Announcing a Repository for the KDE 4.7.4 upgrade
Post by timkb4cq » Mon Jan 30, 2012 10:00 pm
There is now a repository at
deb http://teharris.net/mepiscr/kde/ kde4.7 test
To upgrade MEPIS 11 to KDE 4.7.4
or for those who find it easier to read in the form Synaptic displays it:
kde4.7
test
This is a large upgrade which must be done from the command line, and it's not recommended for novices or for your main production system.
That said, it is a smoother upgrade here than the 4.6.5 was and seems pretty stable in limited testing.
Directions from a clean MEPIS 11 install:
Open Synaptic. Install aptitude and upgrade mepis-confg
If you want to keep Amarok, enable the main CR ( http://main.mepis-deb.org/mepiscr mepis11cr main non-free), Reload, Change Settings -> Preferences -> Distributions to prefer versions from mepis and upgrade ffmpeg.
Now add both KDE repositories
kde4.7
test
and
experimental
test
Reload & close Synaptic.
Open a Console session with <Ctl><Alt><F1> , log in as root and run
aptitude -t mepis dist-upgrade
This should just remove just 2 (no longer needed) libraries (and Amarok if you didn't upgrade ffmpeg), and download over 500 MB of packages to upgrade & install.
When it finishes successfully, run /etc/init.d/kdm restart and you'll boot into your new KDE 4.7.4 desktop.
If you plan to upgrade more than one system, please change your Synaptic Settings -> Preferences -> Files to leave all packages in the cache so you can move them over from /var/cache/apt/archives locally instead of downloading them all over again.
The CR slowed down from all the bandwidth when the last KDE upgrade went up, so be considerate.
Enjoy!
Re: Announcing a Repository for the KDE 4.7.4 upgrade
Post by richb » Mon Jan 30, 2012 10:05 pm
Tim, I assume this is for an upgrade starting with a standard M11 install and the procedure for an upgrade from KDE 4.6.5 is different.
Rich
SSD Production: MX 17.1
Post by timkb4cq » Mon Jan 30, 2012 10:17 pm
Correct, these directions were for a clean MEPIS 11 install. I know they still work if the regular updates have been along the way as well.
I actually haven't tried an upgrade from 4.6.5, but the same process should work. You'll just have the first bits done already.
There will be somewhat less to download as you already will have the newer Qt libraries but it's still a lot.
Post by richb » Mon Jan 30, 2012 10:20 pm
What is the repo Stevo posted then?
deb http://main.mepis-deb.org/mepiscr/kde/ kde4.7 test
Rich
Post by timkb4cq » Mon Jan 30, 2012 10:29 pm
That's the same repo. I wasn't aware he had posted it. I thought he had just PM'd it to some folks.
I've been working out the last few dependency issues before making the announcement. Up until a couple hours ago the upgrade would remove digikam & leave nepomuk crashing on boot up if you hadn't done an update from the testing M11 CR first. I didn't want the M11 testing CR to be a required part of the upgrade if it could be helped.
uncle mark
Post by uncle mark » Mon Jan 30, 2012 10:40 pm
timkb4cq wrote:That's the same repo. I wasn't aware he had posted it. I thought he had just PM'd it to some folks.
Can I assume Warren has been made aware of this, in case it will aid him with his new release?
Desktop: Custom build Asus/AMD/nVidia -- MEPIS 11
Laptop: Acer Aspire 5250 -- MX-15
Assorted junk: assorted Linuxes
Post by Jerry3904 » Mon Jan 30, 2012 10:43 pm
I have kept him in the loop.
KrispyKritter
Post by KrispyKritter » Mon Jan 30, 2012 11:40 pm
I gave it a try and had 7 errors which seem to be dealing with digicam. I don't use digicam as far as I know so I ignored them.
Reboot would not go past the login screen. Went to a failsafe mode and get error that there isn't an acceptable display selected.
This was not done on a fresh install, but one that was less than a month old and had not been tweaked other than loading packages.
Steve
EDIT The system had been up graded to KDE4.6 and was completely up to date (ran apt-get update and upgrade prior to starting the installation of KDE4.7
Steve
I messed with the dragon and now I am ready for the ketchup!
The only stupid question is the one you already know the answer.
~Krispy Kritter~
Toshiba Satellite A215-S7427(AMD-64)
Windows7/M11(KDE4.6.5)/M11(RoadblockTRK2-32)'buntus13.1/MX14b2/Tanglu1.0
Danum
Post by Danum » Tue Jan 31, 2012 9:34 am
Tim, you need to look again regarding what should be removed.
Commit Log for Tue Jan 31 00:21:15 2012
Removed the following packages:
amarok
digikam
kdebase-data (no longer required in KDE 4.7)
kdebase-runtime-data (no longer required in KDE 4.7)
kdebase-workspace-data (no longer required in KDE 4.7)
kdebase-workspace-kgreet-plugins (no longer required in KDE 4.7)
knm-runtime (no longer required in KDE 4.7)
libakonadiprivate1 (no longer required in KDE 4.7)
libkdegames5 (4:4.5.3)(no longer required in KDE 4.7)
libkonq5a (4:4.5.3)(no longer required in KDE 4.7)
Upgraded the following packages:
akonadi-backend-mysql (1.4.0-0r2) to 1.6.2-1mcr115+1
akonadi-server (1.4.0-0r2) to 1.6.2-1mcr115+1
amarok-common (2.4.0-1) to 2.5.0-1mcr115+1
amarok-utils (2.4.0-1) to 2.5.0-1mcr115+1
ark (4:4.5.1-0r1) to 4:4.7.4-1mcr115+1
digikam-data (2:1.9.0-1) to 4:2.5.0-1mcr115+1
dolphin (4:4.5.3-0r1) to 4:4.7.4-1mcr115+1
freespacenotifier (4:4.5.1-0r2) to 4:4.7.4-1mcr115+1
gwenview (4:4.5.1-0r1) to 4:4.7.4-1mcr115+1
kamera (4:4.5.1-0r1) to 4:4.7.4-1mcr115+1
kcalc (4:4.5.1-0r1) to 4:4.7.4-1mcr115+1
kcharselect (4:4.5.1-0r1) to 4:4.7.4-1mcr115+1
kde-config-phonon-xine (4:4.5.3-0r1) to 4:4.7.4-1mcr115+1
kde-window-manager (4:4.5.1-0r2) to 4:4.7.4-1mcr115+1
kdebase-apps (4:4.5.3-0r1) to 4:4.7.4-1mcr115+1
kdebase-bin (4:4.5.3-0r1) to 4:4.7.4-1mcr115+1
kdebase-runtime (4:4.5.3-0r1) to 4:4.7.4-1mcr115+1
kdebase-workspace (4:4.5.1-0r2) to 4:4.7.4-1mcr115+1
kdebase-workspace-bin (4:4.5.1-0r2) to 4:4.7.4-1mcr115+1
kdegames-card-data (4:4.4.5-1) to 4:4.7.4-1mcr115+1
kdegames-mahjongg-data (4:4.4.5-1) to 4:4.7.4-1mcr115+1
kdegraphics-libs-data (4:4.5.1-0r1) to 4:4.7.4+5.73mcr115+1
kdelibs-bin (4:4.5.3-0r1) to 4:4.7.4-1mcr115+1
kdelibs5-data (4:4.5.3-0r1) to 4:4.7.4-1mcr115+1
kdelibs5-plugins (4:4.5.3-0r1) to 4:4.7.4-1mcr115+1
kdemultimedia-kio-plugins (4:4.4.5-1) to 4:4.7.4-1mcr115+1
kdenetwork-filesharing (4:4.5.1-0r1) to 4:4.7.4-1mcr115+1
kdenlive (0.7.8+svn5529-1) to 0.8.2.1-2mcr115+1
kdenlive-data (0.7.8+svn5529-1) to 0.8.2.1-2mcr115+1
kdepasswd (4:4.5.3-0r1) to 4:4.7.4-1mcr115+1
kdepim-kresources (4:4.4.7-3) to 4:4.4.11.1+l10n-1mcr110+1
kdepim-runtime (4:4.4.7-1) to 4:4.4.11.1-2mcr110+1
kdepimlibs-kio-plugins (4:4.5.1-0r1) to 4:4.7.4-1mcr115+1
kdeplasma-addons (4:4.5.1-0r2) to 4:4.7.4-1mcr115+1
kdf (4:4.5.1-0r1) to 4:4.7.4-1mcr115+1
kdm (4:4.5.1-0r2) to 4:4.7.4-1mcr115+1
kdoctools (4:4.5.3-0r1) to 4:4.7.4-1mcr115+1
kfind (4:4.5.3-0r1) to 4:4.7.4-1mcr115+1
kgamma (4:4.5.1-0r1) to 4:4.7.4-1mcr115+1
kgpg (4:4.5.1-0r1) to 4:4.7.4-1mcr115+1
khelpcenter4 (4:4.5.3-0r1) to 4:4.7.4-1mcr115+1
kinfocenter (4:4.5.1-0r2) to 4:4.7.4-1mcr115+1
klines (4:4.4.5-1) to 4:4.7.4-1mcr115+1
klipper (4:4.5.1-0r2) to 4:4.7.4-1mcr115+1
kmahjongg (4:4.4.5-1) to 4:4.7.4-1mcr115+1
kmail (4:4.4.7-3) to 4:4.4.11.1+l10n-1mcr110+1
kmines (4:4.4.5-1) to 4:4.7.4-1mcr115+1
kmix (4:4.4.5-1) to 4:4.7.4-1mcr115+1
knotes (4:4.4.7-3) to 4:4.4.11.1+l10n-1mcr110+1
kolourpaint4 (4:4.5.1-0r1) to 4:4.7.4-1mcr115+1
konq-plugins (4:4.4.0-2+b1) to 4:4.7.4-1mcr115+1
konqueror (4:4.5.3-0r1) to 4:4.7.4-1mcr115+1
konqueror-nsplugins (4:4.5.3-0r1) to 4:4.7.4-1mcr115+1
konsole (4:4.5.3-0r1) to 4:4.7.4-1mcr115+1
kopete (4:4.5.1-0r1) to 4:4.7.4-1mcr115+1
kpat (4:4.4.5-1) to 4:4.7.4-1mcr115+1
kppp (4:4.5.1-0r1) to 4:4.7.4-1mcr115+1
krdc (4:4.5.1-0r1) to 4:4.7.4-1mcr115+1
kscd (4:4.4.5-1) to 4:4.7.4-1mcr115+1
kscreensaver (4:4.5.1-0r2) to 4:4.7.4-1mcr115+1
kshisen (4:4.4.5-1) to 4:4.7.4-1mcr115+1
ksnapshot (4:4.5.1-0r1) to 4:4.7.4-1mcr115+1
ksysguard (4:4.5.1-0r2) to 4:4.7.4-1mcr115+1
ksysguardd (4:4.5.1-0r2) to 4:4.7.4-1mcr115+1
kuser (4:4.4.5-4) to 4:4.7.4-1mcr115+1
kwalletmanager (4:4.5.1-0r1) to 4:4.7.4-1mcr115+1
kwrite (4:4.5.3-0r1) to 4:4.7.4-1mcr115+1
libakonadi-contact4 (4:4.5.1-0r1) to 4:4.7.4-1mcr115+1
libakonadi-kabc4 (4:4.5.1-0r1) to 4:4.7.4-1mcr115+1
libakonadi-kcal4 (4:4.5.1-0r1) to 4:4.7.4-1mcr115+1
libakonadi-kde4 (4:4.5.1-0r1) to 4:4.7.4-1mcr115+1
libakonadi-kmime4 (4:4.5.1-0r1) to 4:4.7.4-1mcr115+1
libattica0 (0.1.4-1) to 0.2.0-1mcr110+1
libdbusmenu-qt2 (0.5.1-1) to 0.9.0-1mcr110+1
libglib2.0-0 (2.24.2-1) to 2.28.6-1mcr110+1
libgpgme++2 (4:4.5.1-0r1) to 4:4.7.4-1mcr115+1
libkabc4 (4:4.5.1-0r1) to 4:4.7.4-1mcr115+1
libkatepartinterfaces4 (4:4.5.3-0r1) to 4:4.7.4-1mcr115+1
libkblog4 (4:4.5.1-0r1) to 4:4.7.4-1mcr115+1
libkcal4 (4:4.5.1-0r1) to 4:4.7.4-1mcr115+1
libkcddb4 (4:4.4.5-1) to 4:4.7.4-1mcr115+1
libkcmutils4 (4:4.5.3-0r1) to 4:4.7.4-1mcr115+1
libkde3support4 (4:4.5.3-0r1) to 4:4.7.4-1mcr115+1
libkdecorations4 (4:4.5.1-0r2) to 4:4.7.4-1mcr115+1
libkdecore5 (4:4.5.3-0r1) to 4:4.7.4-1mcr115+1
libkdepim4 (4:4.4.7-3) to 4:4.4.11.1+l10n-1mcr110+1
libkdesu5 (4:4.5.3-0r1) to 4:4.7.4-1mcr115+1
libkdeui5 (4:4.5.3-0r1) to 4:4.7.4-1mcr115+1
libkdewebkit5 (4:4.5.3-0r1) to 4:4.7.4-1mcr115+1
libkdnssd4 (4:4.5.3-0r1) to 4:4.7.4-1mcr115+1
libkemoticons4 (4:4.5.3-0r1) to 4:4.7.4-1mcr115+1
libkfile4 (4:4.5.3-0r1) to 4:4.7.4-1mcr115+1
libkholidays4 (4:4.5.1-0r1) to 4:4.7.4-1mcr115+1
libkhtml5 (4:4.5.3-0r1) to 4:4.7.4-1mcr115+1
libkidletime4 (4:4.5.3-0r1) to 4:4.7.4-1mcr115+1
libkimap4 (4:4.5.1-0r1) to 4:4.7.4-1mcr115+1
libkimproxy4 (4:4.5.3-0r1) to 4:4.7.4-1mcr115+1
libkio5 (4:4.5.3-0r1) to 4:4.7.4-1mcr115+1
libkjsapi4 (4:4.5.3-0r1) to 4:4.7.4-1mcr115+1
libkjsembed4 (4:4.5.3-0r1) to 4:4.7.4-1mcr115+1
libkldap4 (4:4.5.1-0r1) to 4:4.7.4-1mcr115+1
libkleo4 (4:4.4.7-3) to 4:4.4.11.1+l10n-1mcr110+1
libkmediaplayer4 (4:4.5.3-0r1) to 4:4.7.4-1mcr115+1
libkmime4 (4:4.5.1-0r1) to 4:4.7.4-1mcr115+1
libknewstuff2-4 (4:4.5.3-0r1) to 4:4.7.4-1mcr115+1
libknewstuff3-4 (4:4.5.3-0r1) to 4:4.7.4-1mcr115+1
libknotifyconfig4 (4:4.5.3-0r1) to 4:4.7.4-1mcr115+1
libkntlm4 (4:4.5.3-0r1) to 4:4.7.4-1mcr115+1
libkonq5-templates (4:4.5.3-0r1) to 4:4.7.4-1mcr115+1
libkonqsidebarplugin4a (4:4.5.3-0r1) to 4:4.7.4-1mcr115+1
libkontactinterface4 (4:4.5.1-0r1) to 4:4.7.4-1mcr115+1
libkopete4 (4:4.5.1-0r1) to 4:4.7.4-1mcr115+1
libkparts4 (4:4.5.3-0r1) to 4:4.7.4-1mcr115+1
libkpgp4 (4:4.4.7-3) to 4:4.4.11.1+l10n-1mcr110+1
libkpimidentities4 (4:4.5.1-0r1) to 4:4.7.4-1mcr115+1
libkpimtextedit4 (4:4.5.1-0r1) to 4:4.7.4-1mcr115+1
libkpimutils4 (4:4.5.1-0r1) to 4:4.7.4-1mcr115+1
libkprintutils4 (4:4.5.3-0r1) to 4:4.7.4-1mcr115+1
libkpty4 (4:4.5.3-0r1) to 4:4.7.4-1mcr115+1
libkresources4 (4:4.5.1-0r1) to 4:4.7.4-1mcr115+1
libkrosscore4 (4:4.5.3-0r1) to 4:4.7.4-1mcr115+1
libkrossui4 (4:4.5.3-0r1) to 4:4.7.4-1mcr115+1
libkscreensaver5 (4:4.5.1-0r2) to 4:4.7.4-1mcr115+1
libksgrd4 (4:4.5.1-0r2) to 4:4.7.4-1mcr115+1
libksieve4 (4:4.4.7-3) to 4:4.4.11.1+l10n-1mcr110+1
libksignalplotter4 (4:4.5.1-0r2) to 4:4.7.4-1mcr115+1
libktexteditor4 (4:4.5.3-0r1) to 4:4.7.4-1mcr115+1
libktnef4 (4:4.5.1-0r1) to 4:4.7.4-1mcr115+1
libkunitconversion4 (4:4.5.3-0r1) to 4:4.7.4-1mcr115+1
libkutils4 (4:4.5.3-0r1) to 4:4.7.4-1mcr115+1
libkworkspace4 (4:4.5.1-0r2) to 4:4.7.4-1mcr115+1
libkxmlrpcclient4 (4:4.5.1-0r1) to 4:4.7.4-1mcr115+1
libmailtransport4 (4:4.5.1-0r1) to 4:4.7.4-1mcr115+1
libmessagecore4 (4:4.4.7-3) to 4:4.4.11.1+l10n-1mcr110+1
libmessagelist4 (4:4.4.7-3) to 4:4.4.11.1+l10n-1mcr110+1
libmicroblog4 (4:4.5.1-0r1) to 4:4.7.4-1mcr115+1
libmimelib4 (4:4.4.7-3) to 4:4.4.11.1+l10n-1mcr110+1
libnepomuk4 (4:4.5.3-0r1) to 4:4.7.4-1mcr115+1
libnepomukquery4a (4:4.5.3-0r1) to 4:4.7.4-1mcr115+1
libokularcore1 (4:4.5.1-0r1) to 4:4.7.4-1mcr115+1
libpcre3 (8.02-1.1) to 8.12-3mcr110+1
libphonon4 (4:4.6.0really4.4.3-1) to 4:4.6.0really4.5.0-4mcr110+1
libplasma-geolocation-interface4 (4:4.5.1-0r2) to 4:4.7.4-1mcr115+1
libplasma3 (4:4.5.3-0r1) to 4:4.7.4-1mcr115+1
libplasmagenericshell4 (4:4.5.1-0r2) to 4:4.7.4-1mcr115+1
libpolkit-agent-1-0 (0.96-4+squeeze1) to 0.102-1mcr110+1
libpolkit-backend-1-0 (0.96-4+squeeze1) to 0.102-1mcr110+1
libpolkit-gobject-1-0 (0.96-4+squeeze1) to 0.102-1mcr110+1
libpoppler-qt4-3 (0.12.4-1.2) to 0.16.7-2mcr110+1
libprocessui4a (4:4.5.1-0r2) to 4:4.7.4-1mcr115+1
libqgpgme1 (4:4.5.1-0r1) to 4:4.7.4-1mcr115+1
libqjson0 (0.7.1-1) to 0.7.1-3mcr110+1
libqt4-assistant (4:4.7.1-2) to 4:4.7.3-8mcr110+1
libqt4-core (4:4.7.1-2) to 4:4.7.3-8mcr110+1
libqt4-dbus (4:4.7.1-2) to 4:4.7.3-8mcr110+1
libqt4-designer (4:4.7.1-2) to 4:4.7.3-8mcr110+1
libqt4-gui (4:4.7.1-2) to 4:4.7.3-8mcr110+1
libqt4-help (4:4.7.1-2) to 4:4.7.3-8mcr110+1
libqt4-network (4:4.7.1-2) to 4:4.7.3-8mcr110+1
libqt4-opengl (4:4.7.1-2) to 4:4.7.3-8mcr110+1
libqt4-qt3support (4:4.7.1-2) to 4:4.7.3-8mcr110+1
libqt4-script (4:4.7.1-2) to 4:4.7.3-8mcr110+1
libqt4-scripttools (4:4.7.1-2) to 4:4.7.3-8mcr110+1
libqt4-sql (4:4.7.1-2) to 4:4.7.3-8mcr110+1
libqt4-sql-mysql (4:4.7.1-2) to 4:4.7.3-8mcr110+1
libqt4-sql-sqlite (4:4.7.1-2) to 4:4.7.3-8mcr110+1
libqt4-svg (4:4.7.1-2) to 4:4.7.3-8mcr110+1
libqt4-test (4:4.7.1-2) to 4:4.7.3-8mcr110+1
libqt4-webkit (4:4.7.1-2) to 4:4.7.3-8mcr110+1
libqt4-xml (4:4.7.1-2) to 4:4.7.3-8mcr110+1
libqt4-xmlpatterns (4:4.7.1-2) to 4:4.7.3-8mcr110+1
libqtcore4 (4:4.7.1-2) to 4:4.7.3-8mcr110+1
libqtgui4 (4:4.7.1-2) to 4:4.7.3-8mcr110+1
libqtwebkit4 (2.0~week26-2) to 2.1.0~2011week13-3mcr110+1
libsolid4 (4:4.5.3-0r1) to 4:4.7.4-1mcr115+1
libsoprano4 (2.5.0+dfsg.1-1) to 2.7.3+dfsg.1-1mcr115+1
libsyndication4 (4:4.5.1-0r1) to 4:4.7.4-1mcr115+1
libthreadweaver4 (4:4.5.3-0r1) to 4:4.7.4-1mcr115+1
libvncserver0 (0.9.7-2+b1) to 0.9.8.2-2mcr115+1
marble-data (4:4.5.1-0r2) to 4:4.7.4-1mcr115+1
marble-plugins (4:4.5.1-0r2) to 4:4.7.4-1mcr115+1
network-manager (0.8.1-6+squeeze1) to 0.9.0-2mcr110+1
okular (4:4.5.1-0r1) to 4:4.7.4-1mcr115+1
okular-extra-backends (4:4.5.1-0r1) to 4:4.7.4-1mcr115+1
oxygen-icon-theme (4:4.5.1-0r1) to 4:4.6.2-1mcr110+1
phonon (4:4.6.0really4.4.3-1) to 4:4.6.0really4.5.0-4mcr110+1
phonon-backend-xine (4:4.6.0really4.4.3-1) to 4:4.6.0really4.4.4-4mcr110+1
plasma-dataengines-addons (4:4.5.1-0r2) to 4:4.7.4-1mcr115+1
plasma-dataengines-workspace (4:4.5.1-0r2) to 4:4.7.4-1mcr115+1
plasma-dataengines-yawp (0.3.6-2) to 0.3.6-2mcr110+1
plasma-desktop (4:4.5.1-0r2) to 4:4.7.4-1mcr115+1
plasma-desktopthemes-artwork (4:4.5.1-0r2) to 4:4.7.4-1mcr115+1
plasma-netbook (4:4.5.1-0r2) to 4:4.7.4-1mcr115+1
plasma-runners-addons (4:4.5.1-0r2) to 4:4.7.4-1mcr115+1
plasma-scriptengine-javascript (4:4.5.3-0r1) to 4:4.7.4-1mcr115+1
plasma-scriptengine-python (4:4.5.1-0r2) to 4:4.7.4-1mcr115+1
plasma-scriptengine-webkit (4:4.5.1-0r2) to 4:4.7.4-1mcr115+1
plasma-wallpapers-addons (4:4.5.1-0r2) to 4:4.7.4-1mcr115+1
plasma-widget-folderview (4:4.5.3-0r1) to 4:4.7.4-1mcr115+1
plasma-widget-lancelot (4:4.5.1-0r2) to 4:4.7.4-1mcr115+1
plasma-widget-networkmanagement (0.1~svn1175124-1+kde45) to 0.9~git20111103.1240c6f-1mcr110+1
plasma-widget-yawp (0.3.6-2) to 0.3.6-2mcr110+1
plasma-widgets-addons (4:4.5.1-0r2) to 4:4.7.4-1mcr115+1
plasma-widgets-workspace (4:4.5.1-0r2) to 4:4.7.4-1mcr115+1
policykit-1 (0.96-4+squeeze1) to 0.102-1mcr110+1
polkit-kde-1 (0.95.1-2+b1) to 0.99.0-3mcr110+1
poppler-utils (0.12.4-1.2) to 0.16.7-2mcr110+1
printer-applet (4:4.5.1-0r1) to 4:4.7.4-1mcr115+1
python-dbus (0.83.1-1) to 0.84.0-2mcr110+1
python-kde4 (4:4.4.5-3) to 4:4.6.80-3mcr110+1
python-qt4 (4.7.3-1+b1) to 4.8.3-4mcr110+1
python-qt4-dbus (4.7.3-1+b1) to 4.8.3-4mcr110+1
python-sip (4.10.2-1) to 4.12.3-1mcr110+1
shared-desktop-ontologies (0.5-1) to 0.8.1-2mcr115+1
soprano-daemon (2.5.0+dfsg.1-1) to 2.7.3+dfsg.1-1mcr115+1
sweeper (4:4.5.1-0r1) to 4:4.7.4-1mcr115+1
system-config-printer-kde (4:4.4.5-4) to 4:4.7.4-1mcr115+1
systemsettings (4:4.5.1-0r2) to 4:4.7.4-1mcr115+1
wpasupplicant (0.6.10-2.1) to 0.7.3-5mcr110+1
Installed the following packages:
docbook-xsl (1.75.2+dfsg-5)
kate-data (4:4.7.4-1mcr115+1)
katepart (4:4.7.4-1mcr115+1)
kde-baseapps (4:4.7.4-1mcr115+1)
kde-baseapps-bin (4:4.7.4-1mcr115+1)
kde-baseapps-data (4:4.7.4-1mcr115+1)
kde-runtime (4:4.7.4-1mcr115+1)
kde-runtime-data (4:4.7.4-1mcr115+1)
kde-style-oxygen (4:4.7.4-1mcr115+1)
kde-wallpapers-default (4:4.7.4-1mcr115+1)
kde-workspace (4:4.7.4-1mcr115+1)
kde-workspace-bin (4:4.7.4-1mcr115+1)
kde-workspace-data (4:4.7.4-1mcr115+1)
kde-workspace-kgreet-plugins (4:4.7.4-1mcr115+1)
libakonadiprotocolinternals1 (1.6.2-1mcr115+1)
libcanberra0 (0.24-1)
libdiscid0 (0.2.2-1)
libdlrestrictions1 (0.14.2-1mcr110+1)
libdmtx0a (0.7.2-1+b1)
libexiv2-11 (0.22-1mcr110+1)
libkcalcore4 (4:4.7.4-1mcr115+1)
libkcalutils4 (4:4.7.4-1mcr115+1)
libkdcraw-data (4:4.7.4-1mcr115+1)
libkdcraw20 (4:4.7.4-1mcr115+1)
libkdeclarative5 (4:4.7.4-1mcr115+1)
libkdegames5a (4:4.7.4-1mcr115+1)
libkephal4abi1 (4:4.7.4-1mcr115+1)
libkexiv2-10 (4:4.7.4-1mcr115+1)
libkexiv2-data (4:4.7.4-1mcr115+1)
libkipi-data (4:4.7.4-1mcr115+1)
libkipi8 (4:4.7.4-1mcr115+1)
libkmahjongglib4 (4:4.7.4-1mcr115+1)
libkonq-common (4:4.7.4-1mcr115+1)
libkonq5abi1 (4:4.7.4-1mcr115+1)
libksane-data (4:4.7.4-1mcr115+1)
libkwineffects1abi2 (4:4.7.4-1mcr115+1)
libmarblewidget12 (4:4.7.4-1mcr115+1)
libmusicbrainz3-6 (3.0.2-2)
libnepomukutils4 (4:4.7.4-1mcr115+1)
libnl3 (3.0-2mcr110+1)
libnm-glib4 (0.9.0-2mcr110+1)
libnm-util2 (0.9.0-2mcr110+1)
libopencv-core2.3 (2.3.1-4mcr110+1)
libopencv-flann2.3 (2.3.1-4mcr110+1)
libopencv-imgproc2.3 (2.3.1-4mcr110+1)
libopencv-video2.3 (2.3.1-4mcr110+1)
libplasmaclock4abi2 (4:4.7.4-1mcr115+1)
libpolkit-qt-1-1 (0.99.0-3mcr110+1)
libpoppler13 (0.16.7-2mcr110+1)
libprison0 (1.0+dfsg-1mcr115+1)
libprocesscore4abi1 (4:4.7.4-1mcr115+1)
libqrencode3 (3.1.1-1)
libqt4-declarative (4:4.7.3-8mcr110+1)
libqtlocation1 (1.2.0-1mcr110+1)
libqtmultimediakit1 (1.2.0-1mcr110+1)
libqzeitgeist0 (0.7.0-1mcr110+1)
libsolidcontrol4abi1 (4:4.6.5-2mcr110+2)
libsolidcontrol4abi2 (4:4.7.4-1mcr115+1)
libsolidcontrolifaces4abi2 (4:4.7.4-1mcr115+1)
libtaskmanager4abi2 (4:4.7.4-1mcr115+1)
libtdb1 (1.2.1-2+b1)
libupower-glib1 (0.9.5-5)
libweather-ion6 (4:4.7.4-1mcr115+1)
mobile-broadband-provider-info (20110806-1mcr110+1)
plasma-containments-addons (4:4.7.4-1mcr115+1)
upower (0.9.5-5)
Desktop.
Zalman Z11 Plus ATX PC Tower, AMD FX 8350 Black Edition Vishera, 8 Core 4.4 GHz, Kingston HyperX FURY Red 16GB, Nvidia GT740 Graphics, Pioneer BDR-209EBK Writer, 2 x Seagate 1TB SSHD SATA Hybrid Hard Drives. ASUS VS278Q 27 inch HD Monitor
#10
Post by Stevo » Tue Jan 31, 2012 12:54 pm
Digikam 2.0 unfortunately included parts of KDE 4.7 as separate libraries. After removing digikam, showfoto, and kipi-plugins, an
apt-get autoremove
should flush all those libraries out, since nothing else uses them, then allow for the digikam 2.5.0 upgrade.
The optimist proclaims that we live in the best of all possible worlds, and the pessimist fears this is true.
James Branch Cabell
Return to “Community Submissions”
