Installed frugal from DVD to: /dev/sda8 (all good)
Copied lines from /mnt/sda8/antiX-Frugal-4.19.0-5-amd64/grub.entry
Put into grub1 menu.lst
kernel (hd0,0)/boot/vmlinuz-mx18 bdir=antiX-Frugal-4.19.0-5-amd64 buuid=8c8abf92-9c9c-43f1-9e30-511292cfbf05 nosplash lang=en_AU tz=Australia/Sydney persist_all
initrd (hd0,0)/boot/initrd-mx18.img
Fails unable to mount /dev onto /root/dev
Fails unable to find /sbin/init
HP PRODESK Processor 4x Intel(R) Core(TM) i5-4590 CPU @ 3.30GHz Memory 16336MB
Any suggestions?
unable to grub1 boot new install MX18.
Re: unable to grub1 boot new install MX18.
Since you are using legacy grub (you mention menu.lst), you will need to edit the provided grub.entry to make it grub1 compliant.
for me: grub1 = legacy grub.
I updated the menu.lst file, the important lines included in 1st post.
This is how I got antiX-17 to boot.
perhaps change first to /dev/sda8 , which I think in GRUB1 is (hd0,7) ( in Grub2 it would be (hd0,8) )garthur wrote: ↑Mon Aug 26, 2019 11:34 am Installed frugal from DVD to: /dev/sda8 (all good)
and adjust:
kernel (hd0,7)/boot/vmlinuz-mx18 bdir=antiX-Frugal-4.19.0-5-amd64 buuid=8c8abf92-9c9c-43f1-9e30-511292cfbf05 nosplash lang=en_AU tz=Australia/Sydney persist_all
initrd (hd0,7)/boot/initrd-mx18.img
Ah yes.
Shouldn't (hd0,0) be something like (hd0,7) if the frugal install is on sda8?
Re: unable to grub1 boot new install MX18. (solved)
All my kernels and init ram fs files are in sda1 because grub1 wont access the higher partitions.
My fault. somehow I copied the wrong initrd file. all good now.
