Moderator note:
Images posted to the Forum are limited to 600px x 600px. The link to the larger image at the outside service should be used without the {img} tags if the image is larger than the restricted Forum size.
I'm actually pretty new to linux and trying to install MX Linux on a Lenovo Yoga 520 (81C8). Finally I want to run a dual boot system with MX Linux and Windows 10. Windows 10 is already installed but trying to install MX Linux seems to be a lot of more trouble than I expected. Starting GParted in the Live USB to create a new partition for Linux displays my USB Stick but not my SSD I want to install Linux (screenshot).
https://i.imgur.com/Pio1rUO.png
Searching the internet
Maybe I need some further driver for the SSD, but I'm not sure.
These are my hardware components:
Lenovo Yoga 520- 14IKB (81C8)
Bios 4QCN49WW (v2.13)
CPU Íntel Core i5-8250U
8 GB RAM
Hard Disk Intel SSDPEKKW256G7
Can somebody help me please?
[SOLVED] First Install - GParted can't find SSD
Re: First Install - GParted can't find SSD
Have you tried the help provided/ suggested by "mother google"? (link below)
https://goo.gl/M1fUax
If you have tried the above and those don't work, you should provide the terminal output of the following command here:
inxi-Fxrz
In the upper right corner of gparted you can select the disk / drive.
Gparted always shows only one disk in the main window.
The one visible with the picture is just the USBstick, you are booting from.
Note: The way I'm doing such dual boot is always to shrink the partition
first with Windows itself. after you have free space made in Windows,
do use Gparted to add required partitions for the Linux install.
Please always do a full shutdown in windows (Either hold the shift-key when pressing
shutdown) or disable fastboot, as WIndows "locks" at least the Windows partition
when doing fastboot shotdown's, and I'm not sure if that will make Gparted unhappy
about such a "lock"ed partition, even if you shall not touch the Windows partitions itself.
And note always good to ask before if uncertain, as there might be some pitfalls,
but most can somehow be fixed.
Good Luck
Hey guys,
thanks for your quick answers
didn't work for me, but searching fo "inxi" led me to the following output.
Tried it with different search terms but every video, FAQ, Wiki or forum-thread takes an available HDD (SDD) for granted.manyroads wrote: ↑Sat Mar 23, 2019 9:28 am Have you tried the help provided/ suggested by "mother google"? (link below)
The terminal codemanyroads wrote: ↑Sat Mar 23, 2019 9:28 am If you have tried the above and those don't work, you should provide the terminal output of the following command here:Code: Select all
inxi-Fxrz
inxi-Fxrz
System: Host: mx1 Kernel: 4.19.0-1-amd64 x86_64 bits: 64 compiler: gcc v: 6.3.0
Desktop: Xfce 4.12.3 Distro: MX-18.1_x64 Continuum Feb 9 2019
Machine: Type: Convertible System: LENOVO product: 81C8 v: Lenovo YOGA 520-14IKB
serial: <filter>
Mobo: LENOVO model: LNVNB161216 v: SDK0J40709 WIN serial: <filter> UEFI: LENOVO
v: 4QCN49WW(V2.13) date: 01/10/2019
Battery: ID-1: BAT1 charge: 16.8 Wh condition: 31.8/35.3 Wh (90%) model: Celxpert PABAS0241231
status: Charging
CPU: Topology: Quad Core model: Intel Core i5-8250U bits: 64 type: MT MCP arch: Kaby Lake
rev: A L2 cache: 6144 KiB
flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 28800
Speed: 900 MHz min/max: 400/3400 MHz Core speeds (MHz): 1: 928 2: 905 3: 929 4: 906
5: 930 6: 925 7: 926 8: 938
Graphics: Device-1: Intel vendor: Lenovo driver: i915 v: kernel bus ID: 00:02.0
resolution: 1920x1080~57Hz
OpenGL: renderer: Mesa DRI Intel UHD Graphics 620 (Kabylake GT2) v: 4.5 Mesa 18.2.6
Audio: Device-1: Intel vendor: Lenovo driver: snd_hda_intel v: kernel bus ID: 00:1f.3
Network: Device-1: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter vendor: Lenovo
driver: ath10k_pci v: kernel port: 3040 bus ID: 02:00.0
Device-2: Atheros type: USB driver: btusb bus ID: 1-7:4
Drives: Local Storage: total: 14.32 GiB used: 677.5 MiB (4.6%)
ID-1: /dev/sda type: USB vendor: SanDisk model: Ultra Fit size: 14.32 GiB
RAID: Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci v: 3.0
bus ID: 00:17.0
Partition: ID-1: / size: 6.07 GiB used: 677.5 MiB (10.9%) fs: overlay source: ERR-102
Sensors: System Temperatures: cpu: 41.0 C mobo: N/A
1: deb http://ftp.de.debian.org/debian/ stretch-updates main contrib non-free
1: deb http://ftp.de.debian.org/debian/ stretch main contrib non-free
1: deb http://ftp.halifax.rwth-aachen.de/mxlinux/packages/mx/repo/ stretch main non-free
Info: Processes: 233 Uptime: 14m Memory: 7.66 GiB used: 646.9 MiB (8.2%) Init: SysVinit
runlevel: 5 Compilers: gcc: 6.3.0 Shell: bash v: 4.4.12 inxi: 3.0.29
Tried this, but there is no other disk or HDD I can select. Only the USB-Stick is shown.
Have tried these things too, unfortunately without success. I'm "googleing" and trying for at least seven days. Seems to be difficult to solve, but I won't give up this fast.fehlix wrote: ↑Sat Mar 23, 2019 10:42 am Note: The way I'm doing such dual boot is always to shrink the partition
Good Luck
Yes the correct command, which is the same aa "Quick System Info" from the menu is doingSpecter88 wrote: ↑Sat Mar 23, 2019 1:54 pm The terminal codedidn't work for me, but searching fo "inxi" led me to the following output.Code: Select all
inxi-Fxrz
shall be:
inxi -Fxrz
Better describe what you have done to get help. "Without success" is not much to see what went wrong.
Did you shutdown Windows as recommended, so the partitions are not locked.
First Shutdown Windows full complete without any fastmode.
Further if possible try to disable "RAID" mode of the SATA controler and select "AHCI",
you do this with the BIOS/UEFI setup.
Reboot in Windows and open Device management to see whether you can shrink partition now.
If you really need to run in RAID mode their are other hurtles to overcome.
Further would you mind to try another USB stick, as "SanDisk model: Ultra Fit "
is known to have lot's issues when used as a USB-boot device.
Yes, it's the RAID setting. This might help: https://askubuntu.com/questions/946480/ ... o-yoga-720
Got into my UEFI Firmware settings. Changed the default entry for the storage settings from RST (Intels Rapid Storage Technology) into AHCI and.... Lo and behold! It works!!
Used the tutorial you posted
Thanks a lot guys, you avoided a lot of headache-filled-weekends for me
and got no further problems.Stevo wrote: ↑Sat Mar 23, 2019 2:37 pm This might help: https://askubuntu.com/questions/946480/ ... o-yoga-720
