I removed vlc to fix some dependencies and now I get this:
vlc-nox : Depends: libswscale2 (>= 6:9.1-1) but 6:0.8.9-1 is installed.
Is it something that affects MEPIS users too?
VLC doesn't install
Re: VLC doesn't install
This is fixed for MX-14-beta2. But beta1 is broken without quite a bit of hackery.
No idea if it affects MEPIS users
For beta 1, these aptitude commands worked to upgrade VLC (as root, of course)
I have a feeling these may come in handy for later situations.
aptitude dist-upgrade -t wheezy-backports
aptitude dist-upgrade -t mx
Thanks Stevo,Stevo wrote:For beta 1, these aptitude commands worked to upgrade VLC (as root, of course)
I have a feeling these may come in handy for later situations.Code: Select all
aptitude dist-upgrade -t wheezy-backports aptitude dist-upgrade -t mx
It sure came in handy for Mepis 12 (only first line). VLC (now 2.1.2 from bpo) was upgraded..
ko@lappy:~$ su
Password:
root@lappy:/home/ko# aptitude dist-upgrade -t wheezy-backports
The following NEW packages will be installed:
libavfilter3{a} libavformat54{a} libavresample1{a}
initramfs-tools libav-tools libavdevice53 libpostproc52 libswscale2 linux-libc-dev vlc vlc-nox
The following packages are RECOMMENDED but will NOT be installed:
vlc-plugin-notify vlc-plugin-pulse
8 packages upgraded, 3 newly installed, 0 to remove and 0 not upgraded.
Need to get 9,047 kB of archives. After unpacking 10.2 MB will be used.
Do you want to continue? [Y/n/?]
Get: 1 http://ftp.nl.debian.org/debian/ wheezy-backports/main libavformat54 amd64 6:9.10-1~bpo70+1 [523 kB]
Get: 2 http://ftp.nl.debian.org/debian/ wheezy-backports/main libavdevice53 amd64 6:9.10-1~bpo70+1 [80.2 kB]
Get: 3 http://ftp.nl.debian.org/debian/ wheezy-backports/main libavresample1 amd64 6:9.10-1~bpo70+1 [86.9 kB]
Get: 4 http://ftp.nl.debian.org/debian/ wheezy-backports/main libswscale2 amd64 6:9.10-1~bpo70+1 [132 kB]
Get: 5 http://ftp.nl.debian.org/debian/ wheezy-backports/main libavfilter3 amd64 6:9.10-1~bpo70+1 [143 kB]
Get: 6 http://ftp.nl.debian.org/debian/ wheezy-backports/main libav-tools amd64 6:9.10-1~bpo70+1 [3,444 kB]
Get: 7 http://ftp.nl.debian.org/debian/ wheezy-backports/main libpostproc52 amd64 6:0.git20120821-4~bpo70+1 [41.9 kB]
Get: 8 http://ftp.nl.debian.org/debian/ wheezy-backports/main vlc amd64 2.1.2-2~bpo70+2 [1,181 kB]
Get: 9 http://ftp.nl.debian.org/debian/ wheezy-backports/main vlc-nox amd64 2.1.2-2~bpo70+2 [2,425 kB]
Get: 10 http://ftp.nl.debian.org/debian/ wheezy-backports/main initramfs-tools all 0.115~bpo70+1 [92.6 kB]
Get: 11 http://ftp.nl.debian.org/debian/ wheezy-backports/main linux-libc-dev amd64 3.12.6-2~bpo70+1 [897 kB]
Fetched 9,047 kB in 3s (2,783 kB/s)
Selecting previously unselected package libavformat54:amd64.
(Reading database ... 118395 files and directories currently installed.)
Unpacking libavformat54:amd64 (from .../libavformat54_6%3a9.10-1~bpo70+1_amd64.deb) ...
Preparing to replace libavdevice53:amd64 6:0.8.9-1 (using .../libavdevice53_6%3a9.10-1~bpo70+1_amd64.deb) ...
Unpacking replacement libavdevice53:amd64 ...
Selecting previously unselected package libavresample1:amd64.
Unpacking libavresample1:amd64 (from .../libavresample1_6%3a9.10-1~bpo70+1_amd64.deb) ...
Preparing to replace libswscale2:amd64 6:0.8.9-1 (using .../libswscale2_6%3a9.10-1~bpo70+1_amd64.deb) ...
Unpacking replacement libswscale2:amd64 ...
Selecting previously unselected package libavfilter3:amd64.
Unpacking libavfilter3:amd64 (from .../libavfilter3_6%3a9.10-1~bpo70+1_amd64.deb) ...
Preparing to replace libav-tools 6:0.8.9-1 (using .../libav-tools_6%3a9.10-1~bpo70+1_amd64.deb) ...
Unpacking replacement libav-tools ...
Preparing to replace libpostproc52:amd64 6:0.8.9-1 (using .../libpostproc52_6%3a0.git20120821-4~bpo70+1_amd64.deb) ...
Unpacking replacement libpostproc52 ...
Preparing to replace vlc 2.1.2-0mcr120+1 (using .../vlc_2.1.2-2~bpo70+2_amd64.deb) ...
Unpacking replacement vlc ...
Preparing to replace vlc-nox 2.1.2-0mcr120+1 (using .../vlc-nox_2.1.2-2~bpo70+2_amd64.deb) ...
Unpacking replacement vlc-nox ...
Preparing to replace initramfs-tools 0.110 (using .../initramfs-tools_0.115~bpo70+1_all.deb) ...
Unpacking replacement initramfs-tools ...
Preparing to replace linux-libc-dev:amd64 3.9.8-1 (using .../linux-libc-dev_3.12.6-2~bpo70+1_amd64.deb) ...
Unpacking replacement linux-libc-dev:amd64 ...
Processing triggers for man-db ...
Processing triggers for mime-support ...
Processing triggers for desktop-file-utils ...
Processing triggers for menu ...
Setting up libavformat54:amd64 (6:9.10-1~bpo70+1) ...
Setting up libavdevice53:amd64 (6:9.10-1~bpo70+1) ...
Setting up libavresample1:amd64 (6:9.10-1~bpo70+1) ...
Setting up libswscale2:amd64 (6:9.10-1~bpo70+1) ...
Setting up libavfilter3:amd64 (6:9.10-1~bpo70+1) ...
Setting up libav-tools (6:9.10-1~bpo70+1) ...
Configuration file `/etc/avserver.conf'
==> Modified (by you or by a script) since installation.
==> Package distributor has shipped an updated version.
What would you like to do about it ? Your options are:
Y or I : install the package maintainer's version
N or O : keep your currently-installed version
D : show the differences between the versions
Z : start a shell to examine the situation
The default action is to keep your current version.
*** avserver.conf (Y/I/N/O/D/Z) [default=N] ?
Setting up libpostproc52 (6:0.git20120821-4~bpo70+1) ...
Setting up vlc-nox (2.1.2-2~bpo70+2) ...
Setting up vlc (2.1.2-2~bpo70+2) ...
Setting up initramfs-tools (0.115~bpo70+1) ...
update-initramfs: deferring update (trigger activated)
Setting up linux-libc-dev:amd64 (3.12.6-2~bpo70+1) ...
Processing triggers for initramfs-tools ...
update-initramfs: Generating /boot/initrd.img-3.12-3.dmz.1-liquorix-amd64
W: mdadm: /etc/mdadm/mdadm.conf defines no arrays.
W: mdadm: no arrays defined in configuration file.
Current status: 0 updates [-8].
Ko Bros Linux User #312596. MX14.4, MX14.3, Mepis 12, Debian 7, antiX 15, Peppermint 5...and sometimes Win7
