Howdy!
Well, this is my 1st post, let the games begin.
I have been using Mint for almost 3yrs. Love it, but have been reading good things about MX and want to give it a try. Did a bootable USB and like what I see. I am ready to do an install on my hard drive, but, want to be sure there should be no issues with dual boot. I currently have Mint 19.1, 18.3, Freedos, and a hidden win partition( so my computer store could charge me to "install" windows.....Thailand).
I have only run into problems doing dual boot a couple of times with Mint, both easy fixes.
Is there anything I be prepared for??
Any surprises compared to a Mint install?
Will MX work with my GRUB selection screen that is already installed on all 3 of my machines or will it replace it?
I did a search on the forums....did not find anything I could use.
Read the manual, while it is mentioned, not enough detail for my Linux pay grade.LOL
Thanks in advance!!
JC
Acer Aspire all in 1 i3 w 4g of ram
Dual Boot
Re: Dual Boot
I assume you are using MBR legacy boot?GlockdocVegas wrote: ↑Tue Jun 04, 2019 8:35 am ...I am ready to do an install on my hard drive, but, want to be sure there should be no issues with dual boot. I currently have Mint 19.1, 18.3, Freedos, and a hidden win partition( so my computer store could charge me to "install" windows.....Thailand).
Thanks in advance!!
JC
And that Mint is controlling the main grub menu right now?
You can have MX work with the current Grub selection screen (assuming it was created by Mint) by choosing during installation to have MX install its bootloader in the root partition, rather than MBR. But if you do that, you will then have to boot into Mint afterwards, and do a
sudo update-grub
If you choose during installation of MX to have MX bootloader be installed on the MBR, then MX will thereafter control the grub menu. It should detect and list the other distros/OSes on the machine.
Take note however that Mint tends to steal back control of grub menu whenever you upgrade kernel or install a new one in Mint.
If you're on UEFI boot, is your computer having Secure Boot turned on? Mint is based on UBuntu and Canonical paid for a secure boot key, so it can work with Secure Boot activated, but if you wish to boot and install MX, you'll need to turn SB off from the BIOS.
Re: Dual Boot
Always good to post "Quick System Info" ( found in the menu) when booting LiveUSB/ISO.
The GRUB install will not differ much from the Mint install.
You'll see with the Mint-grub menu an entry for MX Linux,
and also with the MX-Grub menu an entry for Mint.
All depend's which grubloader you will load when booted,
which depends on UEFI/BIOS booting, as you would select in UEFI booting
different grubloaer directly, whereas in BIOS/MBR you have only one
bootloader to boot into.
- GlockdocVegas
Re: Dual Boot
Thanks! Installed and working well. No major issues.....and.....and...MX finds my dam BT speakers!! Something I have not been able to get handled in Mint 19.1 for the last 6 weeks. =)
