update-notifier and -manager
This is the first time I have seen this in operation, now that Kent's simple proposal to delete that file (forget the name) works.
I tested this following a suggestion of Kent's in the following way:
1) enable a new repo:
deb
http://ftp.us.debian.org/debian/ [NOTE: substitute your favorite code in place of "us" if not in the US of A]
wheezy-proposed-updates
contrib non-free main
2) update and upgrade [NOTE: I suppose it would eventually catch up, not sure whether the repo needs somehow to be made active]
3) click on the yellow icon that appears in the Notification Area
4) up pops update-manager (also is a menu entry) with possible updates listed
5) I unchecked all except "whois," install went without a hitch.
Questions I have
--technical: how can that erroneous file be corrected during/after install?
--user: my root pwd was not requested, which surprised me. I see a good argument that packages already installed by the user do not need the same level of permissions that new installs need, but what do you think?
Certainly much nicer for the user IMHO.
deb
Questions I have
Re: update-notifier and -manager
Are you talking about the /etc/lsb-release file, or something else?Jerry3904 wrote:... --technical: how can that erroneous file be corrected during/after install? ...
I'm getting a gksu authentication box before update-manager will start:Jerry3904 wrote: ... --user: my root pwd was not requested, which surprised me. I see a good argument that packages already installed by the user do not need the same level of permissions that new installs need, but what do you think?...
{the screenshot below is from my sid install, but I'm pretty sure it will do the same on MX14} Had you previously done some other things that used gksu for authentication, and you didn't clear the "Remember password" checkbox?
Yes, that file
Maybe, will check. Glad that you are seeing it.
- chrispop99
- Global Moderator
I can confirm that changing repos to force an update, then logging out/in causes update manager to trigger, and then the root passwd is needed to proceed.Jerry3904 wrote: Questions I have
DELL XPS 15
Lots of test machines
DELL XPS 15
So that seems to leave us with that file issue.
There are two ways to modify the file.Jerry3904 wrote:So that seems to leave us with that file issue.
1. at install time, the installer can be modified to replace/remove file or replace strings in a file
2. after install with an update, ask Stevo or other packagers I think there's relatively easy to replace/remove files with a deb.
How's the /etc/lsb-release file created in the first place? Isn't it just a text file that you or anticapitalista create? If that's the case couldn't you (or anti) just change the file before remastering the iso?Adrian wrote:There are two ways to modify the file.Jerry3904 wrote:So that seems to leave us with that file issue.
It can be changed. Then, when grub is installed to MBR, the boot menu shows Debian rather than MX-14
I think that comes from the GRUB_DISTRIBUTOR line in the /etc/default/grub fileanticapitalista wrote:It can be changed. Then, when grub is installed to MBR, the boot menu shows Debian rather than MX-14
I wonder if you could change that line to: GRUB_DISTRIBUTOR="MX-14"$ head /etc/default/grub
# If you change this file, run 'update-grub' afterwards to update
# /boot/grub/grub.cfg.
# For full documentation of the options in this file, see:
# info -f grub -n 'Simple configuration'
GRUB_DEFAULT=0
GRUB_TIMEOUT=5
GRUB_DISTRIBUTOR=`lsb_release -i -s 2> /dev/null || echo Debian` <==
GRUB_CMDLINE_LINUX_DEFAULT="quiet"
GRUB_CMDLINE_LINUX=""
I tried that before and grub failed to boot. I'll try it again.
