vokoscreen in meta-installer
Has anyone tried vokoscreen from the meta-installer. If I record audio, I get a message about ffmpeg crashing.
Re: vokoscreen in meta-installer
I can't get my mic to work, but no crashing when recording.dolphin_oracle wrote:Has anyone tried vokoscreen from the meta-installer. If I record audio, I get a message about ffmpeg crashing.
Mine won't go 3 seconds without crashing, if I'm recording audio.
Do any error messages show up when running it from a terminal?dolphin_oracle wrote:Mine won't go 3 seconds without crashing, if I'm recording audio.
And which version of vokoscreen? I see 1.8.10 is now in wheezy-backports...
OK, I've just built 1.9.0, can you try this one out, too?
http://ubuntuone.com/5PzfqRNTYv2znjHihSyhA6
I get about two seconds of audio now with 1.9.0 before the sound stops, with the video continuing.
This is a headache, because the sound worked, though it did get out of sync, when I first built and tested 1.9.0 at the beginning of Feb--I still have the saved .mkv videos--and I can't think of what has really changed in the meantime that can affect it.....
OK, sound seems to work when I restrict the area to a window, I wonder if fullscreen is too much for my laptop, even with reducing framerate. Also, mpeg4 recording to an .avi file seems to be broken.
It was my idea to put it in the meta installer, but perhaps it should be removed, if some systems are going to have resource or sound problems.
I get the amazing message:Stevo wrote:Do any error messages show up when running it from a terminal?dolphin_oracle wrote:Mine won't go 3 seconds without crashing, if I'm recording audio.
"ffmpeg has crashed".
I'm in the middle of backup from restore, so I'll try the new version and report back with the output from the terminal.
Here are the results of the new vokoscreen_1.9.0-1mcr120+1_i386.deb version . It still crashed:
screenshot of crash message in gui
and the terminal output from a second attempt.
dolphin@mx1:~
$ vokoscreen
[vokoscreen] Locale: "en_US"
[vokoscreen] Version: "1.9.0"
[vokoscreen] Qt Version: 4.8.2
[vokoscreen] asoundlib Version: "1.0.25"
[vokoscreen] ---Begin Search external tools---
[vokoscreen] Find avconv Version: "9.10-6:9.10-1~bpo70+1"
[vokoscreen] Error: pactl is not found, this is an PulseAudio-utils tool. Please install pactl
[vokoscreen] Find mkvmerge
[vokoscreen] ---End search external tools---
[vokoscreen] ---Begin search Videoplayer---
[vokoscreen] Find Videoplayer : "/usr/bin/avplay"
[vokoscreen] Find Videoplayer : "/usr/bin/vlc"
[vokoscreen] ---End search Videoplayer---
[vokoscreen][Regional selection] Frame locked: false
[vokoscreen] ---Begin search PulseAudio Plugin---
[vokoscreen] Found file .asound for PulseAudio Plugin
[vokoscreen] ---End search PulseAudio Plugin---
[vokoscreen] ---Begin Pulse unload Module---
[vokoscreen] ---End Pulse unload Module---
[vokoscreen] ---Begin search Alsa capture device---
[vokoscreen] alsa_device_sample() in alsadevice.c: open audio device hw:0,0 (Success)
[vokoscreen] alsa_device_sample() in alsadevice.c: Samplerate = 44100
[vokoscreen] Find CaptureCard: "[hw:0,0] HDA Intel MID"
[vokoscreen] ---End search Alsa capture device---
[vokoscreen] ---Begin search PulseAudio Capture Devices---
[vokoscreen] ---End search PulseAudio Capture Devices---
[vokoscreen] ffmpegcommand : "avconv -f alsa -ac 2 -i hw:0,0 -f x11grab -r 25 -s 1366x768 -i :0.0+0,0 -pix_fmt yuv420p -vcodec mpeg4 -acodec libmp3lame -ar 44100 -qscale 1 -r 25 /tmp/vokoscreen-vokoscreen/vokoscreen-2014-02-12_09-00-29.mkv"
[vokoscreen] ffmpeg is running and is ready for reading and writing
"[vokoscreen] ffmpeg is crashed on Wednesday, 09:00"
[vokoscreen] ffmpeg is not running
dolphin@mx1:~
I can see that the problem has already been reported to Debian:
https://bugs.debian.org/cgi-bin/bugrepo ... bug=736976
So maybe we need to use an alternate screen recorder.
Stevo wrote:I can see that the problem has already been reported to Debian:
well, there is nothing wrong with gtk-recordmydesktop.
