(SOLVED) Install issues with MX 17.1 final 64 bit
muskt
Post by muskt » Wed Mar 14, 2018 6:08 pm
When I attempted to create a bootable USB drive via Windows 10, the install (this was RC1) locked up when attempting to install or to use GParted. I asked for assistance and was told to use the MX utilities. I did--successfully.
Now that 17.1 final is here, I figured I was clever enough to do it again. I did everything via MX17 64. Nothing on my machine has changed. I used the same USB drive. Every time I attempt the install it locks up at 3%. I must use the reset button to start over. I tried the install again, but used GParted first to set up a partition--It still locks up. I did confirm the md5, and have downloaded and burned 3 times--all while using MX17. While the machine is locked up, the cursor will work, FF works, Thunar works. Shutdown or restart does not work, and even using "pkill minstall" will not free up the installer or GParted.
What am I doing wrong? I did notice that the USB drive has a uefi (or whatever) partition on it now. I didn't notice that on the RC1, but it might have been there. My machine is an I7-930 with Asus P6X58D mobo with 18G ram & Nvidia graphics.
Jerry in Delaware
Re: Install issues with MX 17.1 final 64 bit
Post by Jerry3904 » Wed Mar 14, 2018 6:42 pm
Can you please give us the full output of
inxi -F
Post by dolphin_oracle » Wed Mar 14, 2018 7:22 pm
please run
minstall
from the terminal and post any output.
lenovo ThinkPad T530 - MX-18
muskt
Post by muskt » Wed Mar 14, 2018 7:27 pm
Here is what showed up in the terminal after running "minstall".
root@mx1:/home/demo# minstall
Qt: Session management error: Authentication Rejected, reason : None of the authentication protocols specified are supported and host-based authentication failed
removed "sdc4 - 43.7G - ext4 - rootMX17"
yes
Error: device /dev/sdc4 is not mounted
sfdisk: change-id is deprecated in favour of --part-type
The partition table has been altered.
Calling ioctl() to re-read partition table.
Syncing disks.
mke2fs 1.43.4 (31-Jan-2017)
/dev/sdc4 contains a ext4 file system labelled 'rootMX17'
last mounted on Wed Mar 14 17:38:29 2018
Creating filesystem with 11443712 4k blocks and 2861600 inodes
Filesystem UUID: d15579dd-bba6-4eca-9e78-a35401a9ef75
Superblock backups stored on blocks:
32768, 98304, 163840, 229376, 294912, 819200, 884736, 1605632, 2654208,
4096000, 7962624, 11239424
Allocating group tables: done
Writing inode tables: done
Creating journal (65536 blocks): done
Writing superblocks and filesystem accounting information: done
created on Wed Mar 14 19:24:07 2018
Filesystem UUID: 8a574344-7d28-44f0-95e0-af709c566169
make-fstab: Remove all dynamic entries from /etc/fstab
make-fstab: Create new /etc/fstab
Jerry in Delaware
muskt
Post by muskt » Wed Mar 14, 2018 7:30 pm
Here are the results from "inxi -F".
inxi -F
System: Host: mx1 Kernel: 4.15.0-1-amd64 x86_64 bits: 64 Desktop: Xfce 4.12.3
Distro: MX-17.1_x64 Horizon March 14, 2018
Machine: Device: desktop Mobo: ASUSTeK model: P6X58D PREMIUM v: Rev 1.xx serial: N/A
BIOS: American Megatrends v: 1501 date: 05/10/2011
CPU: Quad core Intel Core i7 930 (-MT-MCP-) cache: 8192 KB
clock speeds: max: 2801 MHz 1: 2900 MHz 2: 1696 MHz 3: 1786 MHz 4: 1883 MHz
5: 2387 MHz 6: 1895 MHz 7: 1854 MHz 8: 1699 MHz
Graphics: Card: NVIDIA GF116 [GeForce GTX 550 Ti]
Display Server: x11 (X.Org 1.19.2 )
drivers: nouveau (unloaded: modesetting,fbdev,vesa)
Resolution: 1680x1050@59.88hz
OpenGL: renderer: Gallium 0.4 on NVCF version: 4.3 Mesa 13.0.6
Audio: Card-1 NVIDIA GF116 High Def. Audio Controller driver: snd_hda_intel
Card-2 Intel 82801JI (ICH10 Family) HD Audio Controller driver: snd_hda_intel
Sound: Advanced Linux Sound Architecture v: k4.15.0-1-amd64
Network: Card-1: Marvell 88E8056 PCI-E Gigabit Ethernet Controller driver: sky2
IF: eth1 state: up speed: 1000 Mbps duplex: full mac: 48:5b:39:44:fd:e7
Card-2: Marvell 88E8056 PCI-E Gigabit Ethernet Controller driver: sky2
IF: eth0 state: down mac: 48:5b:39:45:05:b4
Drives: HDD Total Size: 1344.3GB (0.4% used)
ID-1: /dev/sdb model: ST3160811AS size: 160.0GB
ID-2: /dev/sdc model: WDC_WD3200AAKS size: 320.1GB
ID-3: /dev/sda model: WDC_WD3000GLFS size: 300.1GB
ID-4: /dev/sdd model: WDC_WD3000HLFS size: 300.1GB
ID-5: /dev/sde model: Samsung_SSD_840 size: 256.1GB
ID-6: USB /dev/sdf model: TransMemory size: 8.0GB
Partition: ID-1: / size: 15G used: 258M (2%) fs: overlay dev: N/A
ID-2: swap-1 size: 4.24GB used: 0.00GB (0%) fs: swap dev: /dev/sda3
Sensors: System Temperatures: cpu: 40.5C mobo: 38.0C gpu: 41.0
Fan Speeds (in rpm): cpu: 2008 psu: 0 sys-1: 0 sys-2: 0 sys-3: 0
Info: Processes: 221 Uptime: 9 min Memory: 882.1/18050.0MB Client: Shell (bash) inxi: 2.3.54
demo@mx1:~
Post by dolphin_oracle » Wed Mar 14, 2018 7:50 pm
How long did you wait before killing the installer?
Are you preserving home?
Is home on the root partition?
has anything been removed from the target partititon? (mount from the liveUSB and you can check to see if anything has been deleted).
muskt
Post by muskt » Wed Mar 14, 2018 7:54 pm
Longest was close to 10 minutes
Not preserving
Home on Root--Always have done this.
SDC4 is target--labeled rootMX17--live says not mounted--since I tried it a while ago, now nothing happens except for the swirling arrow. Several minutes have passed with no response from comp. I have not a clue how to check for deleted items.
Post by dolphin_oracle » Wed Mar 14, 2018 7:56 pm
deleted doesn't matter if you aren't preserving home.
try mounting the partition in thunar from a live USB and see if your previous install is still there.
muskt
Post by muskt » Wed Mar 14, 2018 7:59 pm
thunar says "unable to mount" an operation is alerady pending.
I never got an install hangs at 3%.
#10
Post by dolphin_oracle » Wed Mar 14, 2018 8:05 pm
can you reboot and try without running the installer.
Return to “Installation”
