failed to create required partitions returning to step 1
Hello MX team,
After learning good things about MX Linux wanted to try it out on one of my machines. The machine earlier had ArcoLinux installed(A spin off of Arch). I created the live USB changed the boot order and started with the installation.
I selected "Auto-install using entire disk".
But while installing I get this error
I came across one of the post about someone facing a similar issue but the solution is too technical for me to understand.
viewtopic.php?t=42541
Thanks and Regards
Thanks and Regards
Re: failed to create required partitions returning to step 1
Welcome! That was excellent research you did (I'm not being sarcastic). The solution in the thread you found is simple. Just reboot the live system and try again.codestruggler wrote: ↑Fri Mar 29, 2019 1:06 am Hello MX team,
If that doesn't work then I have a more drastic solution that will quickly wipe out everything on your hard drive so you can start over. If you don't want to wipe out everything on your hard drive then DO NOT DO THIS. To wipe out a drive and start over, run this command in a terminal:
sudo live-usb-maker --force=usb
-- Richard Feynman
-- Richard Feynman
I tried your solution but I get the same error. I also restarted but its the same.
I also restarted the last time around.
No matter how many times I format the sda gparted later always shows something like this.
http://i.imgur.com/sbCtqDb.png
May be mine is a really peculiar case.
Anything else that I may try ?
Thanks a lot.
Thanks a lot.
I'm sorry it didn't work and I'm a little surprised. It looks like there is plenty of space to partition manually even if that ESP partition was not totally wiped out. The next thing to try is to manually partition. Here is a video: Using MX Linux 17 installer, partitions,format,UEFI. You may have a few more questions about it but this is not my area of expertise. The experts should be getting up in a few hours and they can help you further if you do have questions.
-- Richard Feynman
-- Richard Feynman
I suggest the following.
1. Check the md5sum of the downloaded iso to make sure the download was good.
2. Run gparted from the menu (not from inside the installer)
3. With gparted format your drive as you want. The autoinstaller would make the following partitions
512 MB VFAT with an esp flag set
2GB. Swap
Remainder as root partition formatted ext4
Close gparted when done
4. Run the installer from the terminal
sudo minstall
5. In the installer choose "custom" rather auto. Choose your swap and root partitions. Leave home and boot set to "root" if you followed the partition scheme above.
6. When asked if.you want to format the partitions say NO (they are already formatted).
Let us know of any failure points. In the installer fails please also provide via copy and paste the output that will be in the terminal window.
2GB. Swap
sudo minstall
- Eadwine Rose
- Administrator
Shouldn't the media with which the install is made also be checked?
I followed the video exactly but still get the same error.
Edit:
Sorry I did not see dolphin's reply, I will try his steps and report back.
Edit:
Dolphin's steps should help you with this, if you want to pinpoint the problem you can launch the installer from terminal "sudo -E minstall" and see what's the last messages that it spits when it tries to format the partitions that might give us a clue of what is going on on your system.
Hello Adrian I already did the steps that dolphin_oracle mentioned before I saw your reply only difference is that i did
sudo minstall instead of sudo -E minstall.
I have screenshots of the step by step process that I followed while following Dolphins steps.
1. Partitions using gparted
http://i.imgur.com/bhvsZAE.png
2. launching minstall through terminal
http://i.imgur.com/cyMiMIL.png
3. Choosing partitions manually
http://i.imgur.com/wn75riB.png
4. I selected No when it asked me to format the partitions and got this error.
Failed to prepare the chosen partitions returning to step 1
http://i.imgur.com/PcY9xjo.png
the text in the terminal behind your screen shots might be handy.
