MokListRT: Out of Resources **SOLVED**
Lfever
#1 Post by Lfever »
I am trying to install MX 18.2 on my laptop but when I try to boot the LiveUSB in UEFI mode MokListRT: Out of Resources is displayed at the top of the screen along with color pixels.
Quick info output:
System:    Host: mx1 Kernel: 4.19.0-1-amd64 x86_64 bits: 64 compiler: gcc v: 6.3.0
           Desktop: Xfce 4.12.3 Distro: MX-18.2_x64 Continuum Apr 7  2019
Machine:   Type: Laptop System: Dell product: Latitude E6420 v: 01 serial: <filter>
           Mobo: Dell model: 0P6K8J v: A00 serial: <filter> BIOS: Dell v: A24 date: 05/12/2017
Battery:   Device-1: hidpp_battery_0 model: Logitech M570 charge: 70% status: Discharging
CPU:       Topology: Dual Core model: Intel Core i5-2520M bits: 64 type: MT MCP
           arch: Sandy Bridge rev: 7 L2 cache: 3072 KiB
           flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 19955
           Speed: 1791 MHz min/max: 800/3200 MHz Core speeds (MHz): 1: 798 2: 799 3: 798 4: 798
Graphics:  Device-1: Intel 2nd Generation Core Processor Family Integrated Graphics vendor: Dell
           driver: i915 v: kernel bus ID: 00:02.0
           resolution: 1366x768~60Hz
           OpenGL: renderer: Mesa DRI Intel Sandybridge Mobile v: 3.3 Mesa 18.2.6
Audio:     Device-1: Intel 6 Series/C200 Series Family High Definition Audio vendor: Dell
           driver: snd_hda_intel v: kernel bus ID: 00:1b.0
Network:   Device-1: Intel 82579LM Gigabit Network vendor: Dell driver: e1000e v: 3.2.6-k
           port: 4080 bus ID: 00:19.0
           Device-2: Broadcom Limited BCM43228 802.11a/b/g/n
           vendor: Dell Wireless 1530 Half-size Mini PCIe Card driver: wl v: kernel port: 4040
           bus ID: 02:00.0
Drives:    Local Storage: total: 240.43 GiB used: 1.66 GiB (0.7%)
           ID-1: /dev/sda vendor: Samsung model: SSD 840 EVO 250GB size: 232.89 GiB
           ID-2: /dev/sdb type: USB vendor: Transcend model: JetFlash Transcend 8GB
Partition: ID-1: / size: 2.94 GiB used: 302.0 MiB (10.0%) fs: overlay source: ERR-102
           ID-2: swap-1 size: 7.00 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/sda4
Sensors:   System Temperatures: cpu: 55.0 C mobo: 33.0 C sodimm: 39.0 C
           Fan Speeds (RPM): cpu: 0
Info:      Processes: 206 Uptime: 12m Memory: 3.74 GiB used: 1.11 GiB (29.8%) Init: SysVinit
           runlevel: 5 Compilers: gcc: 6.3.0 Shell: bash v: 4.4.12 inxi: 3.0.29
fdisk -l output:
root@mx1:/home/demo# fdisk -l
Disk /dev/sda: 232.9 GiB, 250059350016 bytes, 488397168 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: gpt
Disk identifier: 21F72328-7A37-43DC-9C0E-FFB15DEE1EE4
Device         Start       End   Sectors   Size Type
/dev/sda1       2048    206847    204800   100M EFI System
/dev/sda2     206848 136521727 136314880    65G Linux filesystem
/dev/sda3  136521728 473722879 337201152 160.8G Linux filesystem
/dev/sda4  473722880 488396799  14673920     7G Linux swap
Disk /dev/sdb: 7.6 GiB, 8103395328 bytes, 15826944 sectors
Disklabel type: dos
Disk identifier: 0x847e868c
Device     Boot    Start      End  Sectors  Size Id Type
/dev/sdb1  *        2048 15722495 15720448  7.5G 83 Linux
/dev/sdb2       15722496 15824895   102400   50M ef EFI (FAT-12/16/32)
Disk /dev/loop0: 1.3 GiB, 1422229504 bytes, 2777792 sectors
I've tried what I found here with no success.
Hopefully someone can help me find a solution
Thanks
Lfever
Linux and Amateur Radio is a perfect marriage!
Amateur Radio Call: W3IE
Re: MokListRT: Out of Resources
#2 Post by fehlix »
Lfever wrote: Thu Apr 18, 2019 8:44 pm I am trying to install MX 18.2 on my laptop but when I try to boot the LiveUSB in UEFI mode MokListRT: Out of Resources is displayed at the top of the screen along with color pixels.
Please disable secure boot mode.
Lfever
#3 Post by Lfever »
I can find no reference to secure boot in the bios
Also the previous distro on this laptop was installed and running in UEFI
Lfever
#4 Post by fehlix »
Lfever wrote: Thu Apr 18, 2019 9:06 pm I can find no reference to secure boot in the bios
Hmm, looks like this firmware can only boot in UEFI through selecting the grubx64.efi directly (as described in the link you provided). So after Pressing F12 to see the boot menu , and choosing UEFI you might find an option to select to boot from file efi-file. If so navigate to the USB-stick and select /EFI/BOOT/grubx64.efi
Lfever
#5 Post by Lfever »
fehlix wrote: Thu Apr 18, 2019 9:23 pm
Success!
I went back into bios and studied a while (it's a little confusing) ;)
Found and set it to grubx64.efi Installed and fully updated MX 18.2 UEFI running on this laptop :happy:
Thanks for your help fehlix
Lfever
Return to “Installation”
