E6440...Intel Core i5-4310M...240G SSD...MX-19.4_x64
Dell Optiplex 755...Intel Core2 Duo E8500...300G HD...MX-19.4_x64
Re: change language
On the command line at the prompt.
Re: change language
is it important to enter command like this...at terminal root /
or can it be entered on a command line prompt...at any directory location?
Re: change language
Yes, in a user terminal with the $ prompt.
sudo temporarily changes to root.
