This will be a long post. A summary of why the reinstall.
I could only boot using a usb stick NOT to the hard drive. A Bios check showed it saw all my hard drives. I have 2 partitions that had error's and fsck fix the one for my root but I could never fix the sda1 boot/esp one. I even reformatted sda1 and reinstall grub but the error seemed to always be there, when a check was done, and I could not boot to the hard drive.
So I boot to a usb that had 'pmagic' to secure erase that hard drive. At first I was told that the drive was Frozen and could not be erased, it was going to try to unfreeze it. It took 2 tries before I could do the erase, which took awhile. Smartmonitor never said the drive had any error's.
I then booted to the march snapshop (Iso was check) and did an update to make sure I had the latest installer. Used gparted to make 3 partitions, sda1-esp, sda2-root and sda3-home. This is the odd thing that happen when I closed gparted all of a sudden I was asked for the password to mount each and very partition on both hard drives, a lot of cancel's. Should note here that I had the usb boot toram (32 GiB). So used MX installer to install gparted 33 and then had it check each and every partition for error's. On closed it did the same thing.
So I then did the install to the hard drive drive and all seems to be good. I've rebooted a few times and then installed the antiX kernel which I'm using. Now I'm slowly installing the other programs and creating the partitions and files as before. One thing that works is my icons on the desktop stay put now.
Here is my system info.
towwire@mx18.1a:~
$ inxi -F
System: Host: mx18.1a Kernel: 4.20.12-antix.1-amd64-smp x86_64 bits: 64 Desktop: Xfce 4.12.3
Distro: MX-18.1_x64 Continuum Feb 9 2019
Machine: Type: Desktop System: Gigabyte product: N/A v: N/A serial: <root required>
Mobo: Gigabyte model: F2A88X-UP4 v: x.x serial: <root required>
UEFI: American Megatrends v: F8a date: 12/14/2015
CPU: Topology: Quad Core model: AMD A10-7850K Radeon R7 12 Compute Cores 4C+8G bits: 64
type: MCP L2 cache: 2048 KiB
Speed: 2374 MHz min/max: 1700/3700 MHz Core speeds (MHz): 1: 1848 2: 2021 3: 1696
4: 1695
Graphics: Device-1: AMD Kaveri [Radeon R7 Graphics] driver: radeon v: kernel
Display: x11 server: X.Org 1.19.2 driver: ati,radeon unloaded: fbdev,modesetting,vesa
resolution: 1920x1200~60Hz
OpenGL: renderer: AMD KAVERI (DRM 2.50.0 4.20.12-antix.1-amd64-smp LLVM 7.0.0)
v: 4.5 Mesa 18.2.6
Audio: Device-1: AMD Kaveri HDMI/DP Audio driver: snd_hda_intel
Device-2: AMD FCH Azalia driver: snd_hda_intel
Sound Server: ALSA v: k4.20.12-antix.1-amd64-smp
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet driver: r8169
IF: eth0 state: up speed: 1000 Mbps duplex: full mac: 74:d4:35:57:f2:98
Drives: Local Storage: total: 2.73 TiB used: 16.20 GiB (0.6%)
ID-1: /dev/sda vendor: Seagate model: ST2000DM001-1CH164 size: 1.82 TiB
ID-2: /dev/sdb vendor: Seagate model: ST1000DM003-1ER162 size: 931.51 GiB
Partition: ID-1: / size: 24.48 GiB used: 6.71 GiB (27.4%) fs: ext4 dev: /dev/sda2
ID-2: /home size: 48.97 GiB used: 9.49 GiB (19.4%) fs: ext4 dev: /dev/sda3
Sensors: System Temperatures: cpu: 1.0 C mobo: N/A gpu: radeon temp: 4 C
Info: Processes: 197 Uptime: 8m Memory: 30.38 GiB used: 929.4 MiB (3.0%) Shell: bash
inxi: 3.0.29
towwire@mx18.1a:~
So I ran 'GRUB_where_is-grub_installed.sh'. You can find it here:
viewtopic.php?f=104&t=47067 ..
towwire@mx18.1a:~/Doc's/Scrips
$ sudo ./GRUB_where_is-grub_installed.sh
[sudo] password for towwire:
/dev/ram0 No GRUB found
/dev/ram1 No GRUB found
/dev/ram2 No GRUB found
/dev/ram3 No GRUB found
/dev/ram4 No GRUB found
/dev/ram5 No GRUB found
/dev/ram6 No GRUB found
/dev/ram7 No GRUB found
/dev/ram8 No GRUB found
/dev/ram9 No GRUB found
/dev/ram10 No GRUB found
/dev/ram11 No GRUB found
/dev/ram12 No GRUB found
/dev/ram13 No GRUB found
/dev/ram14 No GRUB found
/dev/ram15 No GRUB found
/dev/sda No GRUB found
/dev/sda1 No GRUB found
/dev/sda2 No GRUB found
/dev/sda3 No GRUB found
/dev/sda4 No GRUB found
/dev/sda5 No GRUB found
/dev/sda6 No GRUB found
/dev/sdb No GRUB found
/dev/sdb1 No GRUB found
/dev/sdb2 No GRUB found
/dev/sdb3 No GRUB found
/dev/sdb4 No GRUB found
/dev/sdb5 No GRUB found
/dev/sdb6 No GRUB found
/dev/sdb7 No GRUB found
/dev/sdb8 No GRUB found
/dev/sdb9 No GRUB found
/dev/sdb10 No GRUB found
/dev/sdb11 No GRUB found
