Clementine issues in MX-14 Beta1
Re: MX-14 beta 1
#1 Post by anticapitalista »
Re- Clementine.
The one that gets installed is from the MEPIS CR repo which does not have some depends that the version in Wheezy installs.
So, I will add the extra to the meta-installer. This is what i did after installing clementine using the meta-installer and commenting out the mepiscr repos.
apt-get purge clementine
Reading package lists... Done
Building dependency tree
The following packages were automatically installed and are no longer required:
  libavcodec54 libavformat54 libavutil52 libqtwebkit4
Use 'apt-get autoremove' to remove them.
The following packages will be REMOVED:
  clementine*
0 upgraded, 0 newly installed, 1 to remove and 3 not upgraded.
After this operation, 21.1 MB disk space will be freed.
Do you want to continue [Y/n]?
(Reading database ... 95162 files and directories currently installed.)
Removing clementine ...
Processing triggers for hicolor-icon-theme ...
Processing triggers for desktop-file-utils ...
Processing triggers for gconf2 ...
root@mx1:/home/qwe# apt-get install clementine
The following extra packages will be installed:
  libdbusmenu-glib4 libechonest1.2 libftgl2 libindicate-qt1 libindicate5
  libprojectm2 libqxt-core0 libqxt-gui0
The following NEW packages will be installed:
  clementine libdbusmenu-glib4 libechonest1.2 libftgl2 libindicate-qt1
  libindicate5 libprojectm2 libqxt-core0 libqxt-gui0
0 upgraded, 9 newly installed, 0 to remove and 3 not upgraded.
Need to get 5,872 kB of archives.
After this operation, 15.2 MB of additional disk space will be used.
Get:1 http://ftp.gr.debian.org/debian/ wheezy/main libdbusmenu-glib4 i386 0.6.2-1 [109 kB]
Get:2 http://ftp.gr.debian.org/debian/ wheezy/main libqxt-core0 i386 0.6.1-6 [231 kB]
Get:3 http://ftp.gr.debian.org/debian/ wheezy/main libqxt-gui0 i386 0.6.1-6 [342 kB]
Get:4 http://ftp.gr.debian.org/debian/ wheezy/main libechonest1.2 i386 1.2.1-1 [227 kB]
Get:5 http://ftp.gr.debian.org/debian/ wheezy/main libindicate5 i386 0.6.92-1 [62.1 kB]
Get:6 http://ftp.gr.debian.org/debian/ wheezy/main libindicate-qt1 i386 0.2.5.91-5 [33.1 kB]
Get:7 http://ftp.gr.debian.org/debian/ wheezy/main libftgl2 i386 2.1.3~rc5-4 [110 kB]
Get:8 http://ftp.gr.debian.org/debian/ wheezy/main libprojectm2 i386 2.1.0+dfsg-1 [270 kB]
Get:9 http://ftp.gr.debian.org/debian/ wheezy/main clementine i386 1.0.1+dfsg-2+b1 [4,489 kB]
Fetched 5,872 kB in 22s (260 kB/s)
Selecting previously unselected package libdbusmenu-glib4:i386.
(Reading database ... 95149 files and directories currently installed.)
Unpacking libdbusmenu-glib4:i386 (from .../libdbusmenu-glib4_0.6.2-1_i386.deb) ...
Selecting previously unselected package libqxt-core0:i386.
Unpacking libqxt-core0:i386 (from .../libqxt-core0_0.6.1-6_i386.deb) ...
Selecting previously unselected package libqxt-gui0:i386.
Unpacking libqxt-gui0:i386 (from .../libqxt-gui0_0.6.1-6_i386.deb) ...
Selecting previously unselected package libechonest1.2:i386.
Unpacking libechonest1.2:i386 (from .../libechonest1.2_1.2.1-1_i386.deb) ...
Selecting previously unselected package libindicate5.
Unpacking libindicate5 (from .../libindicate5_0.6.92-1_i386.deb) ...
Selecting previously unselected package libindicate-qt1.
Unpacking libindicate-qt1 (from .../libindicate-qt1_0.2.5.91-5_i386.deb) ...
Selecting previously unselected package libftgl2.
Unpacking libftgl2 (from .../libftgl2_2.1.3~rc5-4_i386.deb) ...
Selecting previously unselected package libprojectm2.
Unpacking libprojectm2 (from .../libprojectm2_2.1.0+dfsg-1_i386.deb) ...
Selecting previously unselected package clementine.
Unpacking clementine (from .../clementine_1.0.1+dfsg-2+b1_i386.deb) ...
Processing triggers for man-db ...
Processing triggers for menu ...
Setting up libdbusmenu-glib4:i386 (0.6.2-1) ...
Setting up libqxt-core0:i386 (0.6.1-6) ...
Setting up libqxt-gui0:i386 (0.6.1-6) ...
Setting up libechonest1.2:i386 (1.2.1-1) ...
Setting up libindicate5 (0.6.92-1) ...
Setting up libindicate-qt1 (0.2.5.91-5) ...
Setting up libftgl2 (2.1.3~rc5-4) ...
Setting up libprojectm2 (2.1.0+dfsg-1) ...
Setting up clementine (1.0.1+dfsg-2+b1) ...
root@mx1:/home/qwe#
#2 Post by richb »
I started this thread and moved the last Clementine issues post here. Please post Clementine issues on MX-14 Beta1 here.
chrispop99
Re: MX-14 beta 1
#3 Post by chrispop99 »
anticapitalista wrote:Re- Clementine.
(Excuse my lack of skills; I'm at my limits here!)
So essentially that would be what I did by completely removing the CR version, then installing as a .deb?
DELL XPS 15
Lots of test machines
Re: Clementine issues in MX-14 Beta1
#4 Post by anticapitalista »
Yes.
I have uploaded a newer meta-installer deb that should fix this issue. Don't know when it will be ready for download though.
You would have to make sure the new meta-installer deb gets installed before trying to install clementine though.
#5 Post by anticapitalista »
Actually, Clementine is still broken if you use the install-meta app since it installs version 1.2 from the mepis community repo. The version in Debian wheezy 1.0.1 works just fine.
Has anyone running MX-14-beta1 managed to get Clementine from the mepiscr working and if so, how?
I'm thinking that there is some dependency missing when Clementine 1.2 is installed
#6 Post by timkb4cq »
I found the problem.
The Clementine in the M12 CR was compiled against libtag1c2a & libtag1-vanilla 1.8-2 (the newest available at the time), also in the M12 CR, because the wheezy version was too old for it.
Since that time, Wheezy-backports released version 1.9-2 of those libraries, and that's what MX-14 has installed.
Clementine works fine if you force them back to the CR version.
Or Clementine could be rebuilt against the wheezy-backports version.
#7 Post by Jerry3904 »
I installed the recommended gnome-media and it seems to work all right, except for starting in minimized mode.
I just repeated this in my clean install side, using the terminal. That way, gnome-media comes in automatically, and--to my surprise--clem opened up in the standard way, and then worked.
#8 Post by anticapitalista »
timkb4cq wrote:I found the problem.
Thanks Tim.
We'll have to decide which of the repos take priority. We have Mepis, mepiscr, debian wheezy, wheezy-backports and antiX.
The 'problematic ones are mepiscr and debian-backports since some of the apps clash with relation to libs.
For example, on a fresh MX-14-beta1, if you comment out the mepiscr repo, than some audio related libs get upgraded.
If you want to install samba, you must do it from wheezy-backports due to conflicts of libsmbclient (I think).
Do we want wheezy-backports to take priority? If so then a dist-upgrade with debian backports installs a load of stuff to take the iso well over 700MB.
#9 Post by anticapitalista »
Jerry, did you play a file or cd? Try playing a mp3 file if you haven't done so.
#10 Post by Jerry3904 »
DVD. mp3 doesn't play in Clem, though VLC handles it just fine...
Return to “Older Versions”
