MX 17.1 install fails at partitioning (probably due to NVME & UEFI)
jacklarge
Post by jacklarge » Sun Apr 15, 2018 4:21 am
Hi MX Gurus,
I like the look of MX Linux but having 'issues' getting out of the starting gate! I know the Live CD works with my Laptops specs very nicely but the Installer appears to have a bug at stage 1a/b (partitioning/formatting the disk). I've seen a couple of XPS queries in the forum but none seemed to be exactly the same as mine (or really helped).
My inxi -F:
System:    Host: mx1 Kernel: 4.15.0-1-amd64 x86_64 bits: 64 Desktop: Xfce 4.12.3
           Distro: MX-17.1_x64 Horizon March 14, 2018
Machine:   Device: laptop System: Dell product: XPS 13 9360 serial: N/A
           Mobo: Dell model: 0PF86Y v: A00 serial: N/A UEFI: Dell v: 2.6.2 date: 02/26/2018
Battery    BAT0: charge: 52.1 Wh 90.1% condition: 57.8/60.0 Wh (96%)
CPU:       Dual core Intel Core i7-7560U (-MT-MCP-) cache: 4096 KB
           clock speeds: max: 3800 MHz 1: 700 MHz 2: 700 MHz 3: 700 MHz 4: 700 MHz
Graphics:  Card: Intel Device 5926
           Resolution: 1920x1080@59.93hz
           OpenGL: renderer: Mesa DRI Intel Kabylake GT3 version: 4.5 Mesa 13.0.6
Audio:     Card Intel Device 9d71 driver: snd_hda_intel Sound: ALSA v: k4.15.0-1-amd64
Network:   Card-1: Qualcomm Atheros QCA6174 802.11ac Wireless Network Adapter driver: ath10k_pci
           IF: wlan0 state: up mac: 9c:b6:d0:f3:d1:13
           Card-2: Atheros
           IF: null-if-id state: N/A speed: N/A duplex: N/A mac: N/A
Drives:    HDD Total Size: NA (-)
           ID-1: /dev/nvme0n1 model: KXG50ZNV512G_NVMe_TOSHIBA_512GB size: 512.1GB
Partition: ID-1: / size: 12G used: 62M (1%) fs: overlay dev: N/A
Sensors:   System Temperatures: cpu: 25.0C mobo: N/A
           Fan Speeds (in rpm): cpu: N/A
Info:      Processes: 191 Uptime: 24 min Memory: 947.5/15768.8MB Client: Shell (bash) inxi: 2.3.54
When I run (after updating everything via Synaptic) the installer I get:
then:
and finally:
When I run it via the terminal it appears that the installer is expecting the NVME disk to be nvme0n1p11 rather than nvme0n1p1?
Hope someone can help me as I would really like to install this Distro on my laptop (and it has trashed the partitions so I need to install something :p )
Cheers!
Old enough to remember the Internet when graphics meant ascii art.
Dell XPS 13 9360 - 16GB - 512GB - i7
stsoh
Re: MX 17.1 install fails at partitioning (probably due to NVME & UEFI)
Post by stsoh » Sun Apr 15, 2018 4:56 am
instead of 'nvme0n11', try 'nvme0n1p1'.
jacklarge
Post by jacklarge » Sun Apr 15, 2018 5:06 am
Thanks for the quick reply stsoh. How would I go about that?
stsoh
Post by stsoh » Sun Apr 15, 2018 5:50 am
i thought u r using terminal to format/partition/mount nvme0n1, if u r not sure then use gpart.
jacklarge
Post by jacklarge » Sun Apr 15, 2018 6:20 am
If I partition using gdisk at the terminal, all seems fine. But then when I use the Installer it doesn't give me the option to use those partitions it just allows 'auto install using the entire disk'. So I get exactly the same problem repeating (plus I lose all my partitions that I made in gdisk).
Post by Jerry3904 » Sun Apr 15, 2018 6:26 am
Try using gparted before the installer, formatting the entire hdd to ext4.
wulf
Post by wulf » Sun Apr 15, 2018 6:31 am
I'd second what Jerry3904 says. This sounds like a very similar problem that I had. See here ...viewtopic.php?f=92&t=43904
jacklarge
Post by jacklarge » Sun Apr 15, 2018 6:42 am
Jerry - did as suggested - same result as previous, unfortunately. I think it is more to do with a problem with the installer than anything else at this point.
Wulf - have done all that too - the installer doesn't seem to take any notice of the existing partitions. By the way (probably nothing to do with this issue but) Secure Boot is off in the BIOS too.
Thanks for all the suggestions though guys.
jacklarge
Post by jacklarge » Sun Apr 15, 2018 6:49 am
One thing I haven't tried is to use Legacy rather than UEFI in the BIOS boot.
I plan on only having one OS on this laptop so I could try that - does anyone see any issue with going down that path?
#10
Post by Jerry3904 » Sun Apr 15, 2018 6:57 am
Sorry, should have asked the first question first: have you looked at the Wiki entry (linked in the Users Manual) on this:
https://mxlinux.org/wiki/system/uefi#Li ... nvironment
There is also a video that might be of help:
https://mxlinux.org/uefi-boot-issues-an ... ings-check
Return to “Installation”
