Installer makes Finish at Step 6 [SOLVED]
Hi Mate,
I try to install MX18.1 with the Kernel 4.14 on my HP.
Installer make Steps 1-6 only,
it does not make a new User & a Password,
see Pictures.
atb/vvm
see Pictures.
atb/vvm
- chrispop99
- Global Moderator
Re: Installer makes Finish at Step 6
Are you doing this with media created from the original ISO, or from a Snapshot?
DELL XPS 15
Lots of test machines
DELL XPS 15
Sorry about my bad English,
1. I made LIveUSB with MX-Live-USB Maker on my 2nd Notebook
2. I have booted this LiveUSB on this Notebook
3. In LiveSystem on this Notebook
I have installed the Kernel 4.14 with MX Package Installer
4. I have run the Remaster
5. I have installed live-usb kernel updater:
https://mxlinux.org/wiki/help-files/hel ... l-updater/
Then I tried to install MX
from this customized LiveUSB on my HP Notebook.
With Kernel 4.14 MX runs on HP without Problem
atb/vvm
sudo apt-get update # if needed
sudo apt-get install git # if needed
git clone https://github.com/BitJam/live-kernel-updater
git clone https://github.com/BitJam/cli-shell-utils
cd live-kernel-updater
sudo ./live-kernel-updater
atb/vvm
The same Story
with MX Installing on my 2nd Notebook (VAIO),
it has many other Linux Distros
and MX18.1 too.
They run perfectly together.
This Installer did make 1-6 Steps
and then Last Step FINISH
without making of Useraccount...
I have no Ideas more,
maybe an other ISO for 64 System,
can anybody send me a valid Link???
atb/vvm
and MX18.1 too.
atb/vvm
Installer skips creating account only if you have an account other than demo on your live environment. Do you have anything else in /home? Any other folder except "demo"?
I tried many times to install this MXLiveUSBDo you have anything else in /home? Any other folder except "demo"?
on different PCs as a 2nd or 3rd OperatingSystem
and I used different USB-Slots on this PCs too.
There were 2 types of Installation:
1. 2 different Partitions - for Root and my Old Home (without to format it)
2. 1 Partition - for Root + Home here
and always Installer makes 6 Steps + Finish
atb/vvm
I understood your Idea,
I format my HP HardDrive with Gparted
and then make a new Installation
Maybe I have Luck
Thanks
atb/vvm
Maybe I have Luck
Thanks
atb/vvm
unfortunately it does not work,
I have formatted my HardDrive
it has a swap,
and a new Root and Home Partitions,
they are EMPTY now....
I have installed MX
and it runs without Problems
but as DEMO user only.
atb/vvm
it has a swap,
I have installed MX
atb/vvm
what iso are you using?
from the running live system give us the output of
and
inxi -F
ls -l /home
demo@mx1:~
$ inxi -F
System: Host: mx1 Kernel: 4.14.0-3-amd64 x86_64 bits: 64 Desktop: Xfce 4.12.3
Distro: MX-18.1.1.1.1.1_x64 Continuum Feb 9 2019
Machine: Type: Laptop System: HP product: HP Laptop 17-ak0xx v: Type1ProductConfigId
serial: <root required>
Mobo: HP model: 8345 v: 41.25 serial: <root required> UEFI: Insyde v: F.04
date: 06/09/2017
Battery: ID-1: BAT0 charge: 40.8 Wh condition: 40.8/40.8 Wh (100%)
CPU: Topology: Dual Core model: AMD A9-9420 RADEON R5 5 COMPUTE CORES 2C+3G bits: 64
type: MCP L2 cache: 1024 KiB
Speed: 1885 MHz min/max: 1400/3000 MHz Core speeds (MHz): 1: 1715 2: 1748
Graphics: Device-1: AMD driver: amdgpu v: kernel
Display: x11 server: X.Org 1.19.2 driver: amdgpu,ati
unloaded: fbdev,modesetting,radeon,vesa resolution: 1920x1080~60Hz
OpenGL: renderer: AMD STONEY (DRM 3.19.0 4.14.0-3-amd64 LLVM 7.0.0)
v: 4.5 Mesa 18.2.6
Audio: Device-1: AMD driver: snd_hda_intel
Device-2: AMD driver: snd_hda_intel
Sound Server: ALSA v: k4.14.0-3-amd64
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet driver: r8169
IF: eth0 state: up speed: 1000 Mbps duplex: full mac: ac:e2:d3:01:bb:fc
Device-2: Realtek driver: N/A
Drives: Local Storage: total: 960.76 GiB used: 3.80 GiB (0.4%)
ID-1: /dev/sda vendor: Toshiba model: MQ01ABD100 size: 931.51 GiB
ID-2: /dev/sdb type: USB vendor: SanDisk model: Cruzer Fit size: 29.25 GiB
Partition: ID-1: / size: 5.82 GiB used: 42.4 MiB (0.7%) fs: overlay source: ERR-102
ID-2: swap-1 size: 4.38 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/sda5
Sensors: System Temperatures: cpu: 44.0 C mobo: 33.0 C gpu: amdgpu temp: 0 C
Info: Processes: 182 Uptime: 1m Memory: 7.33 GiB used: 800.3 MiB (10.7%) Shell: bash
inxi: 3.0.29
demo@mx1:~
