Help please-no music in Imagination program
I'm trying to do a slideshow using imagination and when I import music it does not show up in the audio area. Program ver is 3.02 r1. DEB site shows a 3.03 ver in SID repos but I am reluctant to risk borking my mx14 by installing it.
"Computers are tools; they should primarily be designed to easily complete the task desired"
Dell Dimension 4700 - ANTIX 19 on Kingston A400 SSD
ACER Desktop Athlon 64X2 - MX 19
Acer C720P 32GB SSD 4GB Memory Ex- Chromebook - GalliumOS
Re: Help please-no music in Imagination program
I hope for your sake that someone here uses the program. Failing that, I see from the Debian packages page that it requires ffmpeg encoder to be installed, which is only listed as recommended in Synaptic. Do you have that installed?
If you want to import .mp3 files into your slide show, you have to install libsox-fmt-mp3. Make sure libxox-fmt-alsa is installed also, if you're using Alsa. In fact, you might as well install all of the libsox-fmt packages through the libsox-fmt-all metapackage.
2.4GHz AMD Athlon 4600+
thanks. I will try both solutions tonight and see how it goes. I sucessfully used the programb4 in ubuntu 12.04 but don't want to install the os just to get Imagination to work.
Oh, it'll work, believe me. There's no need to install a different version of Imagination or a different OS in order to get sound in your slideshow.zarg2 wrote:thanks. I will try both solutions tonight and see how it goes. I sucessfully used the programb4 in ubuntu 12.04 but don't want to install the os just to get Imagination to work.
@zarg2, why don't you put in a request to have the sid/Jessie version of Imagination added to the CR?
Why?kmathern wrote:@zarg2, why don't you put in a request to have the sid/Jessie version of Imagination added to the CR?
Mainly to keep him from using the sid reposjoany wrote:Why?kmathern wrote:@zarg2, why don't you put in a request to have the sid/Jessie version of Imagination added to the CR?
But if the recommended sox packages are indeed all that's required, a backport of the Sid package wouldn't solve the problem.
yep, I will try joany's solutions this evening and post the results here. I think I'm maybe one of a 100 people that actually use imagination so backporting the sid version would be a lot of trouble to go to.
