memory usage by desktop environment
- jdmeaux1952
I was doing some searching and ran across this chart of memory usage by desktop environments. I found it interesting.
MSI S6000 i5-460M 4Gb mem
I am not CrAzY. And I have a paper from the doctors to prove it!
LRU# 563815
Phear the Penguin
LRU# 563815
Phear the Penguin
Re: memory usage by desktop environment
The KDE/xfce ratio agrees pretty much with findings by others on this forum. This metric is not very meaningful, however. Increased memory use doesn't translate proportionally to a decrease in performance. I've never been concerned about "conserving" memory. As long as you have enough memory, you won't notice much of a difference.jdmeaux1952 wrote:I was doing some searching and ran across this chart of memory usage by desktop environments. I found it interesting.
2.4GHz AMD Athlon 4600+
- jdmeaux1952
I've got 16 Gb on my desktop AMD machine, 4 Gb on my MSI laptop, and 512 Mg on myJUNKBOX. I have used Openbox, Fluxbox, and LXDE on the JUNKBOX. Although I never have truly worried about the memory usage, I just though that what was posted as memory usage for the different desktop environments was interesting.joany wrote: Increased memory use doesn't translate proportionally to a decrease in performance. I've never been concerned about "conserving" memory. As long as you have enough memory, you won't notice much of a difference.
LRU# 563815
Phear the Penguin
LRU# 563815
Phear the Penguin
I think DE [choice] depends on how much bling one wants,
how much memory is available,
and probably sun spots.
Don't forget what you ate last night. This can effect many things.
--Mark Twain
--Mark Twain
- jdmeaux1952
And I love those "organic" mushrooms, too.
LRU# 563815
Phear the Penguin
LRU# 563815
Phear the Penguin
It is interesting. Thanks for posting. In particular, I'm surprised that MATE is so much lower than Xfce. I expected them to be more or less the same. Whoever did this must've isolated just the DE portion of memory use. This is important info for low RAM systems, but I do agree that with modern 4-8GB machines with fast processors, it's more a curiosity than anything else.
Acer Aspire 7736Z-4088
Pentium T4400 2.2Ghz, Intel GMA 4500M
4GB RAM, 500GB WDC_WD5000LPLX
MX-15 64-bit
MX-15 64-bit
- Gordon Cooper
Perhaps you forgot the most important thing - the phases of the moon.jdmeaux1952 wrote:And I love those "organic" mushrooms, too.
- jdmeaux1952
I had been "googling" something like "desktop environment memory" or "comparison of DE" or "lxde VS xfce" when I ran across an article on memory usage by DE. I should have linked back to the article as well.
LRU# 563815
Phear the Penguin
LRU# 563815
Phear the Penguin
Must have been from this site: http://lxlinux.com/
I got very different results when comparing kde and xfce on mx-14.
Kde with akonadi turned off isn't heavy at all. OK, it's using more memory than xfce, but much less than indicated by this chart.
Could it be a little bit rigged to show how light lxde is?
Henry
Henry
