I come from Debian and I'm currently testing MX Linux on a persistent live USB. I was trying to install the package lilv-utills, but it's not available from synaptic.
Is there any chance to install that package in MX linux?
missing package - lilv-utils
Re: missing package - lilv-utils
lilv-utils typo?
Yes lilv-utils like in the topic description.
... but not in your description
On antiX no issue installing itI was trying to install the package lilv-utills
# apt-get install lilv-utils
Reading package lists... Done
Building dependency tree
The following additional packages will be installed:
liblilv-0-0 libserd-0-0 libsord-0-0 libsratom-0-0
Suggested packages:
serdi sordi
The following NEW packages will be installed:
liblilv-0-0 libserd-0-0 libsord-0-0 libsratom-0-0 lilv-utils
0 upgraded, 5 newly installed, 0 to remove and 0 not upgraded.
Need to get 151 kB of archives.
After this operation, 471 kB of additional disk space will be used.
Do you want to continue? [Y/n] n
Abort.
root@antix1:/home/anticap#
Thanks, I will check it again tomorrow.
No problem installing on MX, either.
Could you show us the output of
If the second command shows not available, then the output of
inxi -r
apt policy lilv-utils
sudo apt-get update
Just tested again and it was not working. After apt-get update and upgrade the package was found. -> Problem solved. Thanks!
Ahh, the problem is that the apt database has to be populated after an install before you can see any uninstalled packages from the repos. Mostly, MX Updater does it eventually in the background, but you can do it manually if in a hurry.
