Icon breakage on MX18?
manyroads
#1 Post by manyroads »
Hi all.
Is anyone out there using 'evolution' on MX18? I suspect that 'evolution' is the cuprit causing my wife's ePapirus icons to reset to Adwaita icons. She needs to logout &login in order to reset (fix) them. I run the same themes, icons, etc but no 'evolution' and have zero problems. Ergo the 'blame' assessment.
Re: Icon breakage on MX18?
#2 Post by Stevo »
Is Evolution "only a theory?"
<rimshot>
Sorry, couldn't resist.
manyroads
#3 Post by manyroads »
I think I have toe lint in my mouth.... :footinmouth:
c7RAfN0H
#4 Post by c7RAfN0H »
when do the icons change
manyroads
#5 Post by manyroads »
after she closes the evolution window or brings the screen back from suspend
edit: I'm guessing it is an evolution gtk3 'thing' of some sort. She did not have the problem on manjaro xfce4.13
#6 Post by asqwerth »
If you save the icon set in user's home instead of in root, the icons won't show up for programs run as root.
manyroads
#7 Post by manyroads »
They are installed system wide.... I'll duplicate them in her home dirs
#8 Post by Adrian »
Stevo wrote: Sat Jan 05, 2019 5:47 pm Is Evolution "only a theory?"
<rimshot>
If we have GNOME, why there's still a Mono?
