Here is the first draft of the documentation for this feature:
o F7 Save
(LiveUSB)
This can save all your menu selections and typed-in boot
parameters as the new defaults. It is a very easy way to
quickly customize a LiveUSB for language and timezone.
menus
Use the current menu selections as the defaults.
custom
Create a new main menu entry using any boot codes you
have entered manually. If you don't enter any boot codes
then a custom entry won't be made.
both
Use the current menu selections as the defaults and also
create a custom main menu entry.
reset
Remove any custom main menu entry and restore the
original menu defaults.
If one Language option works then they all should work. The same is true of Time Zone and Console. But for the other menus (Options, Video Mode) it would be great if every entry were tested to see if it gets saved. Although AFAIK there is no reason for the "check md5" or "check fs" options to be saved. There are some known imperfections in the system if typed-in options conflict with options from the menus. In this case neither one will be saved. One way to test the custom main menu entry feature is to just type in a made-up bootcode, "my-bootcode" or whatever. This will be flagged as unknown but that won't hurt anything nor should it interfere with the saving.
The saving happens early in the boot process. There is visual feedback on the screen but unfortunately the modem program that was added to RC2 fills the boot screen with useless messages, scrolling everything else off screen. (In my personal opinion we should ditch that program on the grounds of it being rude and obnoxious). You can try to mitigate this in three ways:
- Use the "F6 Console" menu to increase the console resolution
- Use the "bp=9" boot parameter to pause the boot process. Use ctrl-d to continue.
- Look in the log files under /var/log/live/. Most things that get printed to the screen
early on should show up in files under there. - You can also increase the amount of feedback with the "verb=7" boot option although
this won't help with the scrolling off-screen problem.
