Boot after installation
Kikujadek
Post by Kikujadek » Fri Dec 22, 2017 8:25 pm
Hi
I just have installed MX-17 on Acer Aspire ES1-111-C4GS and I can't boot the system. I have UEFI with secure boot enabled and it says no bootable device. When I switch to legacy it boots but freezes after grub, just black screen.
I have tried to use "select an uefi file as trusted for executing" but there is no hdd in there.
I had Linux Lite and Sparky Linux on this netbook which booted without any problem.
Any solutions?
Thanks
Re: Boot after installation
Post by Jerry3904 » Fri Dec 22, 2017 8:26 pm
Can you give us the output the MX Quick System Info so we can see what you have?
Kikujadek
Post by Kikujadek » Fri Dec 22, 2017 8:47 pm
I can give you only photo, I have connection problem right now :(
Post by Stevo » Fri Dec 22, 2017 8:50 pm
Isn't this one of those troublesome BayTrail machines that has a 32-bit instead of a 64-bit UEFI?
Post by dolphin_oracle » Fri Dec 22, 2017 10:17 pm
DiSable secure boot.
lenovo ThinkPad T530 - MX-18
Kikujadek
Post by Kikujadek » Sat Dec 23, 2017 9:39 am
Stevo wrote:Isn't this one of those troublesome BayTrail machines that has a 32-bit instead of a 64-bit UEFI?
How do I check It? It has 64-bit cpu but where to check UEFI?
Disabling secure boot didn't help "no bootable device" as before. :(
Post by dolphin_oracle » Sat Dec 23, 2017 10:13 am
When you ran the ino taller did you install grub to mbr or to esp?
Kikujadek
Post by Kikujadek » Sat Dec 23, 2017 10:24 am
I have installed to mbr
Post by dolphin_oracle » Sat Dec 23, 2017 10:34 am
when booting UEFI, it should be installed to the esp partition of the device. assuming you have a 64bit UEFI that is.
Kikujadek
#10
Post by Kikujadek » Sat Dec 23, 2017 10:58 am
I have installed to esp and than I have selected an uefi file as trusted for executing after that just had to disable secure boot. And it's working!!!
Thanks for all of the replies, special thanks to dolphin :D
Return to “Installation”
