Newbie here. Installed MX recently and finding my way around.In my list of devices (viewed in File Manager) there's a named device which I don't recognise. It's labelled GALPon MiniNo. When I try to mount it to see what it is I get the error message (see attached text file).I'm in a dual boot situation with Win 10 64 bit at ID-4: /dev/sdd vendor: Samsung model: SSD 850 PRO 256GB size: 238.47 GiB and MX at ID-3: /dev/sdc vendor: Seagate model: ST3320620AS size: 298.09 GiB . Should I ignore it as an anomoly or is there a remedy? Thank you.
Speed: 3999 MHz min/max: 800/4000 MHz Core speeds (MHz): 1: 3999 2: 3999 3: 3999
4: 3999
Graphics: Device-1: NVIDIA GF119 [GeForce GT 610] driver: nouveau v: kernel
Display: x11 server: X.Org 1.19.2 driver: nouveau unloaded: fbdev,modesetting,vesa
resolution: 1920x1080~60Hz
OpenGL: renderer: NVD9 v: 4.3 Mesa 18.2.6
Audio: Device-1: Intel 9 Series Family HD Audio driver: snd_hda_intel
Device-2: NVIDIA GF119 HDMI Audio driver: snd_hda_intel
Sound Server: ALSA v: k4.19.0-5-amd64
Network: Device-1: Intel Ethernet I218-V driver: e1000e
IF: eth1 state: up speed: 1000 Mbps duplex: full mac: d0:50:99:71:90:1b
Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet driver: r8169
IF: eth0 state: down mac: d0:50:99:71:90:19
IF-ID-1: eth2 state: down mac: 6a:96:7b:f3:ff:85
Drives: Local Storage: total: 6.27 TiB used: 285.21 GiB (4.4%)
ID-1: /dev/sda vendor: Western Digital model: WD60EZRX-00MVLB1 size: 5.46 TiB
ID-2: /dev/sdb vendor: Seagate model: ST3320620AS size: 298.09 GiB
Partition: ID-1: / size: 136.90 GiB used: 8.33 GiB (6.1%) fs: ext4 dev: /dev/sdc5
ID-2: /home size: 139.26 GiB used: 1.25 GiB (0.9%) fs: ext4 dev: /dev/sdc7
ID-3: swap-1 size: 15.48 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/sdc6
Sensors: System Temperatures: cpu: 57.0 C mobo: N/A gpu: nouveau temp: 46 C
Info: Processes: 229 Uptime: 3h 38m Memory: 15.62 GiB used: 3.46 GiB (22.1%) Shell: bash
inxi: 3.0.33
clive@MXLinux:~
